Instruction 'tcgen05.alloc' not supported on .target 'sm_110'
When compiling the following code on Thor:
__global__ void tcgen05_dummy(const int num_iters) {
    __shared__ uint32_t smem[1024];
    asm volatile(
      "tcgen05.alloc.cta_group::2.sync.aligned.shared::cta.b32 [%0], %1;"
      : "r"(smem[0]), "n"(TMEM_COLUMNS));
NVCC reports the following errors:
error   : Instruction 'tcgen05.alloc' not supported on .target 'sm_110'
error   : Feature '.cta_group::2' not supported on .target 'sm_110'
CUDA Version:
Copyright (c) 2005-2025 NVIDIA Corporation
Built on Tue_Dec_16_07:27:17_PM_PST_2025
Cuda compilation tools, release 13.1, V13.1.115
Build cuda_13.1.r13.1/compiler.37061995_0
Compilation command:
nvcc -arch=sm_110a -O2 tcgen05_dummy.cu
The tcgen05 instructions are supported on Thor, right?
There is a clue in that you seem to be compiling for sm_110a but the error is indicating sm_110
The operation requires sm_110a (i.e. sm_110 won’t be sufficient), and/but the -arch switch has some possibly unexpected behavior in terms of what it means/actually compiles for.
Try compiling your code with -gencode arch=compute_110a,code=sm_110a instead of your -arch switch, and I think you’ll have a successful compile. If you wish to also embed PTX in the fatbinary, add an appropriate -gencode switch to do that, also.
