Thanks a lot for your patience.
It turns out that the nvcr.io/nvidia/tritonserver container does work well on JetPack 5.
Please see below for the testing.
Server: tritonserver:24.02-py3-igpu
$ git clone -b r24.02 https://github.com/triton-inference-server/server.git
$ cd server/docs/examples/
$ ./fetch_models.sh
$ sudo docker run -it --rm --runtime nvidia --network host -v ${PWD}/model_repository:/models nvcr.io/nvidia/tritonserver:24.02-py3-igpu tritonserver --model-repository=/models
You should see the backend and model logs like below:
I0327 04:32:46.516401 1 server.cc:634]
| Backend | Path | Config |
| tensorflow | /opt/tritonserver/backends/tensorflow/libtriton_tensorflow.so | {"cmdline":{"auto-complete-config":"true","backend-directory":"/opt/tritonserver/backends","min-compute-capability":"5.300000", |
| | | "default-max-batch-size":"4"}} |
| onnxruntime | /opt/tritonserver/backends/onnxruntime/libtriton_onnxruntime.so | {"cmdline":{"auto-complete-config":"true","backend-directory":"/opt/tritonserver/backends","min-compute-capability":"5.300000", |
I0327 04:32:46.516911 1 server.cc:677]
| Model | Version | Status |
| densenet_onnx | 1 | READY |
| inception_graphdef | 1 | READY |
| simple | 1 | READY |
| simple_dyna_sequence | 1 | READY |
| simple_identity | 1 | READY |
| simple_int8 | 1 | READY |
| simple_sequence | 1 | READY |
| simple_string | 1 | READY |
Client: tritonserver:24.02-py3-igpu-sdk
You should be able to see the detection output by sending a query like below.
We test this on another XavierNX but it should be okay to run on the same device.
$ sudo docker run -it --rm --runtime nvidia --network host nvcr.io/nvidia/tritonserver:24.02-py3-igpu-sdk
# /workspace/install/bin/image_client -u [IP]:8000 -m densenet_onnx -c 3 -s INCEPTION /workspace/images/mug.jpg
Request 0, batch size 1
Image '/workspace/images/mug.jpg':
15.349564 (504) = COFFEE MUG
13.227465 (968) = CUP
10.424894 (505) = COFFEEPOT
