Also the graph optimization is done in the same container.
The log output when doing the optimization:
INFO:tensorflow:Running against TensorRT version 5.0.2
I1129 09:40:24.167615 28 tf_logging.py:115] Running against TensorRT version 5.0.2
2018-11-29 09:40:24.651538: I tensorflow/core/grappler/devices.cc:51] Number of eligible GPUs (core count >= 8): 4
2018-11-29 09:40:24.654939: I tensorflow/core/grappler/clusters/single_machine.cc:359] Starting new session
2018-11-29 09:40:24.655574: I tensorflow/core/common_runtime/gpu/gpu_device.cc:1511] Adding visible gpu devices: 0, 1, 2, 3
2018-11-29 09:40:24.655797: I tensorflow/core/common_runtime/gpu/gpu_device.cc:982] Device interconnect StreamExecutor with strength 1 edge matrix:
2018-11-29 09:40:24.655842: I tensorflow/core/common_runtime/gpu/gpu_device.cc:988] 0 1 2 3
2018-11-29 09:40:24.655851: I tensorflow/core/common_runtime/gpu/gpu_device.cc:1001] 0: N Y N N
2018-11-29 09:40:24.655868: I tensorflow/core/common_runtime/gpu/gpu_device.cc:1001] 1: Y N N N
2018-11-29 09:40:24.655884: I tensorflow/core/common_runtime/gpu/gpu_device.cc:1001] 2: N N N Y
2018-11-29 09:40:24.655890: I tensorflow/core/common_runtime/gpu/gpu_device.cc:1001] 3: N N Y N
2018-11-29 09:40:24.656901: I tensorflow/core/common_runtime/gpu/gpu_device.cc:1115] Created TensorFlow device (/job:localhost/replica:0/task:0/device:GPU:0 with 15030 MB memory) → physical GPU (device: 0, name: Tesla P100-PCIE-16GB, pci bus id: 0000:00:04.0, compute capability: 6.0)
2018-11-29 09:40:24.657268: I tensorflow/core/common_runtime/gpu/gpu_device.cc:1115] Created TensorFlow device (/job:localhost/replica:0/task:0/device:GPU:1 with 15108 MB memory) → physical GPU (device: 1, name: Tesla P100-PCIE-16GB, pci bus id: 0000:00:05.0, compute capability: 6.0)
2018-11-29 09:40:24.657619: I tensorflow/core/common_runtime/gpu/gpu_device.cc:1115] Created TensorFlow device (/job:localhost/replica:0/task:0/device:GPU:2 with 15108 MB memory) → physical GPU (device: 2, name: Tesla P100-PCIE-16GB, pci bus id: 0000:00:06.0, compute capability: 6.0)
2018-11-29 09:40:24.657827: I tensorflow/core/common_runtime/gpu/gpu_device.cc:1115] Created TensorFlow device (/job:localhost/replica:0/task:0/device:GPU:3 with 15108 MB memory) → physical GPU (device: 3, name: Tesla P100-PCIE-16GB, pci bus id: 0000:00:07.0, compute capability: 6.0)
2018-11-29 09:40:25.191757: I tensorflow/contrib/tensorrt/convert/convert_graph.cc:853] MULTIPLE tensorrt candidate conversion: 13
2018-11-29 09:40:25.192324: I tensorflow/contrib/tensorrt/convert/convert_nodes.cc:3056] Segment @scope ‘’, converted to graph
2018-11-29 09:40:25.192363: E tensorflow/contrib/tensorrt/convert/convert_graph.cc:418] Can’t find a device placement for the op!
2018-11-29 09:40:25.198213: I tensorflow/contrib/tensorrt/convert/convert_nodes.cc:3056] Segment @scope ‘’, converted to graph
2018-11-29 09:40:25.198264: E tensorflow/contrib/tensorrt/convert/convert_graph.cc:418] Can’t find a device placement for the op!
