Triton container is based on Ubuntu 20.04, all the others are based on Ubuntu 18.04
GPU
• DeepStream Version
6.0
• TensorRT Version
8.0.1
470.74
Question
Deepstream 6 containers on NGC are all based on Ubuntu 18.04, except for the -triton container which is based on Ubuntu 20.04. Is this intended? In DeepStream 5.1 we built our binary using the -devel container and then copied the application across to -base and -triton. This can no longer be done because -triton is based on 20.04. Any reason why all the containers aren’t based on 20.04?
Sorry for the late response, will confirm with dev team to get back to you.
How get this conclusion? In my check, it’s also UBuntu 18.04 as below
$ docker run --gpus all -it --rm -v /tmp/.X11-unix:/tmp/.X11-unix -v /Datadiska/$user/:/Datadiska/$user/ -e DISPLAY=$DISPLAY -w /opt/nvidia/deepstream/deepstream --privileged nvcr.io/nvidia/deepstream:6.0-triton
root@805d45c17911:/opt/nvidia/deepstream/deepstream-6.0# uname -a
Linux 805d45c17911 5.4.0-90-generic #101~18.04.1-Ubuntu SMP Fri Oct 22 09:25:04 UTC 2021 x86_64 x86_64 x86_64 GNU/Linux
$ docker run --rm -it nvcr.io/nvidia/deepstream:6.0-triton
   DeepStreamSDK 6.0.0
*** LICENSE AGREEMENT ***
By using this software you agree to fully comply with the terms and conditions
of the License Agreement. The License Agreement is located at
/opt/nvidia/deepstream/deepstream/LicenseAgreement.pdf. If you do not agree
to the terms and conditions of the License Agreement do not use the software.
== Triton Inference Server ==
NVIDIA Release 21.08 (build 26170506)
Copyright (c) 2018-2021, NVIDIA CORPORATION & AFFILIATES.  All rights reserved.
Various files include modifications (c) NVIDIA CORPORATION.  All rights reserved.
This container image and its contents are governed by the NVIDIA Deep Learning Container License.
By pulling and using the container, you accept the terms and conditions of this license:
https://developer.nvidia.com/ngc/nvidia-deep-learning-container-license
find: File system loop detected; '/usr/bin/X11' is part of the same file system loop as '/usr/bin'.
WARNING: The NVIDIA Driver was not detected.  GPU functionality will not be available.
   Use Docker with NVIDIA Container Toolkit to start this container; see
   https://github.com/NVIDIA/nvidia-docker.
root@8c9ce9772542:/opt/nvidia/deepstream/deepstream-6.0# uname -a
Linux 8c9ce9772542 5.11.0-38-generic #42~20.04.1-Ubuntu SMP Tue Sep 28 20:41:07 UTC 2021 x86_64 x86_64 x86_64 GNU/Linux
$ docker image inspect nvcr.io/nvidia/deepstream:6.0-triton
        "Id": "sha256:6e629647efbab6672b27c79b74b2048dde6e7411614aba7f38b9fbc0097f0bb7",
        "RepoTags": [
            "nvcr.io/nvidia/deepstream:6.0-triton"
        "RepoDigests": [
            "nvcr.io/nvidia/deepstream@sha256:95e7118d37a95830d7c9e85d16509c405af5ce178dce11189ad726bc7ff869fd"
        "Parent": "",
        "Comment": "",
        "Created": "2021-10-05T21:44:13.422543019Z",
        "Container": "d54594b8fa7f41aa2a766426a2ad1116aca0bf9342d5e2fac3ef056e65fa239e",
        "ContainerConfig": {
            "Hostname": "193d21fdca68",
            "Domainname": "",
            "User": "",
            "AttachStdin": false,
            "AttachStdout": false,
            "AttachStderr": false,
            "Tty": true,
            "OpenStdin": false,
            "StdinOnce": false,
