ERROR: NVIDIA driver is not loaded
I need help installing the GPU on my Linux Mint machine.
I’m pretty new to Linux but trying my best.
I’ve read through many other posts and have not had much luck yet.
I ran: sudo apt-get install nvidia-driver-550.
(nvidia-settings:4302): GLib-GObject-CRITICAL **: 16:21:42.663: g_object_unref: assertion 'G_IS_OBJECT (object)' failed
** (nvidia-settings:4302): CRITICAL **: 16:21:42.664: ctk_powermode_new: assertion '(ctrl_target != NULL) && (ctrl_target->h != NULL)' failed
ERROR: nvidia-settings could not find the registry key file or the X server is
       not accessible. This file should have been installed along with this
       driver at
       /usr/share/nvidia/nvidia-application-profiles-key-documentation. The
       application profiles will continue to work, but values cannot be
       prepopulated or validated, and will not be listed in the help text.
       Please see the README for possible values and descriptions.
More Info:
$ lspci -v | grep VGA
00:02.0 VGA compatible controller: Intel Corporation RocketLake-S GT1 [UHD Graphics P750] (rev 04) (prog-if 00 [VGA controller])
01:00.0 VGA compatible controller: NVIDIA Corporation GP106GL [Quadro P2200] (rev a1) (prog-if 00 [VGA controller])
ubuntu-drivers devices
== /sys/devices/pci0000:00/0000:00:01.0/0000:01:00.0 ==
modalias :
pci:v000010DEd00001C31sv00001028sd0000131Bbc03sc00i00
vendor   : NVIDIA Corporation
model    : GP106GL [Quadro P2200]
driver   : nvidia-driver-535 - distro non-free
driver   : nvidia-driver-470 - distro non-free
driver   : nvidia-driver-470-server - distro non-free
driver   : nvidia-driver-550 - distro non-free recommended
driver   : nvidia-driver-450-server - distro non-free
driver   : nvidia-driver-535-server - distro non-free
driver   : nvidia-driver-545 - distro non-free
driver   : nvidia-driver-418-server - distro non-free
driver   : xserver-xorg-video-nouveau - distro free builtin
$ dpkg -l |grep nvidia
ii  libnvidia-cfg1-550:amd64                   550.120-0ubuntu0.22.04.1                   amd64        NVIDIA binary OpenGL/GLX configuration library
ii  libnvidia-common-550                       550.120-0ubuntu0.22.04.1                   all          Shared files used by the NVIDIA libraries
rc  libnvidia-compute-535:amd64                535.183.01-0ubuntu0.22.04.1                amd64        NVIDIA libcompute package
ii  libnvidia-compute-550:amd64                550.120-0ubuntu0.22.04.1                   amd64        NVIDIA libcompute package
ii  libnvidia-compute-550:i386                 550.120-0ubuntu0.22.04.1                   i386         NVIDIA libcompute package
ii  libnvidia-decode-550:amd64                 550.120-0ubuntu0.22.04.1                   amd64        NVIDIA Video Decoding runtime libraries
ii  libnvidia-decode-550:i386                  550.120-0ubuntu0.22.04.1                   i386         NVIDIA Video Decoding runtime libraries
ii  libnvidia-egl-wayland1:amd64               1:1.1.9-1.1ubuntu0.1                       amd64        Wayland EGL External Platform library -- shared library
ii  libnvidia-egl-wayland1:i386                1:1.1.9-1.1ubuntu0.1                       i386         Wayland EGL External Platform library -- shared library
ii  libnvidia-encode-550:amd64                 550.120-0ubuntu0.22.04.1                   amd64        NVENC Video Encoding runtime library
ii  libnvidia-encode-550:i386                  550.120-0ubuntu0.22.04.1                   i386         NVENC Video Encoding runtime library
ii  libnvidia-extra-550:amd64                  550.120-0ubuntu0.22.04.1                   amd64        Extra libraries for the NVIDIA driver
ii  libnvidia-fbc1-550:amd64                   550.120-0ubuntu0.22.04.1                   amd64        NVIDIA OpenGL-based Framebuffer Capture runtime library
