Integrating the DLib Library on the Code
The code below is for facial recognition on OpenCV using the Jetson Nano.I’ve installed the DLib 19.24.2 Library and need help incorporating the DLib Library on the code below:
import face_recognition
import cv2
import os
import pickle
import time
print(cv2.__version__)
Encodings=[]
Names=[]
with open('train.pkl','rb') as f:
Names=pickle.load(f)
Encodings=pickle.load(f)
font=cv2.FONT_HERSHEY_SIMPLEX
cam= cv2.VideoCapture(1)
while True:
_,frame=cam.read()
frameSmall=cv2.resize(frame,(0,0),fx=.25,fy=.25)
frameRGB=cv2.cvtColor(frameSmall,cv2.COLOR_BGR2RGB)
facePositions=face_recognition.face_locations(frameRGB,model='cnn')
allEncodings=face_recognition.face_encodings(frameRGB,facePositions)
for (top,right,bottom,left),face_encoding in zip(facePositions,allEncodings):
name='Unkown Person'
matches=face_recognition.compare_faces(Encodings,face_encoding)
if True in matches:
first_match_index=matches.index(True)
name=Names[first_match_index]
top=top*4
right=right*4
bottom=bottom*4
left=left*4
cv2.rectangle(frame,(left,top),(right, bottom),(0,0,255),2)
cv2.putText(frame,name,(left,top-6),font,.75,(0,0,255),2)
cv2.imshow('Picture',frame)
cv2.moveWindow('Picture',0,0)
if cv2.waitKey(1)==ord('q'):
break
cam.release()
cv2.destroyAllWindows()
The code above gives a really low output video frame rate(about ~1fps) on the Jetson nano, need help incorporating the DLib library on the code above.
Also, how can I improve the output video frame rate on the Jetson Nano? I wish to achieve a outut video frame rate of about 25-30FPS on the Jetson nano, kindly please suggest how I can achieve this.
Kindly please help.
Fr integrating dlib, would need other users to share experience. But since it is don on CPU cores, it may not be able to achieve 25-30fps.
If you would like to run deep learning inference, we would suggest use DeepStream SDK. Please check the document:
NVIDIA Metropolis Documentation
You can install the package through SDKManager. After the installation, the package will be in
/opt/nvidia/deepstream/deepstream/
You may begin with running deepstream-app + ResNet50
What would be the best achievable output video fps (approx.) if I were to develop a facial recognition app on Deepstream sdk 6.0.1on the Jetson Nano with JetPack 4.6.1?
Please find some benchmark data below:
For example:
Jetson Nano
Action Recognition 2D: 32