            "Env": [
                "TAG=gmc1",
                "PLATFORM=x86_64",
                "DS_REL_PKG=deepstream_sdk_v6.0.0_x86_64.tbz2",
                "DS_REL_PKG_DIR=deepstream_sdk_v6.0.0_x86_64",
                "DS_VERSION=6.0.0",
                "PATH=/opt/tritonserver/bin:/usr/local/mpi/bin:/usr/local/nvidia/bin:/usr/local/cuda/bin:/usr/local/sbin:/usr/local/bin:/usr/sbin:/usr/bin:/sbin:/bin:/usr/local/ucx/bin",
                "CUDA_VERSION=11.4.1.004",
                "CUDA_DRIVER_VERSION=470.57.02",
                "CUDA_CACHE_DISABLE=1",
                "_CUDA_COMPAT_PATH=/usr/local/cuda/compat",
                "ENV=/etc/shinit_v2",
                "BASH_ENV=/etc/bash.bashrc",
                "NVIDIA_REQUIRE_CUDA=cuda>=9.0",
                "NCCL_VERSION=2.10.3",
                "CUBLAS_VERSION=11.5.4.8",
                "CUFFT_VERSION=10.5.1.100",
                "CURAND_VERSION=10.2.5.100",
                "CUSPARSE_VERSION=11.6.0.100",
                "CUSOLVER_VERSION=11.2.0.100",
                "NPP_VERSION=11.4.0.90",
                "NVJPEG_VERSION=11.5.2.100",
                "CUDNN_VERSION=8.2.2.26",
                "TRT_VERSION=8.0.1.6+cuda11.3.1.005",
                "TRTOSS_VERSION=21.08",
                "NSIGHT_SYSTEMS_VERSION=2021.2.4.12",
                "NSIGHT_COMPUTE_VERSION=2021.2.1.2",
                "DALI_VERSION=1.4.0",
                "DALI_BUILD=2575285",
                "DLPROF_VERSION=21.08",
                "LD_LIBRARY_PATH=/opt/tritonserver/lib:/usr/src/tensorrt/lib:/opt/riva/lib:/usr/local/cuda/compat/lib:/usr/local/nvidia/lib:/usr/local/nvidia/lib64",
                "NVIDIA_VISIBLE_DEVICES=all",
                "NVIDIA_DRIVER_CAPABILITIES=compute,utility,video,video,graphics",
                "GDRCOPY_VERSION=2.2",
                "HPCX_VERSION=2.9.0",
                "MOFED_VERSION=5.4-rdmacore36.0",
                "OPENUCX_VERSION=1.11.0-rc1",
                "OPENMPI_VERSION=4.1.1",
                "RDMACORE_VERSION=36.0",
                "OPAL_PREFIX=/opt/hpcx/ompi",
                "LIBRARY_PATH=/usr/local/cuda/lib64/stubs:",
                "TRITON_SERVER_VERSION=2.13.0",
                "NVIDIA_TRITON_SERVER_VERSION=21.08",
                "TF_ADJUST_HUE_FUSED=1",
                "TF_ADJUST_SATURATION_FUSED=1",
                "TF_ENABLE_WINOGRAD_NONFUSED=1",
                "TF_AUTOTUNE_THRESHOLD=2",
                "TRITON_SERVER_USER=triton-server",
                "DEBIAN_FRONTEND=noninteractive",
                "DCGM_VERSION=2.2.8",
                "NVIDIA_BUILD_ID=26170506",
                "LD_PRELOAD=/usr/lib/x86_64-linux-gnu/libgstbadvideo-1.0.so.0"
            "Cmd": [
                "/bin/sh",
                "-c",
                "rm -rf /root/tmp"
            "Image": "sha256:a9527802c2aa5ac446ccd3bf51f801d333dfd407c4334f472598b96de0d210d3",
            "Volumes": null,
            "WorkingDir": "/opt/nvidia/deepstream/deepstream-6.0",
            "Entrypoint": null,
            "OnBuild": null,
            "Labels": {
                "com.amazonaws.sagemaker.capabilities.accept-bind-to-port": "true",
                "com.nvidia.build.id": "26170506",
                "com.nvidia.build.ref": "f6fcdaaf639ec6854418a9bf6dd40187e3be3514",
                "com.nvidia.cublas.version": "11.5.4.8",
