I am attempting to run the TensorFlow GPU version but get the error when ever I create a TensorFlow Session.
OS: Linux 4.14
Distro: Manjaro 17.1.1
Machine: Dell XPS 15 9560
GPU: Nvidia GeForce GTX 1050
Drivers: ‘video-hybrid-intel-nvidia-bumblebee’
CUDA: 9.1
cuDNN: 7.0
TensorFlow: r1.5 built from source (which appears to be working fine for others: https://github.com/tensorflow/tensorflow/issues/15656)
optirun nvidia-smi
Thu Jan 11 21:57:15 2018
| NVIDIA-SMI 384.111 Driver Version: 384.111 |
| 0 GeForce GTX 1050 Off | 00000000:01:00.0 Off | N/A |
| N/A 38C P0 N/A / N/A | 6MiB / 4041MiB | 0% Default |
| Processes: GPU Memory |
| GPU PID Type Process name Usage |
| 0 2024 G /usr/lib/xorg-server/Xorg 6MiB |
optirun python test.py
2018-01-11 22:12:48.275062: I tensorflow/stream_executor/cuda/cuda_gpu_executor.cc:898] successful NUMA node read from SysFS had negative value (-1), but there must be at least one NUMA node, so returning NUMA node zero
2018-01-11 22:12:48.275380: I tensorflow/core/common_runtime/gpu/gpu_device.cc:1206] Found device 0 with properties:
name: GeForce GTX 1050 major: 6 minor: 1 memoryClockRate(GHz): 1.493
pciBusID: 0000:01:00.0
totalMemory: 3.95GiB freeMemory: 3.89GiB
2018-01-11 22:12:48.275410: I tensorflow/core/common_runtime/gpu/gpu_device.cc:1300] Adding visible gpu device 0
2018-01-11 22:12:48.275560: E tensorflow/core/common_runtime/direct_session.cc:168] Internal: cudaGetDevice() failed. Status: CUDA driver version is insufficient for CUDA runtime version