2018-11-29 09:40:25.199297: I tensorflow/contrib/tensorrt/convert/convert_nodes.cc:3056] Segment @scope ‘’, converted to graph
2018-11-29 09:40:25.199332: E tensorflow/contrib/tensorrt/convert/convert_graph.cc:418] Can’t find a device placement for the op!
2018-11-29 09:40:25.199710: W tensorflow/contrib/tensorrt/convert/convert_graph.cc:891] Failed to register segment graphdef as a function 2: Invalid argument: Input 0 of node TensorRTOutputPH_0 was passed float from TopKV2:0 incompatible with expected int32.
2018-11-29 09:40:25.200140: I tensorflow/contrib/tensorrt/convert/convert_nodes.cc:3056] Segment @scope ‘’, converted to graph
2018-11-29 09:40:25.200172: E tensorflow/contrib/tensorrt/convert/convert_graph.cc:418] Can’t find a device placement for the op!
2018-11-29 09:40:25.200506: W tensorflow/contrib/tensorrt/convert/convert_graph.cc:891] Failed to register segment graphdef as a function 3: Invalid argument: Input 0 of node TensorRTOutputPH_0 was passed float from TopKV2_1:0 incompatible with expected int32.
2018-11-29 09:40:25.200745: I tensorflow/contrib/tensorrt/convert/convert_nodes.cc:3056] Segment @scope ‘model/output_4_108_56dim/’, converted to graph
2018-11-29 09:40:25.200777: E tensorflow/contrib/tensorrt/convert/convert_graph.cc:418] Can’t find a device placement for the op!
2018-11-29 09:40:25.204282: I tensorflow/contrib/tensorrt/convert/convert_nodes.cc:3056] Segment @scope ‘model/wide-resnet/’, converted to graph
2018-11-29 09:40:25.204326: E tensorflow/contrib/tensorrt/convert/convert_graph.cc:418] Can’t find a device placement for the op!
2018-11-29 09:40:25.214711: I tensorflow/contrib/tensorrt/convert/convert_nodes.cc:3056] Segment @scope ‘model_1/output_4_108_56dim/’, converted to graph
2018-11-29 09:40:25.214763: E tensorflow/contrib/tensorrt/convert/convert_graph.cc:418] Can’t find a device placement for the op!
2018-11-29 09:40:25.219756: I tensorflow/contrib/tensorrt/convert/convert_nodes.cc:3056] Segment @scope ‘model_1/wide-resnet/’, converted to graph
2018-11-29 09:40:25.219795: E tensorflow/contrib/tensorrt/convert/convert_graph.cc:418] Can’t find a device placement for the op!
2018-11-29 09:40:25.233015: I tensorflow/contrib/tensorrt/convert/convert_nodes.cc:3056] Segment @scope ‘model_2/’, converted to graph
2018-11-29 09:40:25.233052: E tensorflow/contrib/tensorrt/convert/convert_graph.cc:418] Can’t find a device placement for the op!
2018-11-29 09:40:25.242917: I tensorflow/contrib/tensorrt/convert/convert_nodes.cc:3056] Segment @scope ‘model_2/wide-resnet/’, converted to graph
2018-11-29 09:40:25.242963: E tensorflow/contrib/tensorrt/convert/convert_graph.cc:418] Can’t find a device placement for the op!
2018-11-29 09:40:25.257458: I tensorflow/contrib/tensorrt/convert/convert_nodes.cc:3056] Segment @scope ‘model_3/output_8_108_56dim/’, converted to graph
2018-11-29 09:40:25.257501: E tensorflow/contrib/tensorrt/convert/convert_graph.cc:418] Can’t find a device placement for the op!
2018-11-29 09:40:25.272904: I tensorflow/contrib/tensorrt/convert/convert_nodes.cc:3056] Segment @scope ‘model_3/wide-resnet/’, converted to graph
2018-11-29 09:40:25.272980: E tensorflow/contrib/tensorrt/convert/convert_graph.cc:418] Can’t find a device placement for the op!