                "com.nvidia.cuda.version": "9.0",
                "com.nvidia.cudnn.version": "8.2.2.26",
                "com.nvidia.cufft.version": "10.5.1.100",
                "com.nvidia.curand.version": "10.2.5.100",
                "com.nvidia.cusolver.version": "11.2.0.100",
                "com.nvidia.cusparse.version": "11.6.0.100",
                "com.nvidia.nccl.version": "2.10.3",
                "com.nvidia.npp.version": "11.4.0.90",
                "com.nvidia.nsightcompute.version": "2021.2.1.2",
                "com.nvidia.nsightsystems.version": "2021.2.4.12",
                "com.nvidia.nvjpeg.version": "11.5.2.100",
                "com.nvidia.tensorrt.version": "8.0.1.6+cuda11.3.1.005",
                "com.nvidia.tensorrtoss.version": "21.08",
                "com.nvidia.tritonserver.version": "2.13.0",
                "com.nvidia.volumes.needed": "nvidia_driver"
        "DockerVersion": "19.03.5",
        "Author": "",
        "Config": {
            "Domainname": "",
            "User": "",
            "Tty": true,
            "OpenStdin": false,
            "StdinOnce": false,
            "Env": [
                "TAG=gmc1",
                "PLATFORM=x86_64",
                "DS_VERSION=6.0.0",
            "Cmd": null,
            "Volumes": null,
            "Entrypoint": [
                "/opt/nvidia/deepstream/deepstream-6.0/entrypoint.sh"
            "OnBuild": null,
            "Labels": {
        "Architecture": "amd64",
        "Os": "linux",
        "Size": 17475940595,
        "VirtualSize": 17475940595,
        "GraphDriver": {
            "Data": {
                "LowerDir": "/var/lib/docker/overlay2/339d9e7f68ddab8d96e947b5e8bb317a7b59a733293c7a7092eb676514061ddf/diff:/var/lib/docker/overlay2/c3a6dbf445b1e1528e6bac7ebaf6928d0762c9837ea528acd51ca9996e693360/diff:/var/lib/docker/overlay2/75f0768a0fbb52836b95958b34809b2acfe06d1f1c898d1597fffe70ab1e85b4/diff:/var/lib/docker/overlay2/e1c576342d028fcfad9729e860c6e04c2636cec659610c3c0f30fdb44299ad0c/diff:/var/lib/docker/overlay2/a5ed11cbd6c664cbdc18b063f6c98c824beead44887ad9766e4f1aa14510132a/diff:/var/lib/docker/overlay2/adcd616e7ba3ca4008dde331859cf677118f61533c2487b5c08145505b98fdcb/diff:/var/lib/docker/overlay2/cccb395956eb7485423af62439160e05ecad87dfc09d426ccbd0427fd9ad47d7/diff:/var/lib/docker/overlay2/96691a787b007b1cd29cc15e232fcb9659975665c9062af863a0c08cf5a8725b/diff:/var/lib/docker/overlay2/c56a0c13e26bdb3a30d1b4ddcee2b8b0ade268755110373b403950f88926e297/diff:/var/lib/docker/overlay2/658abf8fae3e37a214a5bd8ae50f3afe16bc7e4a03ab26f02e1d01178811d89f/diff:/var/lib/docker/overlay2/788d3046f09b626c22f21029723c5fb87d678d97b4448dbc05fe01d0f9f32fe6/diff:/var/lib/docker/overlay2/246bedd54309c540bf19d82856a32de8f72a35e76a73f862a95d20580fb863dc/diff:/var/lib/docker/overlay2/ce356e7ef449212af0920fe70f400cbc647e304e08a7b39296d71d5d703e4901/diff:/var/lib/docker/overlay2/951b2155ee556c77328fb761972f54044843de77b5dfa074dc31820d95d22ff3/diff:/var/lib/docker/overlay2/0d52233e97482a65560203f2755717e00259e2497847863cc268e90cc9dee910/diff:/var/lib/docker/overlay2/099c2c4a4d70dca5eec0c538a75ffa0dcc947801b2e5f84a8115645a7a615d4a/diff:/var/lib/docker/overlay2/425f756fc0ba51be5c6ec43ba402dfb53de73f200b996756d321497537f9ef03/diff:/var/lib/docker/overlay2/69f9b25bc35bbb1d84c4bc8da2acb26928d6d874f106314df5718a6632a01268/diff:/var/lib/docker/overlay2/eb6ce76c003485df7eb8033fc5105883f38b7a38d91e47fe7a1d49d2ecf61f84/diff:/var/lib/docker/overlay2/5bed50869905cf7bb11b58f90cbeab558254893a3c799abe7f17857b6378dff6/diff:/var/lib/docker/overlay2/a092da1c16621aaacf39d7a77c939007b5b6747be0e14a3b3572bdb54b953245/diff:/var/lib/docker/overlay2/097e5596fbcce6547ef6b1ff6703c9d20a77852b90f557517605457f86a6854b/diff:/var/lib/docker/overlay2/771547d2a538774d35dbe24bd63bfd978357c7fc73c508bb281f54e58d340fa6/diff:/var/lib/docker/overlay2/b237d2f6e9cf06282e3ba3db64abb67f7ddb973c44f9544b2f0610b4a3dcc0bd/diff:/var/lib/docker/overlay2/cdbf98bb41e24c9459431fd6eb1e8cca700c0dab11887c0aecea7e1146d72886/diff:/var/lib/docker/overlay2/13815cd80a6b8d7a62768dc78820ecb2a9df74337346928b09bc9bb7dc26d049/diff:/var/lib/docker/overlay2/af570363f794a0110f260fc64f8315421503d815ab79818aed7b8dba34a58be3/diff:/var/lib/docker/overlay2/a96a17450f5c1f02f4e73937de3cf84b022a31e2237c364f31deaf9d62e4df1b/diff:/var/lib/docker/overlay2/9c872c6564183df63ffb41498e4a31a5b7102615b9b0e8d07123b6993168d208/diff:/var/lib/docker/overlay2/df164edec0086bed41a88b1e70e00d5eb11ba7ce7a39622be97032fdc92eec83/diff:/var/lib/docker/overlay2/0934bdd9c9a3ec56ea6bbe6adb0963338f565199191b21eb3bd57b07ea88a9d2/diff:/var/lib/docker/overlay2/0a216246fb4adae02f5c9c9e01ea0a873a8ccb8484c7351a1070b21fdddce694/diff:/var/lib/docker/overlay2/d080bde7b081cb22ee01ec584c39d2ccf989620bd485db4c6db0cdb782bdcbb4/diff:/var/lib/docker/overlay2/d9f0eefb92cda5162db7f61e6430168cbadf5e0e9546c5003485036ed8bc8a13/diff:/var/lib/docker/overlay2/3fd82c5744b903d866461968c9e359ee5e4e21a78e345e49c2c87222846b6aae/diff:/var/lib/docker/overlay2/bffbaecfd83d20617e85cb9177a5e679e60eb914b164e8d7ba8dc8df21c6c014/diff:/var/lib/docker/overlay2/16572ab5d46e0abbdee41dd91eaceba5a6f32cf99208228df57bce45840d0ed4/diff:/var/lib/docker/overlay2/8f11aefd552407d87767fe51456d2048e9d38f10e2d1ac7ca91a1e79e0396283/diff:/var/lib/docker/overlay2/ff879730917e1b2523c868e54bdf74b2fea453e36f71940814e8ede3ee54e033/diff:/var/lib/docker/overlay2/f4ad73bc9a2718d25d7dc8d63b0bfd1a4f5ed2a62c860ac77c5aedcc307117a4/diff:/var/lib/docker/overlay2/376a04c6c029c16bd20ea237bc2ef6ae0fe8a7ba5593619780d755bb6d0b96bd/diff:/var/lib/docker/overlay2/aa02edac80fb1e47f5f2bd436c5a7416188f799485ce3bdbfe4cc5293fae1a8a/diff:/var/lib/docker/overlay2/087ac85604c3d3ff1f560def8288fc170f1ae768ef3283c933bab1419998d730/diff:/var/lib/docker/overlay2/371b1587ddd8c312d4a03b85a09b1a119b3e842915719cda0c303f418f500224/diff:/var/lib/docker/overlay2/069ebc7ebb0409c934be006037ca4e81bfce9f935420cec999d10dad5ccf29bc/diff:/var/lib/docker/overlay2/51534061b08983517aeebbf61108ce510303223cfb8614eb3bdc471ec9151d3c/diff:/var/lib/docker/overlay2/261e561d07751fe87017e44b2d91800af461cf54d94cd36b4317c3a6e49c5a20/diff:/var/lib/docker/overlay2/732752fe46b6abd5f7b1417ea5cc8c97a95e8992e58c6f5d7da9e6c8e04ea8e2/diff:/var/lib/docker/overlay2/6b6ab2943c6d97da57005ca8d2d0284938bf822bcce93ed2b62e3153f8e78255/diff:/var/lib/docker/overlay2/47401c23fab326a688fff031db12f1586d0fe5c90be77fe9036eb5e06de361fd/diff:/var/lib/docker/overlay2/bf950faa56c134afcfa24225550e81c2cd2b9aced88e2786caecba82ab55ba92/diff:/var/lib/docker/overlay2/de8eb63db1660ce26f3326b79a1c268949a31fb0757e735e5a5f770c0a937328/diff:/var/lib/docker/overlay2/2707bd0f65cb49ae38d260ce27d62d596f5511867a68a37d9190ee3dbbaa68f5/diff:/var/lib/docker/overlay2/de564a78a1f6a3450a22b48ed0389d3ca18dd1f57ebf88a2e88cc36f1f6f0ac5/diff:/var/lib/docker/overlay2/9deac9285f79c7dedf7d21db20b917a9bbf765fdaba3ca729a7a2bd53ebd9264/diff:/var/lib/docker/overlay2/1b5f1046385b92d0bf0d84a1d63aee374355154cf17639438f9b49c2b0d67aa7/diff",
