When I install tensorflow to run a test code. it says
2018-05-13 10:00:03.012495: I tensorflow/core/platform/cpu_feature_guard.cc:140] Your CPU supports instructions that this TensorFlow binary was not compiled to use: SSE4.1 SSE4.2 AVX AVX2 FMA
2018-05-13 10:00:03.312772: I tensorflow/core/common_runtime/gpu/gpu_device.cc:1344] Found device 0 with properties:
name: TITAN Xp major: 6 minor: 1 memoryClockRate(GHz): 1.911
pciBusID: 0000:05:00.0
totalMemory: 11.90GiB freeMemory: 11.58GiB
2018-05-13 10:00:03.591350: I tensorflow/core/common_runtime/gpu/gpu_device.cc:1344] Found device 1 with properties:
pciBusID: 0000:06:00.0
totalMemory: 11.90GiB freeMemory: 11.74GiB
2018-05-13 10:00:03.862648: I tensorflow/core/common_runtime/gpu/gpu_device.cc:1344] Found device 2 with properties:
pciBusID: 0000:09:00.0
2018-05-13 10:00:04.117984: I tensorflow/core/common_runtime/gpu/gpu_device.cc:1344] Found device 3 with properties:
pciBusID: 0000:0a:00.0
2018-05-13 10:00:04.123222: I tensorflow/core/common_runtime/gpu/gpu_device.cc:1423] Adding visible gpu devices: 0, 1, 2, 3
2018-05-13 10:00:04.123350: E tensorflow/core/common_runtime/direct_session.cc:167] Internal: cudaGetDevice() failed. Status: CUDA driver version is insufficient for CUDA runtime version
File "test.py", line 5, in <module>
sess = tf.Session()
File "/home/zhe/anaconda3/envs/tf_env/lib/python3.6/site-packages/tensorflow/python/client/session.py", line 1509, in __init__
super(Session, self).__init__(target, graph, config=config)
File "/home/zhe/anaconda3/envs/tf_env/lib/python3.6/site-packages/tensorflow/python/client/session.py", line 638, in __init__
self._session = tf_session.TF_NewDeprecatedSession(opts, status)
File "/home/zhe/anaconda3/envs/tf_env/lib/python3.6/site-packages/tensorflow/python/framework/errors_impl.py", line 516, in __exit__
c_api.TF_GetCode(self.status.status))
tensorflow.python.framework.errors_impl.InternalError: Failed to create session.
Sun May 13 11:38:25 2018
| NVIDIA-SMI 381.09 Driver Version: 381.09 |
| 0 TITAN Xp On | 0000:05:00.0 Off | N/A |
| 23% 37C P8 18W / 250W | 175MiB / 12189MiB | 0% Default |
| 1 TITAN Xp On | 0000:06:00.0 Off | N/A |
| 23% 36C P8 17W / 250W | 10MiB / 12189MiB | 0% Default |
| 2 TITAN Xp On | 0000:09:00.0 Off | N/A |
| 23% 35C P8 17W / 250W | 10MiB / 12189MiB | 0% Default |
| 3 TITAN Xp On | 0000:0A:00.0 Off | N/A |
| 23% 33C P8 17W / 250W | 10MiB / 12189MiB | 0% Default |
| Processes: GPU Memory |
| GPU PID Type Process name Usage |
| 0 1488 C /usr/bin/python 165MiB |
nvcc --version
Copyright (c) 2005-2016 NVIDIA Corporation
Built on Tue_Jan_10_13:22:03_CST_2017
Cuda compilation tools, release 8.0, V8.0.61
My lab colleague didn’t have this problem.
Thanks for your help.