2018-11-29 09:40:25.289882: I tensorflow/contrib/tensorrt/convert/convert_nodes.cc:3056] Segment @scope ‘’, converted to graph
2018-11-29 09:40:25.289936: E tensorflow/contrib/tensorrt/convert/convert_graph.cc:418] Can’t find a device placement for the op!
2018-11-29 09:40:40.418073: I tensorflow/contrib/tensorrt/convert/convert_graph.cc:952] Engine my_trt_op_0 creation for segment 0, composed of 2 nodes succeeded.
2018-11-29 09:40:40.450207: I tensorflow/contrib/tensorrt/convert/convert_graph.cc:952] Engine my_trt_op_1 creation for segment 1, composed of 2 nodes succeeded.
2018-11-29 09:40:40.641688: I tensorflow/contrib/tensorrt/convert/convert_graph.cc:952] Engine model/output_4_108_56dim/my_trt_op_4 creation for segment 2, composed of 4 nodes succeeded.
2018-11-29 09:41:06.770987: I tensorflow/contrib/tensorrt/convert/convert_graph.cc:952] Engine model/wide-resnet/my_trt_op_5 creation for segment 3, composed of 223 nodes succeeded.
2018-11-29 09:41:06.943108: I tensorflow/contrib/tensorrt/convert/convert_graph.cc:952] Engine model_1/output_4_108_56dim/my_trt_op_6 creation for segment 4, composed of 4 nodes succeeded.
2018-11-29 09:41:32.902693: I tensorflow/contrib/tensorrt/convert/convert_graph.cc:952] Engine model_1/wide-resnet/my_trt_op_7 creation for segment 5, composed of 223 nodes succeeded.
2018-11-29 09:41:33.474359: I tensorflow/contrib/tensorrt/convert/convert_graph.cc:952] Engine model_2/my_trt_op_8 creation for segment 6, composed of 17 nodes succeeded.
2018-11-29 09:41:59.413435: I tensorflow/contrib/tensorrt/convert/convert_graph.cc:952] Engine model_2/wide-resnet/my_trt_op_9 creation for segment 7, composed of 223 nodes succeeded.
2018-11-29 09:41:59.587183: I tensorflow/contrib/tensorrt/convert/convert_graph.cc:952] Engine model_3/output_8_108_56dim/my_trt_op_10 creation for segment 8, composed of 4 nodes succeeded.
2018-11-29 09:42:25.531645: I tensorflow/contrib/tensorrt/convert/convert_graph.cc:952] Engine model_3/wide-resnet/my_trt_op_11 creation for segment 9, composed of 223 nodes succeeded.
2018-11-29 09:42:25.653696: I tensorflow/contrib/tensorrt/convert/convert_graph.cc:952] Engine my_trt_op_12 creation for segment 10, composed of 2 nodes succeeded.
2018-11-29 09:42:25.769440: I tensorflow/contrib/tensorrt/convert/convert_nodes.cc:3056] Segment @scope ‘’, converted to graph
2018-11-29 09:42:25.769521: E tensorflow/contrib/tensorrt/convert/convert_graph.cc:418] Can’t find a device placement for the op!
2018-11-29 09:42:25.787068: W tensorflow/contrib/tensorrt/convert/convert_graph.cc:891] Failed to register segment graphdef as a function 0: Invalid argument: Input 0 of node TensorRTOutputPH_0 was passed float from TopKV2:0 incompatible with expected int32.
2018-11-29 09:42:25.893006: W tensorflow/contrib/tensorrt/convert/trt_optimization_pass.cc:185] TensorRTOptimizer is probably called on funcdef! This optimizer must NOT be called on function objects.
2018-11-29 09:42:25.929001: W tensorflow/contrib/tensorrt/convert/trt_optimization_pass.cc:185] TensorRTOptimizer is probably called on funcdef! This optimizer must NOT be called on function objects.