                "MergedDir": "/var/lib/docker/overlay2/7376b087b493f40e76bb9304d8bd15599dad21cae1a0e62a2c1ad5150cf08a93/merged",
                "UpperDir": "/var/lib/docker/overlay2/7376b087b493f40e76bb9304d8bd15599dad21cae1a0e62a2c1ad5150cf08a93/diff",
                "WorkDir": "/var/lib/docker/overlay2/7376b087b493f40e76bb9304d8bd15599dad21cae1a0e62a2c1ad5150cf08a93/work"
            "Name": "overlay2"
        "RootFS": {
            "Type": "layers",
            "Layers": [
                "sha256:7555a8182c42c7737a384cfe03a3c7329f646a3bf389c4bcd75379fc85e6c144",
                "sha256:780a3582aff483c37ab552c1adcd9555f1158ffaf9abbb05ed474fd14b0b5389",
                "sha256:897b016c57cae7a21616a4e8b455b683e86aaa9caf68d235339c98c7492a7937",
                "sha256:e245110f4cd5f4d92f2bed802d77966d515e44308e057a6871ca12a8210c3ee5",
                "sha256:d9230c3208a1e675742648a6fffbbc637f90f94ec7c3c90949bc0901fd69c135",
                "sha256:c4ac0de61e502411caa1d6caf05d36f4ec722cc3fcf2428d5386687e0d193ae7",
                "sha256:df45adac04fd307b9eae48a281ad942c549a54c34bd0ade2ed4d046b46151360",
                "sha256:8a86dcb942a08417e706c3040f2183bb6613432da0eace2b44a13812c196f65f",
                "sha256:4938aec16cb1c054907ff874a9cef148aa770b3eee5bd13165f8a5aa934cb4ee",
                "sha256:41db41c49a2e23e808b87533dbe3ee72de56b50c64005045d6984b616362ce6e",
                "sha256:93576ce8634c86918bd900c68c9cb1075edc530dc4df08b6f61a54f8f6ec9ec2",
                "sha256:1a62730e0411097377b4c34031c4570b728e8912ecafcdbc7d6f84f904735048",
                "sha256:103ab0c22213ae5b37fb12744ceabc80680fc7ed86ce379ea6372101376a4505",
                "sha256:13e7314b42017effc4aad5f0f0f5807bfa3b5072cdce08dc39dd9c79c2b96f75",
                "sha256:6223e500896d395a29393190e513fcf76cbdf8d3d99dcd465135857be799668b",
                "sha256:c91a873344760722e0427ffa8408bbccea6ef80cd298ab8c8dd47b4167fbcb10",
                "sha256:4246ff7d95068ae47cdc1d75209b3e5100ac6e0a097b65e18c4111a092352f5a",
                "sha256:d627d760bedf5c9541b440db0a32bf3c760a12a37405269f35d530cb218bec82",
                "sha256:0a707fb87820a9e2481b6e72a3cb62ce84fe60cf160ca7afa6560ee7705a91f5",
                "sha256:d9c26ffe1c13e21c623accf7e48d414b73dcf7fcae83915e6be4524d532a6386",
                "sha256:a632acaf3f4714ce3e3a2cadbdd103cbb480cdd4ddf09185010479b2b3dabb51",
                "sha256:75f761d90f3b4ce990e6e0a60f1b2606608d2cd6fc67bbff86ae205e41bf1cd7",
                "sha256:8c3d0202c849e1218343afe9c26aa44fc8937e3d0aa90b4cc48a3079c1cd9f7b",
                "sha256:efe476b56e19d5f3f5dfa486ca39f6e80b8065c90fa370d83ca080d1318dc3ce",
                "sha256:5d78ea11498750ad024f358635a38875ddcfac10e5769c0a12a4d34f93116a67",
                "sha256:157df127b62d566a64a59827ed86741f1c89ad4ce688b8cd21d90ea465c38ecf",
                "sha256:8e5c3199c79385484c93c87cc97de220208f7829008e2599f8036d04c5c384a6",
                "sha256:aea2828848609efb8dfd010f00e6bb3b458c0191d44c69b4f78b502fa4f7c5c9",
