Installing Tensorflow 2.7.0 with Python 3.7 on Jetson Nano with JetPack 4.6.1
I need to use Tensorflow 2.7.0 or later with Python 3.7 or later on Jetson nano with JetPack 4.6.1.
I’ve tried using
python3.7 -m pip install --extra-index-url https://developer.download.nvidia.com/compute/redist/jp/v461 tensorflow==2.7.0+nv22.01
But it gives
Looking in indexes: https://pypi.org/simple, https://developer.download.nvidia.com/compute/redist/jp/v461
ERROR: Could not find a version that satisfies the requirement tensorflow==2.7.0+nv22.01 (from versions: 2.10.0rc0, 2.10.0rc1, 2.10.0rc2, 2.10.0rc3, 2.10.0, 2.10.1, 2.11.0rc0, 2.11.0rc1, 2.11.0rc2, 2.11.0)
ERROR: No matching distribution found for tensorflow==2.7.0+nv22.01
Checked the Index of /compute/redist/jp/v461/tensorflow and found tensorflow-2.7.0+nv22.1-cp36-cp36m-linux_aarch64.whl which only available for Python 3.6.
Tried to install Tensorflow 2.10.0 but I got this error during import
>>> import tensorflow as tf
/home/acd/accident-crime-detection/acd/lib/python3.7/site-packages/tensorflow_io/python/ops/__init__.py:98: UserWarning: unable to load libtensorflow_io_plugins.so: unable to open file: libtensorflow_io_plugins.so, from paths: ['/home/acd/accident-crime-detection/acd/lib/python3.7/site-packages/tensorflow_io/python/ops/libtensorflow_io_plugins.so']
caused by: ["[Errno 2] The file to load file system plugin from does not exist.: '/home/acd/accident-crime-detection/acd/lib/python3.7/site-packages/tensorflow_io/python/ops/libtensorflow_io_plugins.so'"]
  warnings.warn(f"unable to load libtensorflow_io_plugins.so: {e}")
/home/acd/accident-crime-detection/acd/lib/python3.7/site-packages/tensorflow_io/python/ops/__init__.py:104: UserWarning: file system plugins are not loaded: unable to open file: libtensorflow_io.so, from paths: ['/home/acd/accident-crime-detection/acd/lib/python3.7/site-packages/tensorflow_io/python/ops/libtensorflow_io.so']
caused by: ['/home/acd/accident-crime-detection/acd/lib/python3.7/site-packages/tensorflow_io/python/ops/libtensorflow_io.so: cannot open shared object file: No such file or directory']
  warnings.warn(f"file system plugins are not loaded: {e}")
Tried using Tensorflow 2.7.0 for Python 3.7 wheel from Tensorflow-bin, but still error during import.
  File "/home/acd/accident-crime-detection/acd/lib/python3.7/site-packages/tensorflow/python/pywrap_tensorflow.py", line 64, in <module>
    from tensorflow.python._pywrap_tensorflow_internal import *
ImportError: /lib/aarch64-linux-gnu/libc.so.6: version `GLIBC_2.28' not found (required by /home/acd/accident-crime-detection/acd/lib/python3.7/site-packages/tensorflow/python/_pywrap_tensorflow_internal.so)
During handling of the above exception, another exception occurred:
  File "<stdin>", line 1, in <module>
  File "/home/acd/accident-crime-detection/acd/lib/python3.7/site-packages/tensorflow/__init__.py", line 41, in <module>
    from tensorflow.python.tools import module_util as _module_util
  File "/home/acd/accident-crime-detection/acd/lib/python3.7/site-packages/tensorflow/python/__init__.py", line 40, in <module>
    from tensorflow.python import pywrap_tensorflow as _pywrap_tensorflow
  File "/home/acd/accident-crime-detection/acd/lib/python3.7/site-packages/tensorflow/python/pywrap_tensorflow.py", line 80, in <module>
    f'{traceback.format_exc()}'
ImportError: Traceback (most recent call last):
Failed to load the native TensorFlow runtime.
See https://www.tensorflow.org/install/errors for some common causes and solutions.