2018-11-29 09:42:26.008819: W tensorflow/contrib/tensorrt/convert/trt_optimization_pass.cc:185] TensorRTOptimizer is probably called on funcdef! This optimizer must NOT be called on function objects.
2018-11-29 09:42:26.045368: W tensorflow/contrib/tensorrt/convert/trt_optimization_pass.cc:185] TensorRTOptimizer is probably called on funcdef! This optimizer must NOT be called on function objects.
2018-11-29 09:42:26.127372: W tensorflow/contrib/tensorrt/convert/trt_optimization_pass.cc:185] TensorRTOptimizer is probably called on funcdef! This optimizer must NOT be called on function objects.
2018-11-29 09:42:26.164375: W tensorflow/contrib/tensorrt/convert/trt_optimization_pass.cc:185] TensorRTOptimizer is probably called on funcdef! This optimizer must NOT be called on function objects.
2018-11-29 09:42:26.282139: W tensorflow/contrib/tensorrt/convert/trt_optimization_pass.cc:185] TensorRTOptimizer is probably called on funcdef! This optimizer must NOT be called on function objects.
2018-11-29 09:42:26.318606: W tensorflow/contrib/tensorrt/convert/trt_optimization_pass.cc:185] TensorRTOptimizer is probably called on funcdef! This optimizer must NOT be called on function objects.
2018-11-29 09:42:26.440117: W tensorflow/contrib/tensorrt/convert/trt_optimization_pass.cc:185] TensorRTOptimizer is probably called on funcdef! This optimizer must NOT be called on function objects.
2018-11-29 09:42:26.494539: W tensorflow/contrib/tensorrt/convert/trt_optimization_pass.cc:185] TensorRTOptimizer is probably called on funcdef! This optimizer must NOT be called on function objects.
2018-11-29 09:42:26.614278: W tensorflow/contrib/tensorrt/convert/trt_optimization_pass.cc:185] TensorRTOptimizer is probably called on funcdef! This optimizer must NOT be called on function objects.
2018-11-29 09:42:26.668181: W tensorflow/contrib/tensorrt/convert/trt_optimization_pass.cc:185] TensorRTOptimizer is probably called on funcdef! This optimizer must NOT be called on function objects.
2018-11-29 09:42:26.787353: W tensorflow/contrib/tensorrt/convert/trt_optimization_pass.cc:185] TensorRTOptimizer is probably called on funcdef! This optimizer must NOT be called on function objects.
2018-11-29 09:42:26.841824: W tensorflow/contrib/tensorrt/convert/trt_optimization_pass.cc:185] TensorRTOptimizer is probably called on funcdef! This optimizer must NOT be called on function objects.
2018-11-29 09:42:26.962737: W tensorflow/contrib/tensorrt/convert/trt_optimization_pass.cc:185] TensorRTOptimizer is probably called on funcdef! This optimizer must NOT be called on function objects.
2018-11-29 09:42:27.016635: W tensorflow/contrib/tensorrt/convert/trt_optimization_pass.cc:185] TensorRTOptimizer is probably called on funcdef! This optimizer must NOT be called on function objects.
2018-11-29 09:42:27.044637: I tensorflow/core/grappler/optimizers/meta_optimizer.cc:501] Optimization results for grappler item: tf_graph
2018-11-29 09:42:27.044703: I tensorflow/core/grappler/optimizers/meta_optimizer.cc:503] constant folding: Graph size after: 1014 nodes (-422), 1060 edges (-545), time = 195.78ms.
2018-11-29 09:42:27.044713: I tensorflow/core/grappler/optimizers/meta_optimizer.cc:503] layout: Graph size after: 1024 nodes (10), 1076 edges (16), time = 62.572ms.
2018-11-29 09:42:27.044719: I tensorflow/core/grappler/optimizers/meta_optimizer.cc:503] TensorRTOptimizer: Graph size after: 108 nodes (-916), 122 edges (-954), time = 120603.203ms.