ii  libnvidia-fbc1-550:i386                    550.120-0ubuntu0.22.04.1                   i386         NVIDIA OpenGL-based Framebuffer Capture runtime library
ii  libnvidia-gl-550:amd64                     550.120-0ubuntu0.22.04.1                   amd64        NVIDIA OpenGL/GLX/EGL/GLES GLVND libraries and Vulkan ICD
ii  libnvidia-gl-550:i386                      550.120-0ubuntu0.22.04.1                   i386         NVIDIA OpenGL/GLX/EGL/GLES GLVND libraries and Vulkan ICD
ii  libnvidia-ml-dev:amd64                     11.5.50~11.5.1-1ubuntu1                    amd64        NVIDIA Management Library (NVML) development files
rc  nvidia-compute-utils-535                   535.183.01-0ubuntu0.22.04.1                amd64        NVIDIA compute utilities
ii  nvidia-compute-utils-550                   550.120-0ubuntu0.22.04.1                   amd64        NVIDIA compute utilities
ii  nvidia-cuda-dev:amd64                      11.5.1-1ubuntu1                            amd64        NVIDIA CUDA development files
ii  nvidia-cuda-gdb                            11.5.114~11.5.1-1ubuntu1                   amd64        NVIDIA CUDA Debugger (GDB)
ii  nvidia-cuda-toolkit                        11.5.1-1ubuntu1                            amd64        NVIDIA CUDA development toolkit
ii  nvidia-cuda-toolkit-doc                    11.5.1-1ubuntu1                            all          NVIDIA CUDA and OpenCL documentation
rc  nvidia-dkms-535                            535.183.01-0ubuntu0.22.04.1                amd64        NVIDIA DKMS package
ii  nvidia-dkms-550                            550.120-0ubuntu0.22.04.1                   amd64        NVIDIA DKMS package
ii  nvidia-driver-550                          550.120-0ubuntu0.22.04.1                   amd64        NVIDIA driver metapackage
ii  nvidia-firmware-535-535.183.01             535.183.01-0ubuntu0.22.04.1                amd64        Firmware files used by the kernel module
ii  nvidia-firmware-550-550.120                550.120-0ubuntu0.22.04.1                   amd64        Firmware files used by the kernel module
rc  nvidia-kernel-common-535                   535.183.01-0ubuntu0.22.04.1                amd64        Shared files used with the kernel module
ii  nvidia-kernel-common-550                   550.120-0ubuntu0.22.04.1                   amd64        Shared files used with the kernel module
ii  nvidia-kernel-source-550                   550.120-0ubuntu0.22.04.1                   amd64        NVIDIA kernel source package
ii  nvidia-opencl-dev:amd64                    11.5.1-1ubuntu1                            amd64        NVIDIA OpenCL development files
ii  nvidia-prime                               0.8.17.1                                   all          Tools to enable NVIDIA's Prime
ii  nvidia-prime-applet                        1.3.9                                      all          An applet for NVIDIA Prime
ii  nvidia-profiler                            11.5.114~11.5.1-1ubuntu1                   amd64        NVIDIA Profiler for CUDA and OpenCL
ii  nvidia-settings                            510.47.03-0ubuntu1                         amd64        Tool for configuring the NVIDIA graphics driver
ii  nvidia-utils-550                           550.120-0ubuntu0.22.04.1                   amd64        NVIDIA driver support binaries
ii  nvidia-visual-profiler                     11.5.114~11.5.1-1ubuntu1                   amd64        NVIDIA Visual Profiler for CUDA and OpenCL
ii  screen-resolution-extra                    0.18.2                                     all          Extension for the nvidia-settings control panel
ii  xserver-xorg-video-nvidia-550              550.120-0ubuntu0.22.04.1                   amd64        NVIDIA binary Xorg driver