If you need help, create an issue at https://github.com/tensorflow/tensorflow/issues and include the entire stack trace above this error message.
This error persist even after I installed libc6 and libc6-dev using
sudo apt-get install -y libc6 libc6-dev
What should I do? should I install the Tensorflow 2.7.0 from the source?
Yes, please build it from the source.
We only support python 3.6 for Nano.
I’ve tried build the Tensorflow from the source for a while, but got this error
ERROR: /home/acd/tensorflow/tensorflow/compiler/mlir/tensorflow/BUILD:572:11: C++ compilation of rule '//tensorflow/compiler/mlir/tensorflow:tensorflow_ops' failed (Exit 4): crosstool_wrapper_driver_is_not_gcc failed: error executing command
  (cd /home/acd/.cache/bazel/_bazel_acd/cde8dcf7cee5950e7dfb9a438207f0dd/execroot/org_tensorflow && \
  exec env - \
    CUDA_TOOLKIT_PATH=/usr/local/cuda-10.2 \
    GCC_HOST_COMPILER_PATH=/usr/bin/aarch64-linux-gnu-gcc-7 \
    LD_LIBRARY_PATH=/usr/local/cuda-10.2/lib64:/usr/local/cuda-10.2/lib64: \
    PATH=/usr/local/cuda-10.2/bin:/home/acd/.local/bin:/home/acd/bin:/usr/local/sbin:/usr/local/bin:/usr/sbin:/usr/bin:/sbin:/bin:/usr/games:/usr/local/games:/snap/bin \
    PWD=/proc/self/cwd \
    PYTHON_BIN_PATH=/usr/bin/python3.7 \
    PYTHON_LIB_PATH=/usr/local/lib/python3.7/dist-packages \
    TF2_BEHAVIOR=1 \
    TF_CUDA_COMPUTE_CAPABILITIES=5.3 \
  external/local_config_cuda/crosstool/clang/bin/crosstool_wrapper_driver_is_not_gcc -MD -MF bazel-out/aarch64-opt/bin/tensorflow/compiler/mlir/tensorflow/_objs/tensorflow_ops/tf_ops.pic.d '-frandom-seed=bazel-out/aarch64-opt/bin/tensorflow/compiler/mlir/tensorflow/_objs/tensorflow_ops/tf_ops.pic.o' '-DLLVM_ON_UNIX=1' '-DHAVE_BACKTRACE=1' '-DBACKTRACE_HEADER=<execinfo.h>' '-DLTDL_SHLIB_EXT=".so"' '-DLLVM_PLUGIN_EXT=".so"' '-DLLVM_ENABLE_THREADS=1' '-DHAVE_SYSEXITS_H=1' '-DHAVE_UNISTD_H=1' '-DHAVE_STRERROR_R=1' '-DHAVE_LIBPTHREAD=1' '-DHAVE_PTHREAD_GETNAME_NP=1' '-DHAVE_PTHREAD_SETNAME_NP=1' '-DHAVE_PTHREAD_GETSPECIFIC=1' '-DHAVE_REGISTER_FRAME=1' '-DHAVE_DEREGISTER_FRAME=1' -D_GNU_SOURCE '-DHAVE_LINK_H=1' '-DHAVE_LSEEK64=1' '-DHAVE_MALLINFO=1' '-DHAVE_POSIX_FALLOCATE=1' '-DHAVE_SBRK=1' '-DHAVE_STRUCT_STAT_ST_MTIM_TV_NSEC=1' '-DLLVM_NATIVE_ARCH="AArch64"' '-DLLVM_NATIVE_ASMPARSER=LLVMInitializeAArch64AsmParser' '-DLLVM_NATIVE_ASMPRINTER=LLVMInitializeAArch64AsmPrinter' '-DLLVM_NATIVE_DISASSEMBLER=LLVMInitializeAArch64Disassembler' '-DLLVM_NATIVE_TARGET=LLVMInitializeAArch64Target' '-DLLVM_NATIVE_TARGETINFO=LLVMInitializeAArch64TargetInfo' '-DLLVM_NATIVE_TARGETMC=LLVMInitializeAArch64TargetMC' '-DLLVM_NATIVE_TARGETMCA=LLVMInitializeAArch64TargetMCA' '-DLLVM_HOST_TRIPLE="aarch64-unknown-linux-gnu"' '-DLLVM_DEFAULT_TARGET_TRIPLE="aarch64-unknown-linux-gnu"' -D__STDC_LIMIT_MACROS -D__STDC_CONSTANT_MACROS -D__STDC_FORMAT_MACROS -DEIGEN_MPL2_ONLY '-DEIGEN_MAX_ALIGN_BYTES=64' -iquote . -iquote bazel-out/aarch64-opt/bin -iquote external/llvm-project -iquote bazel-out/aarch64-opt/bin/external/llvm-project -iquote external/llvm_terminfo -iquote