2018-11-29 09:42:27.044749: I tensorflow/core/grappler/optimizers/meta_optimizer.cc:503] constant folding: Graph size after: 108 nodes (0), 122 edges (0), time = 43.359ms.
2018-11-29 09:42:27.044766: I tensorflow/core/grappler/optimizers/meta_optimizer.cc:503] TensorRTOptimizer: Graph size after: 108 nodes (0), 122 edges (0), time = 83.243ms.
2018-11-29 09:42:27.044774: I tensorflow/core/grappler/optimizers/meta_optimizer.cc:501] Optimization results for grappler item: model_2/my_trt_op_8_native_segment
2018-11-29 09:42:27.044780: I tensorflow/core/grappler/optimizers/meta_optimizer.cc:503] constant folding: Graph size after: 18 nodes (0), 19 edges (0), time = 36.011ms.
2018-11-29 09:42:27.044788: I tensorflow/core/grappler/optimizers/meta_optimizer.cc:503] layout: Graph size after: 18 nodes (0), 19 edges (0), time = 16.487ms.
2018-11-29 09:42:27.044818: I tensorflow/core/grappler/optimizers/meta_optimizer.cc:503] TensorRTOptimizer: Graph size after: 18 nodes (0), 19 edges (0), time = 4.844ms.
2018-11-29 09:42:27.044826: I tensorflow/core/grappler/optimizers/meta_optimizer.cc:503] constant folding: Graph size after: 18 nodes (0), 19 edges (0), time = 31.016ms.
2018-11-29 09:42:27.044839: I tensorflow/core/grappler/optimizers/meta_optimizer.cc:503] TensorRTOptimizer: Graph size after: 18 nodes (0), 19 edges (0), time = 5.544ms.
2018-11-29 09:42:27.044853: I tensorflow/core/grappler/optimizers/meta_optimizer.cc:501] Optimization results for grappler item: model_3/output_8_108_56dim/my_trt_op_10_native_segment
2018-11-29 09:42:27.044863: I tensorflow/core/grappler/optimizers/meta_optimizer.cc:503] constant folding: Graph size after: 5 nodes (0), 4 edges (0), time = 34.587ms.
2018-11-29 09:42:27.044892: I tensorflow/core/grappler/optimizers/meta_optimizer.cc:503] layout: Graph size after: 5 nodes (0), 4 edges (0), time = 17.526ms.
2018-11-29 09:42:27.044903: I tensorflow/core/grappler/optimizers/meta_optimizer.cc:503] TensorRTOptimizer: Graph size after: 5 nodes (0), 4 edges (0), time = 4.659ms.
2018-11-29 09:42:27.044921: I tensorflow/core/grappler/optimizers/meta_optimizer.cc:503] constant folding: Graph size after: 5 nodes (0), 4 edges (0), time = 31.75ms.
2018-11-29 09:42:27.044931: I tensorflow/core/grappler/optimizers/meta_optimizer.cc:503] TensorRTOptimizer: Graph size after: 5 nodes (0), 4 edges (0), time = 4.961ms.
2018-11-29 09:42:27.044959: I tensorflow/core/grappler/optimizers/meta_optimizer.cc:501] Optimization results for grappler item: model_1/output_4_108_56dim/my_trt_op_6_native_segment
2018-11-29 09:42:27.044993: I tensorflow/core/grappler/optimizers/meta_optimizer.cc:503] constant folding: Graph size after: 5 nodes (0), 4 edges (0), time = 36.605ms.
2018-11-29 09:42:27.045009: I tensorflow/core/grappler/optimizers/meta_optimizer.cc:503] layout: Graph size after: 5 nodes (0), 4 edges (0), time = 17.15ms.
2018-11-29 09:42:27.045015: I tensorflow/core/grappler/optimizers/meta_optimizer.cc:503] TensorRTOptimizer: Graph size after: 5 nodes (0), 4 edges (0), time = 4.381ms.
