Hi
I am not sure if this is the correct place to post this, apologies if it isn’t.
I have a GTX 1660 Ti, and Ubuntu 19.10. I am running the nvidia-driver-418 from the ppa. It works fantastically for my 5.3.0 kernel.
However, I have installed the latest 5.6-rc4 (or rc1,2,3 I have tried all of them). And my X server does not startup (Login loop). This is with the ppa 418 driver installed. (which works fine with the older 5.3 kernel)
So I saw that the latest 440.64 driver supports the RC of 5.6 ( NVIDIA 440.64 Driver Released With MX330/MX350 Support, Linux 5.6 Compatibility - Phoronix )
and I am attempting to build it (from 5.6 kernel, init level 3). However, I am getting a lot of compile errors.
sudo ./NVIDIA-Linux-x86_64-440.64.run
/tmp/selfgz1311/NVIDIA-Linux-x86_64-440.64/kernel/nvidia/linux_nvswitch.c:1583:5: error: implicit declaration of function 'getnstimeofday'; did you mean 'efi_gettimeofday'? [-Werror=implicit-function-declaration]
1583 | getnstimeofday(&ts);
| efi_gettimeofday
make[2]: *** [scripts/Makefile.build:268: /tmp/selfgz1311/NVIDIA-Linux-x86_64-440.64/kernel/nvidia/nvlink_linux.o] Error 1
/tmp/selfgz1311/NVIDIA-Linux-x86_64-440.64/kernel/nvidia/os-interface.c: In function '_os_ipmi_receive_resp':
/tmp/selfgz1311/NVIDIA-Linux-x86_64-440.64/kernel/nvidia/os-interface.c:1957:29: error: storage size of 'tv' isn't known
1957 | struct timeval tv;
/tmp/selfgz1311/NVIDIA-Linux-x86_64-440.64/kernel/nvidia/os-interface.c:1957:29: warning: unused variable 'tv' [-Wunused-variable]
/tmp/selfgz1311/NVIDIA-Linux-x86_64-440.64/kernel/nvidia/linux_nvswitch.c:1584:21: error: implicit declaration of function 'timespec_to_ns'; did you mean 'timespec64_to_ns'? [-Werror=implicit-function-declaration]
1584 | return ((NvU64) timespec_to_ns(&ts));
| timespec64_to_ns
/tmp/selfgz1311/NVIDIA-Linux-x86_64-440.64/kernel/nvidia/linux_nvswitch.c:1581:21: warning: unused variable 'ts' [-Wunused-variable]
1581 | struct timespec ts;
cc1: some warnings being treated as errors
/tmp/selfgz1311/NVIDIA-Linux-x86_64-440.64/kernel/nvidia/linux_nvswitch.c:1585:1: warning: control reaches end of non-void function [-Wreturn-type]
1585 | }
make[2]: *** [scripts/Makefile.build:268: /tmp/selfgz1311/NVIDIA-Linux-x86_64-440.64/kernel/nvidia/os-interface.o] Error 1
make[2]: *** [scripts/Makefile.build:268: /tmp/selfgz1311/NVIDIA-Linux-x86_64-440.64/kernel/nvidia/linux_nvswitch.o] Error 1
make[2]: *** [scripts/Makefile.build:268: /tmp/selfgz1311/NVIDIA-Linux-x86_64-440.64/kernel/nvidia/nv-procfs.o] Error 1
make[2]: Target '__build' not remade because of errors.
make[1]: *** [Makefile:1681: /tmp/selfgz1311/NVIDIA-Linux-x86_64-440.64/kernel] Error 2
make[1]: Target 'modules' not remade because of errors.
make[1]: Leaving directory '/usr/src/linux-headers-5.6.0-050600rc3-generic'
make: *** [Makefile:81: modules] Error 2
ERROR: The nvidia kernel module was not created.
ERROR: Installation has failed. Please see the file '/var/log/nvidia-installer.log' for details. You may find suggestions on fixing installation problems in the README available on the Linux driver download page at www.nvidia.com.
This goes on and on and on.
gcc -v
Using built-in specs.
COLLECT_GCC=gcc
COLLECT_LTO_WRAPPER=/usr/lib/gcc/x86_64-linux-gnu/9/lto-wrapper
OFFLOAD_TARGET_NAMES=nvptx-none:hsa
OFFLOAD_TARGET_DEFAULT=1
Target: x86_64-linux-gnu
Configured with: ../src/configure -v --with-pkgversion='Ubuntu 9.2.1-9ubuntu2' --with-bugurl=file:///usr/share/doc/gcc-9/README.Bugs --enable-languages=c,ada,c++,go,brig,d,fortran,objc,obj-c++,gm2 --prefix=/usr --with-gcc-major-version-only --program-suffix=-9 --program-prefix=x86_64-linux-gnu- --enable-shared --enable-linker-build-id --libexecdir=/usr/lib --without-included-gettext --enable-threads=posix --libdir=/usr/lib --enable-nls --enable-bootstrap --enable-clocale=gnu --enable-libstdcxx-debug --enable-libstdcxx-time=yes --with-default-libstdcxx-abi=new --enable-gnu-unique-object --disable-vtable-verify --enable-plugin --enable-default-pie --with-system-zlib --with-target-system-zlib=auto --enable-multiarch --disable-werror --with-arch-32=i686 --with-abi=m64 --with-multilib-list=m32,m64,mx32 --enable-multilib --with-tune=generic --enable-offload-targets=nvptx-none,hsa --without-cuda-driver --enable-checking=release --build=x86_64-linux-gnu --host=x86_64-linux-gnu --target=x86_64-linux-gnu
Thread model: posix
gcc version 9.2.1 20191008 (Ubuntu 9.2.1-9ubuntu2)
cat /proc/version
Linux version 5.3.0-40-generic (buildd@lcy01-amd64-026) (gcc version 9.2.1 20191008 (Ubuntu 9.2.1-9ubuntu2)) #32-Ubuntu SMP Fri Jan 31 20:24:34 UTC 2020
I think my issue might be the wrong GCC version, but I can’t find anything in the README to indicate what version I need.
Any help would be greatly appreciated.
