I have an issue with installing the GPU operator on nodes with enforced SELinux.
SELinux is enabled on the nodes, but disabled in containerd. As a result, the domains are not propagated to the containers. If we check the drivers’ directory on the node, the video folder is of type modules_object_t
(the type needed by kernel modules):
$ ls -Z /usr/lib/modules/5.19.9-200.fc36.x86_64/kernel/drivers
system_u:object_r:modules_object_t:s0 video
While on the pod (nvidia-driver-daemonset pods) the same folder is of type var_lib_t
$ ls -Z /usr/lib/modules/5.19.9-200.fc36.x86_64/kernel/drivers/
system_u:object_r:var_lib_t:s0 video
When trying to install the gpu-operator, the installation fails, and the error on the node is:
[ 5039.462792 audit: type=1400 audit(1684925801.740:1438): avc: denied { module_load } for pid=189114 comm="modprobe" path="/usr/lib/modules/5.19.9-200.fc36.x86_64/kernel/drivers/video/nvidia.ko" dev="overlay" ino=95506836 scontext=system_u:system_r:unconfined_service_t:s0 tcontext=system_u:object_r:var_lib_t:s0 tclass=system permissive=0
The error tells me that unconfined_service_t
is not allowed to do module_load
on type var_lib_t
. This is the expected behavior because modules_object_t
is needed to denote it is loadable. But because containerd is not propagating the types into the pods, I’m losing the modules_object_t
type on the drivers and cannot load them.
One easy fix is to create a policy: allow unconfined_service_t var_lib_t:system module_load
. This is better than running SELinux permissive but still gives more permissions than required. So I was wondering if there is some other way to solve this. Enabling SELinux on containerd is not an option.
If I run chcon -t modules_object_t /usr/lib/modules/5.19.9-200.fc36.x86_64/kernel/drivers/video
before nvidia-driver init
the installation succeeds, but there is no easy way to do this using values file.
Versions used:
- Kubernetes v1.25
- Fedora Core OS 36
- containerd 1.7.1
- gpu-operator 22.9.1
Any ideas would be highly appreciated.
Best regards, Diana.
