i am trying to install DOCA via CLI. I run the following command:
sdkmanager --cli install --logintype devzone --product DOCA --host --targetos Linux --version 1.1 --target BLUEFIELD2_DPU_TARGETS --deselect ‘BlueField OS’ --select ‘DOCA Components’ --flash all
I continue with the installation until this error appears.
│info: Some packages could not be installed. This may mean that you have
│info: requested an impossible situation or if you are using the unstable
│info: distribution that some required packages have not yet been created
│info: or been moved out of Incoming.
│info: The following information may help to resolve the situation:
│info:
│info: The following packages have unmet dependencies:
│info: doca-sdk : Depends: libvma-dev (= 9.3.1-1) but
│info: doca-sdk : Depends: libvma-dev (= 9.3.1-1) but it is not going to be installed
│info: Depends: doca-dpi-devel (= 1.1.024-1) but it is not going to be installed
│error: E: Unable to correct problems, you have held broken packages.
│info: [ Package Install Finished with Error ]
│info: [host] [ 81.05 MB used. Disk Avail: 254.55 GB ]
│info: [ NV_DOCA_SDK_HOST_COMP Install took 11s ]
│error: [error]: Error when apt install failed; [exec_command]: sudo apt-get update; sleep 0.5; sudo apt-get -y install doca-sdk=1.1-0* ; [error]: exit status 100; [deb_path]: /home/name/Downloads/nvidia/ │
│sdkm_downloads/doca-repo-ubuntu1804_1.1-0.1.7.1.1.024.5.4.1.0.3.0_amd64.deb
│info:
│error: command terminated with error
│info: APT system is broken and requires manual fix
│info: Depends on failed component
│info: Start to check if only one device connected…
