Request you to share the ONNX model and the script if not shared already so that we can assist you better.
Alongside you can try few things:
validating your model with the below snippet
check_model.py
import sys
import onnx
filename = yourONNXmodel
model = onnx.load(filename)
onnx.checker.check_model(model).
2) Try running your model with trtexec command.
In case you are still facing issue, request you to share the trtexec “”–verbose"" log for further debugging
import onnx
import onnx.checker
model = onnx.load("repro.onnx")
print(model.ir_version) # print "9"
onnx.checker.check_model(model) # onnx.onnx_cpp2py_export.checker.ValidationError: Your model ir_version is higher than the checker's.
Certainly TerrorRT itself supports up to 7 opsets.
On the other hand, it was stated that onnx_tensorrt supports up to 17, so if the model is converted by onnx_tensorrt, there seems to be no problem.
The imported onnx is the one included in the container.
I also tried running trtexec with --verbose, but I don’t see anything suspicious, except the output. verbose.log (2.0 MB)
I tried to implement repro.onnx’s InstanceNormalization by other ops.
Converted onnx produces close results from repro.onnx .
trtexec not produces inf/nan. (!)
Converted model is here.
So, I guess, InstanceNormalization_TRT plugin has issue of implements.
According to the onnx-tensorrt repo, it is used on InstanceNormalization parsing.
Maybe it has something to do with having two versions of InstanceNormalization_TRT loaded.
You can see this in the verbose.log uploaded in the previous post.
I still get around this with a workaround that replaces InstanceNormalization.
Since the number of nodes on onnx will increase, if possible, I am looking for a method that does not produce nan or inf while using InstanceNormalization.
