Hello!
I’m trying to implement a network and I get the following error:
InternalError: cudaGetDevice() failed. Status: CUDA driver version is insufficient for CUDA runtime version
I have two CUDA versions in my PC, 10.0 and 9.0. This is the first time I’m using 10.0. I already exported the paths.
tf-gpu version=1.14
The compatibility requirements are such according to the docs:
CUDA 10.0 (10.0.130) >= 410.48
The following NVIDIA® software must be installed on your system:
NVIDIA® GPU drivers —CUDA 10.0 requires 410.x or higher.
CUDA® Toolkit —TensorFlow supports CUDA 10.0 (TensorFlow >= 1.13.0)
CUPTI ships with the CUDA Toolkit.
cuDNN SDK (>= 7.4.1)
(Optional) TensorRT 5.0 to improve latency and throughput for inference on some models.
My details are such:
| NVIDIA-SMI 410.48 Driver Version: 410.48 |
| 0 GeForce GTX 1080 Off | 00000000:01:00.0 On | N/A |
| 0% 57C P2 39W / 210W | 145MiB / 8116MiB | 1% Default |
| 1 GeForce GTX 1080 Off | 00000000:02:00.0 Off | N/A |
| 0% 36C P8 10W / 210W | 2MiB / 8119MiB | 0% Default |
| Processes: GPU Memory |
| GPU PID Type Process name Usage |
| 0 1195 G /usr/lib/xorg/Xorg 92MiB |
| 0 1336 G /usr/bin/gnome-shell 50MiB |
Copyright (c) 2005-2018 NVIDIA Corporation
Built on Sat_Aug_25_21:08:01_CDT_2018
Cuda compilation tools, release 10.0, V10.0.130
I believe I have satisfied the compatibility requirements. Or am I missing anything?
Thank you for your help!
