We’ve bought connectx-4 LX 50gbE card which apparently has QSFP28 port and we’d like to get it connected to our switch which has QSFP+ ports only. Is this possible at all? Thanks.
What a miracle! QSFP+ can actually be plugged into QSFP28, but you have to be careful selecting the speed as mellanox’s proprietary 56GigE speed isn’t supported and you have to force 40GigE. What a pity you can’t have 50, but this is still better than having no link at all 😄
Related topics
| How to connect a QSFP56 NIC to a QSFP28 switch? | 2 | 2731 | July 8, 2021 | |
| Mellanox NIC didn't link with QSFP+ cable. | 1 | 446 | January 13, 2021 | |
| SN2100 QSFP (40Gbps) needs to be connected to Cisco Catalyst 3850 SFP 1Gbps port. | 1 | 488 | September 18, 2018 | |
| How to connect infiniband (QSFP28) switch with RJ45 | 2 | 1363 | January 11, 2023 | |
| QSFP56 ports accept QSFP28 devices | 2 | 3135 | February 27, 2021 | |
| Are there any secrets to using a qsfp -> sfp adapter? Setting link speed is not enough. | 1 | 627 | March 25, 2021 | |
| Connectx 5 Ex (MCX516A-BDAT) with QSFP28 (40 Gbps) connection to SFP+ 10 Gbps | 1 | 634 | October 30, 2020 | |
| Hi Mellanox team how do we connect SFP28 port of server (Dual port25Gbps LAN card) to QSFP28 port Mellanox switch P/N: MSN2100-BB2F ? | 1 | 333 | March 17, 2021 | |
| How can i connect a NIC which is QSFP28 to a QSFP56 switch (SN4600)? | 2 | 548 | April 7, 2025 | |
| qsfp vs qsfp+ | 1 | 427 | May 17, 2018 |