bazel-out/aarch64-opt/bin/external/llvm_terminfo -iquote external/llvm_zlib -iquote bazel-out/aarch64-opt/bin/external/llvm_zlib -iquote external/com_google_absl -iquote bazel-out/aarch64-opt/bin/external/com_google_absl -iquote external/nsync -iquote bazel-out/aarch64-opt/bin/external/nsync -iquote external/eigen_archive -iquote bazel-out/aarch64-opt/bin/external/eigen_archive -iquote external/gif -iquote bazel-out/aarch64-opt/bin/external/gif -iquote external/libjpeg_turbo -iquote bazel-out/aarch64-opt/bin/external/libjpeg_turbo -iquote external/com_google_protobuf -iquote bazel-out/aarch64-opt/bin/external/com_google_protobuf -iquote external/com_googlesource_code_re2 -iquote bazel-out/aarch64-opt/bin/external/com_googlesource_code_re2 -iquote external/farmhash_archive -iquote bazel-out/aarch64-opt/bin/external/farmhash_archive -iquote external/fft2d -iquote bazel-out/aarch64-opt/bin/external/fft2d -iquote external/highwayhash -iquote bazel-out/aarch64-opt/bin/external/highwayhash -iquote external/zlib -iquote bazel-out/aarch64-opt/bin/external/zlib -iquote external/local_config_cuda -iquote bazel-out/aarch64-opt/bin/external/local_config_cuda -iquote external/double_conversion -iquote bazel-out/aarch64-opt/bin/external/double_conversion -iquote external/local_config_rocm -iquote bazel-out/aarch64-opt/bin/external/local_config_rocm -iquote external/local_config_tensorrt -iquote bazel-out/aarch64-opt/bin/external/local_config_tensorrt -Ibazel-out/aarch64-opt/bin/external/llvm-project/mlir/_virtual_includes/BuiltinAttributeInterfacesIncGen -Ibazel-out/aarch64-opt/bin/external/llvm-project/mlir/_virtual_includes/BuiltinAttributesIncGen -Ibazel-out/aarch64-opt/bin/external/llvm-project/mlir/_virtual_includes/BuiltinDialectIncGen -Ibazel-out/aarch64-opt/bin/external/llvm-project/mlir/_virtual_includes/BuiltinLocationAttributesIncGen -Ibazel-out/aarch64-opt/bin/external/llvm-project/mlir/_virtual_includes/BuiltinOpsIncGen -Ibazel-out/aarch64-opt/bin/external/llvm-project/mlir/_virtual_includes/BuiltinTypeInterfacesIncGen -Ibazel-out/aarch64-opt/bin/external/llvm-project/mlir/_virtual_includes/BuiltinTypesIncGen -Ibazel-out/aarch64-opt/bin/external/llvm-project/mlir/_virtual_includes/CallOpInterfacesIncGen -Ibazel-out/aarch64-opt/bin/external/llvm-project/mlir/_virtual_includes/CastOpInterfacesIncGen -Ibazel-out/aarch64-opt/bin/external/llvm-project/mlir/_virtual_includes/InferTypeOpInterfaceIncGen -Ibazel-out/aarch64-opt/bin/external/llvm-project/mlir/_virtual_includes/OpAsmInterfaceIncGen -Ibazel-out/aarch64-opt/bin/external/llvm-project/mlir/_virtual_includes/RegionKindInterfaceIncGen -Ibazel-out/aarch64-opt/bin/external/llvm-project/mlir/_virtual_includes/SideEffectInterfacesIncGen -Ibazel-out/aarch64-opt/bin/external/llvm-project/mlir/_virtual_includes/SubElementInterfacesIncGen -Ibazel-out/aarch64-opt/bin/external/llvm-project/mlir/_virtual_includes/SymbolInterfacesIncGen -Ibazel-out/aarch64-opt/bin/external/llvm-project/mlir/_virtual_includes/TensorEncodingIncGen -Ibazel-out/aarch64-opt/bin/external/llvm-project/mlir/_virtual_includes/ParserTokenKinds -Ibazel-out/aarch64-opt/bin/external/local_config_cuda/cuda/_virtual_includes/cuda_headers_virtual -Ibazel-out/aarch64-opt/bin/external/local_config_tensorrt/_virtual_includes/tensorrt_headers -Ibazel-out/aarch64-opt/bin/external/llvm-project/mlir/_virtual_includes/ControlFlowInterfacesIncGen -Ibazel-out/aarch64-opt/bin/external/llvm-project/mlir/_virtual_includes/DerivedAttributeOpInterfaceIncGen -Ibazel-out/aarch64-opt/bin/external/llvm-project/mlir/_virtual_includes/LoopLikeInterfaceIncGen -Ibazel-out/aarch64-opt/bin/external/llvm-project/mlir/_virtual_includes/StandardOpsIncGen -Ibazel-out/aarch64-opt/bin/external/llvm-project/mlir/_virtual_includes/VectorInterfacesIncGen -isystem external/llvm-project/llvm/include -isystem bazel-out/aarch64-opt/bin/external/llvm-project/llvm/include -isystem external/llvm-project/mlir/include -isystem bazel-out/aarch64-opt/bin/external/llvm-project/mlir/include -isystem external/nsync/public -isystem bazel-out/aarch64-opt/bin/external/nsync/public -isystem external/eigen_archive -isystem bazel-out/aarch64-opt/bin/external/eigen_archive -isystem external/gif -isystem bazel-out/aarch64-opt/bin/external/gif -isystem external/com_google_protobuf/src -isystem bazel-out/aarch64-opt/bin/external/com_google_protobuf/src -isystem external/farmhash_archive/src -isystem bazel-out/aarch64-opt/bin/external/farmhash_archive/src -isystem external/zlib -isystem bazel-out/aarch64-opt/bin/external/zlib -isystem external/local_config_cuda/cuda -isystem bazel-out/aarch64-opt/bin/external/local_config_cuda/cuda -isystem external/local_config_cuda/cuda/cuda/include -isystem bazel-out/aarch64-opt/bin/external/local_config_cuda/cuda/cuda/include -isystem external/double_conversion -isystem bazel-out/aarch64-opt/bin/external/double_conversion -isystem external/local_config_rocm/rocm -isystem bazel-out/aarch64-opt/bin/external/local_config_rocm/rocm -isystem external/local_config_rocm/rocm/rocm/include -isystem bazel-out/aarch64-opt/bin/external/local_config_rocm/rocm/rocm/include -isystem external/local_config_rocm/rocm/rocm/include/rocrand -isystem bazel-out/aarch64-opt/bin/external/local_config_rocm/rocm/rocm/include/rocrand -isystem external/local_config_rocm/rocm/rocm/include/roctracer -isystem bazel-out/aarch64-opt/bin/external/local_config_rocm/rocm/rocm/include/roctracer -Wno-builtin-macro-redefined '-D__DATE__="redacted"' '-D__TIMESTAMP__="redacted"' '-D__TIME__="redacted"' -fPIC -U_FORTIFY_SOURCE '-D_FORTIFY_SOURCE=1' -fstack-protector -Wall -fno-omit-frame-pointer -no-canonical-prefixes -fno-canonical-system-headers -DNDEBUG -g0 -O2 -ffunction-sections -fdata-sections -w -DAUTOLOAD_DYNAMIC_KERNELS '-std=c++14' -c tensorflow/compiler/mlir/tensorflow/ir/tf_ops.cc -o bazel-out/aarch64-opt/bin/tensorflow/compiler/mlir/tensorflow/_objs/tensorflow_ops/tf_ops.pic.o)
Execution platform: @local_execution_config_platform//:platform
aarch64-linux-gnu-gcc-7: internal compiler error: Killed (program cc1plus)
Please submit a full bug report,
with preprocessed source if appropriate.