2018-11-29 09:42:27.045048: I tensorflow/core/grappler/optimizers/meta_optimizer.cc:503] constant folding: Graph size after: 5 nodes (0), 4 edges (0), time = 32.507ms.
2018-11-29 09:42:27.045055: I tensorflow/core/grappler/optimizers/meta_optimizer.cc:503] TensorRTOptimizer: Graph size after: 5 nodes (0), 4 edges (0), time = 4.846ms.
2018-11-29 09:42:27.045061: I tensorflow/core/grappler/optimizers/meta_optimizer.cc:501] Optimization results for grappler item: model/output_4_108_56dim/my_trt_op_4_native_segment
2018-11-29 09:42:27.045068: I tensorflow/core/grappler/optimizers/meta_optimizer.cc:503] constant folding: Graph size after: 5 nodes (0), 4 edges (0), time = 36.148ms.
2018-11-29 09:42:27.045074: I tensorflow/core/grappler/optimizers/meta_optimizer.cc:503] layout: Graph size after: 5 nodes (0), 4 edges (0), time = 18.145ms.
2018-11-29 09:42:27.045089: I tensorflow/core/grappler/optimizers/meta_optimizer.cc:503] TensorRTOptimizer: Graph size after: 5 nodes (0), 4 edges (0), time = 4.467ms.
2018-11-29 09:42:27.045100: I tensorflow/core/grappler/optimizers/meta_optimizer.cc:503] constant folding: Graph size after: 5 nodes (0), 4 edges (0), time = 31.955ms.
2018-11-29 09:42:27.045111: I tensorflow/core/grappler/optimizers/meta_optimizer.cc:503] TensorRTOptimizer: Graph size after: 5 nodes (0), 4 edges (0), time = 4.977ms.
2018-11-29 09:42:27.045122: I tensorflow/core/grappler/optimizers/meta_optimizer.cc:501] Optimization results for grappler item: model_1/wide-resnet/my_trt_op_7_native_segment
2018-11-29 09:42:27.045134: I tensorflow/core/grappler/optimizers/meta_optimizer.cc:503] constant folding: Graph size after: 224 nodes (0), 232 edges (0), time = 55.085ms.
2018-11-29 09:42:27.045144: I tensorflow/core/grappler/optimizers/meta_optimizer.cc:503] layout: Graph size after: 224 nodes (0), 232 edges (0), time = 32.213ms.
2018-11-29 09:42:27.045164: I tensorflow/core/grappler/optimizers/meta_optimizer.cc:503] TensorRTOptimizer: Graph size after: 224 nodes (0), 232 edges (0), time = 7.749ms.
2018-11-29 09:42:27.045180: I tensorflow/core/grappler/optimizers/meta_optimizer.cc:503] constant folding: Graph size after: 224 nodes (0), 232 edges (0), time = 46.68ms.
2018-11-29 09:42:27.045192: I tensorflow/core/grappler/optimizers/meta_optimizer.cc:503] TensorRTOptimizer: Graph size after: 224 nodes (0), 232 edges (0), time = 8.96ms.
2018-11-29 09:42:27.045203: I tensorflow/core/grappler/optimizers/meta_optimizer.cc:501] Optimization results for grappler item: model_2/wide-resnet/my_trt_op_9_native_segment
2018-11-29 09:42:27.045211: I tensorflow/core/grappler/optimizers/meta_optimizer.cc:503] constant folding: Graph size after: 224 nodes (0), 232 edges (0), time = 47.917ms.
2018-11-29 09:42:27.045228: I tensorflow/core/grappler/optimizers/meta_optimizer.cc:503] layout: Graph size after: 224 nodes (0), 232 edges (0), time = 29.938ms.
2018-11-29 09:42:27.045237: I tensorflow/core/grappler/optimizers/meta_optimizer.cc:503] TensorRTOptimizer: Graph size after: 224 nodes (0), 232 edges (0), time = 8.003ms.
