Sudo apt install doca-tools fails
While installing doca-tools on Host PC running Ubuntu 20.04, the command “sudo apt install doca-tools” failes with the following output:
Reading package lists… Done
Building dependency tree
Reading state information… Done
doca-tools is already the newest version (2.0.2-0.0.7).
You might want to run ‘apt --fix-broken install’ to correct these.
The following packages have unmet dependencies:
doca-cx-tools : Depends: doca-cx-prime-tools (= 2.0.2027-1) but it is not going to be installed
E: Unmet dependencies. Try ‘apt --fix-broken install’ with no packages (or specify a solution).
Does anyone know how to fix this??