See <file:///usr/share/doc/gcc-7/README.Bugs> for instructions.
Target //tensorflow/tools/pip_package:build_pip_package failed to build
INFO: Elapsed time: 53520.933s, Critical Path: 27882.90s
INFO: 5993 processes: 944 internal, 5049 local.
FAILED: Build did NOT complete successfully
And here’s my configuration
You have bazel 3.7.2- (@non-git) installed.
Please specify the location of python. [Default is /usr/bin/python3]: /usr/bin/python3.7
Found possible Python library paths:
  /usr/lib/python3/dist-packages
Please input the desired Python library path to use.  Default is [/usr/lib/python3/dist-packages]
Do you wish to build TensorFlow with ROCm support? [y/N]: n
No ROCm support will be enabled for TensorFlow.
Do you wish to build TensorFlow with CUDA support? [y/N]: y
CUDA support will be enabled for TensorFlow.
Do you wish to build TensorFlow with TensorRT support? [y/N]: y
TensorRT support will be enabled for TensorFlow.
Found CUDA 10.2 in:
    /usr/local/cuda-10.2/targets/aarch64-linux/lib
    /usr/local/cuda-10.2/targets/aarch64-linux/include
Found cuDNN 8 in:
    /usr/lib/aarch64-linux-gnu
    /usr/include
Found TensorRT 8 in:
    /usr/include/aarch64-linux-gnu
Please specify a list of comma-separated CUDA compute capabilities you want to build with.
You can find the compute capability of your device at: https://developer.nvidia.com/cuda-gpus. Each capability can be specified as "x.y" or "compute_xy" to include both virtual and binary GPU code, or as "sm_xy" to only include the binary code.
Please note that each additional compute capability significantly increases your build time and binary size, and that TensorFlow only supports compute capabilities >= 3.5 [Default is: 3.5,7.0]: 5.3
Do you want to use clang as CUDA compiler? [y/N]: n
nvcc will be used as CUDA compiler.
Please specify which gcc should be used by nvcc as the host compiler. [Default is /usr/bin/gcc]:
Please specify optimization flags to use during compilation when bazel option "--config=opt" is specified [Default is -Wno-sign-compare]:
Would you like to interactively configure ./WORKSPACE for Android builds? [y/N]: n
Not configuring the WORKSPACE for Android builds.
Preconfigured Bazel build configs. You can use any of the below by adding "--config=<>" to your build command. See .bazelrc for more details.
        --config=mkl            # Build with MKL support.
        --config=mkl_aarch64    # Build with oneDNN and Compute Library for the Arm Architecture (ACL).
        --config=monolithic     # Config for mostly static monolithic build.
        --config=numa           # Build with NUMA support.
        --config=dynamic_kernels        # (Experimental) Build kernels into separate shared objects.
        --config=v1             # Build with TensorFlow 1 API instead of TF 2 API.
Preconfigured Bazel build configs to DISABLE default on features:
        --config=nogcp          # Disable GCP support.
        --config=nonccl         # Disable NVIDIA NCCL support.
Configuration finished
And here’s my build command
bazel build --config=cuda --config=nonccl --verbose_failures //tensorflow/tools/pip_package:build_pip_package
Some says it was the compiler’s bug so I’ve tried with GCC 8.4 but I got another similar error
C++ compilation of rule '//tensorflow/compiler/mlir/hlo:hlo' failed (Exit 1): crosstool_wrapper_driver_is_not_gcc failed - Google Search
with addition it uses almost all of my 64GB EMMC
So, how to build Tensorflow 2.7 from the source for Python 3.7 in Jetson Nano?
Killed is usually caused by running out of memory.
Do you add enough swap space for Bazel to use?
Maybe you can also give clang a try.