2018-11-29 09:42:27.045248: I tensorflow/core/grappler/optimizers/meta_optimizer.cc:503] constant folding: Graph size after: 224 nodes (0), 232 edges (0), time = 45.782ms.
2018-11-29 09:42:27.045261: I tensorflow/core/grappler/optimizers/meta_optimizer.cc:503] TensorRTOptimizer: Graph size after: 224 nodes (0), 232 edges (0), time = 8.429ms.
2018-11-29 09:42:27.045272: I tensorflow/core/grappler/optimizers/meta_optimizer.cc:501] Optimization results for grappler item: model/wide-resnet/my_trt_op_5_native_segment
2018-11-29 09:42:27.045283: I tensorflow/core/grappler/optimizers/meta_optimizer.cc:503] constant folding: Graph size after: 224 nodes (0), 232 edges (0), time = 48.493ms.
2018-11-29 09:42:27.045293: I tensorflow/core/grappler/optimizers/meta_optimizer.cc:503] layout: Graph size after: 224 nodes (0), 232 edges (0), time = 29.765ms.
2018-11-29 09:42:27.045303: I tensorflow/core/grappler/optimizers/meta_optimizer.cc:503] TensorRTOptimizer: Graph size after: 224 nodes (0), 232 edges (0), time = 7.656ms.
2018-11-29 09:42:27.045313: I tensorflow/core/grappler/optimizers/meta_optimizer.cc:503] constant folding: Graph size after: 224 nodes (0), 232 edges (0), time = 46.6ms.
2018-11-29 09:42:27.045323: I tensorflow/core/grappler/optimizers/meta_optimizer.cc:503] TensorRTOptimizer: Graph size after: 224 nodes (0), 232 edges (0), time = 8.956ms.
2018-11-29 09:42:27.045333: I tensorflow/core/grappler/optimizers/meta_optimizer.cc:501] Optimization results for grappler item: model_3/wide-resnet/my_trt_op_11_native_segment
2018-11-29 09:42:27.045343: I tensorflow/core/grappler/optimizers/meta_optimizer.cc:503] constant folding: Graph size after: 224 nodes (0), 232 edges (0), time = 48.345ms.
2018-11-29 09:42:27.045358: I tensorflow/core/grappler/optimizers/meta_optimizer.cc:503] layout: Graph size after: 224 nodes (0), 232 edges (0), time = 30.467ms.
2018-11-29 09:42:27.045369: I tensorflow/core/grappler/optimizers/meta_optimizer.cc:503] TensorRTOptimizer: Graph size after: 224 nodes (0), 232 edges (0), time = 7.688ms.
2018-11-29 09:42:27.045382: I tensorflow/core/grappler/optimizers/meta_optimizer.cc:503] constant folding: Graph size after: 224 nodes (0), 232 edges (0), time = 46.09ms.
2018-11-29 09:42:27.045392: I tensorflow/core/grappler/optimizers/meta_optimizer.cc:503] TensorRTOptimizer: Graph size after: 224 nodes (0), 232 edges (0), time = 8.902ms.
Is there anything special in this logs?
The weird thing is that when I start the application again with exactly the same graph then it works. So starting it the first time it fails, but second time it runs normally.
So sometimes it works, but sometimes not:
The error message is the same, but sometimes it appears 4 times
python: cask/shaderlist_impl.h:50: void cask::ShaderList<ShaderType, OperationType>::sortHandles() const [with ShaderType = cask::ConvolutionShader; OperationType = cask::Convolution]: Assertion ((*i)->handle != (*prevI)->handle) && "Internal error: CASK: all shaders must have unique names"' failed. python: cask/shaderlist_impl.h:50: void cask::ShaderList<ShaderType, OperationType>::sortHandles() const [with ShaderType = cask::ConvolutionShader; OperationType = cask::Convolution]: Assertion ((*i)->handle != (*prevI)->handle) && “Internal error: CASK: all shaders must have unique names”’ failed.
Aborted (core dumped)