                "sha256:f6008eeed90a531a220619cc2cd1d1ffa4c3646b16bfd22f77f1bb14159dbd3e",
                "sha256:56cb87b3d0404ef6653264c49e6b41f7b77673a33b8a463bdab86dee55453ab2",
                "sha256:fc7ff3f6e8d8b60f4f6314804ecde55b9fca192723c0e8fca22775084df9ee5d",
                "sha256:09e531a310e6ddbc651718c0a984f12f302e2e9856671df48124990c110de282",
                "sha256:810f6f9223b0c5695c9395dadd1a75a46133c0fdeb03e6884bb386e159d77ac3",
                "sha256:1bba676a1b60b1040fd7ed9bcedde6c7f17947c0bac1e30606a25044bdc0fcd8",
                "sha256:6d820c3932fb174e78e1181039260c6c3cf9b4071366f25aeafddc21442fceb4",
                "sha256:4b047b532d188d7b7aaadde71ca5fee4911fd664ac9a5b556cbf54ec7784e8f2",
                "sha256:0abe86316da830a776b4cb7c565f7c3b7ba4a5d637a8f3ef48df4c92b58059f4",
                "sha256:28c5b0270c92ae7bc68c766790c0d4d4a56fd3917f21266f77332dad1240267f",
                "sha256:4042a51ce7c5ff4b17ed2d70f432c1d30d56d451d8869fe257b63117ab77ca16",
                "sha256:6ca760c5ef28ca14a198777e80c18936052a57163245caaaf4eef238c095ff96",
                "sha256:863259632f15ca07a154eade6a5570f8f7ed02512e15531e229b5cdec097eaa1",
                "sha256:66a9553c9b831959ce57a8eb208bdaadd67fa618ba8b76e86e4a43ee5b22a600",
                "sha256:d021e7ea86c3e42b78fccc595a253a396c45c601747903be081026d820767fda",
                "sha256:b34acc6aaa91422b6eae042865443544fc0ee796b1c72d5d68147e8b9a1957b0",
                "sha256:da0aa19014592337bcba3c744a5242d3b932768d75b2aeb9e27a41d3fd3dc88d",
                "sha256:6fdbe4e13cd73d761599b65f922cfe7b972cbc435945cd3a5b86cac4a77f8306",
                "sha256:08634a4031b2c5caa0e8d2ac9775942e3672664d20f9a6071e7a640aeefc742d",
                "sha256:3a6cabf5e95212920108eee9210649895c5253dc7a05521b6ee8deeb4292b32e",
                "sha256:77672058fd591c7f0b89fcdc6113e992caf170f931efc2d7d5c4f156e456b49e",
                "sha256:bd351827edeb9cae4508dec509024d3c39a2f7f002c5b91e5d4e04f5fbe6649f",
                "sha256:90ae1dd6e444171872388f41b68c63f9cbd58cb4d58bf5c62aca1911d4023da4",
                "sha256:6b06decdd344c77cdc9b26a6c903ed66fe55ea0603afcd3de19c8be51d03990b",
                "sha256:710277152ab413c4ec73b32397e72478b10dd62a1a993aa7a6a1c51bf8c37a07",
                "sha256:42bccec04e71ead34b7b9ea608bacfcc23b19a08c117d66489fa178affd7799e",
                "sha256:a72939f92b71abbca0ac2d8fb0d158317dcaa1d4a20557c35c598ab22e813e1b",
                "sha256:80c1ba16fbcf74bd63020933c3683adabd656f61cb39f9dc7f5706af29355b5a",
                "sha256:8804d8288b1fc7f56557785cdfa9705671962235be7c3992853489be1ce65b32"
        "Metadata": {
            "LastTagTime": "0001-01-01T00:00:00Z"
Note: my host OS is 20.04.
Yes. DS 6.0 Triton container is based on UBuntu 20.04. We need to check docker ubuntu version by “cat /etc/lsb-release” instaed of uname since uname is to get the version number form the host kernel
DS6.0GA is using Triton 21.08 (Release Notes :: NVIDIA Deep Learning Triton Inference Server Documentation), which is released on UBuntu 20.04, so DS6.0GA leverages its UBuntu version.
Look forward to base DeepStream container also being based on 20.04 which would mean we can start using C++17.
Yes, under planning… will have in future release.
