I run tensorflow python code example and get an error.
>>> import tensorflow as tf
>>> hello = tf.constant('Hello, TensorFlow!')
>>> sess = tf.Session()
2018-08-13 18:15:03.045256: I tensorflow/core/platform/cpu_feature_guard.cc:141] Your CPU supports instructions that this TensorFlow binary was not compiled to use: AVX2 FMA
2018-08-13 18:15:03.229415: I tensorflow/stream_executor/cuda/cuda_gpu_executor.cc:897] successful NUMA node read from SysFS had negative value (-1), but there must be at least one NUMA node, so returning NUMA node zero
2018-08-13 18:15:03.229931: I tensorflow/core/common_runtime/gpu/gpu_device.cc:1405] Found device 0 with properties:
name: Tesla K80 major: 3 minor: 7 memoryClockRate(GHz): 0.8755
pciBusID: 0000:00:05.0
totalMemory: 11.17GiB freeMemory: 11.11GiB
2018-08-13 18:15:03.229961: I tensorflow/core/common_runtime/gpu/gpu_device.cc:1484] Adding visible gpu devices: 0
2018-08-13 18:15:03.230149: E tensorflow/core/common_runtime/direct_session.cc:158] Internal: cudaGetDevice() failed. Status: CUDA driver version is insufficient for CUDA runtime version
File "<stdin>", line 1, in <module>
File "/usr/local/anaconda3/envs/tensorflow/lib/python3.6/site-packages/tensorflow/python/client/session.py", line 1494, in __init__
super(Session, self).__init__(target, graph, config=config)
File "/usr/local/anaconda3/envs/tensorflow/lib/python3.6/site-packages/tensorflow/python/client/session.py", line 626, in __init__
self._session = tf_session.TF_NewSession(self._graph._c_graph, opts)
tensorflow.python.framework.errors_impl.InternalError: Failed to create session.
this is my virrualMachine env.
root@VM1534144690845:/usr/local# nvcc -V
Copyright (c) 2005-2017 NVIDIA Corporation
Built on Fri_Sep__1_21:08:03_CDT_2017
Cuda compilation tools, release 9.0, V9.0.176
root@VM1534144690845:/usr/local# nvidia-smi
Mon Aug 13 17:54:22 2018
| NVIDIA-SMI 367.48 Driver Version: 367.48 |
| 0 Tesla K80 On | 0000:00:05.0 Off | 0 |
| N/A 30C P8 30W / 149W | 0MiB / 11439MiB | 0% Default |
| Processes: GPU Memory |
| GPU PID Type Process name Usage |
| No running processes found |
root@VM1534144690845:/usr/local# /etc/issue
-bash: /etc/issue: Permission denied
root@VM1534144690845:/usr/local# grep . /etc/*-release
/etc/lsb-release:DISTRIB_ID=Ubuntu
/etc/lsb-release:DISTRIB_RELEASE=16.04
/etc/lsb-release:DISTRIB_CODENAME=xenial
/etc/lsb-release:DISTRIB_DESCRIPTION="Ubuntu 16.04.1 LTS"
/etc/os-release:NAME="Ubuntu"
/etc/os-release:VERSION="16.04.1 LTS (Xenial Xerus)"
/etc/os-release:ID=ubuntu
/etc/os-release:ID_LIKE=debian
/etc/os-release:PRETTY_NAME="Ubuntu 16.04.1 LTS"
/etc/os-release:VERSION_ID="16.04"
/etc/os-release:HOME_URL="http://www.ubuntu.com/"
/etc/os-release:SUPPORT_URL="http://help.ubuntu.com/"
/etc/os-release:BUG_REPORT_URL="http://bugs.launchpad.net/ubuntu/"
/etc/os-release:UBUNTU_CODENAME=xenial
root@VM1534144690845:/usr/local# conda -V
conda 4.5.9
root@VM1534144690845:/usr/local# python -V
Python 3.6.6 :: Anaconda, Inc.
