Installing Nvidia Nemo framework
Hello all,
I’m looking for the best way to install NeMo on my SLURM cluster. The cluster currently has no GPUs—it’s CPU-only—but I plan to upgrade with GPUs later. In the meantime, I’d like to start experimenting with NeMo using small models (<1B parameters) since anything larger may not be practical to run and train.
I’ve been trying to install the NeMo framework on my SLURM cluster but haven’t had much success, even with a simple “Hello, World” program. I want to confirm whether my installation approach is correct.
I looked into using Docker, but my impression is that it’s better suited for a single-computer setup. Since I need NeMo installed across multiple nodes, I believe the pip installation method might be more appropriate. However, when trying to install nemo-curator via pip, I encountered an error.
For my setup, is there anything specific I need to do to make the pip installation work? Or should I explore Docker further despite using SLURM?
Hello ,
This forum talks about issues specific to TRT, and might not resolve your query.
Thank you Aakankshas, I could repost in another forum. Could you please recommend a forum that I could post to?
@phillipmobley2 I will close this post. I will move your other post (from the workbench forum, which has more info in), to the AI & DS forum. and will follow up to get an answer from the NeMo team. Thanks for your patience here!
