Hi folks,
I’m following the CUDA-by-example book and the code provided with it. I am trying to get the Interoperation between CUDA and OpenGL working, but no matter what I do, I seem to be running into the “all CUDA-capable devices are busy or unavailable” error.
Here is the code I’m working with now (after the suggestions from StackOverflow about doing GLUT stuff first):
#include "common/gl_helper.h"
#include "cuda.h"
#include "cuda_gl_interop.h"
#include "common/book.h"
#define DIM 1024
PFNGLBINDBUFFERARBPROC glBindBuffer = NULL;
PFNGLDELETEBUFFERSARBPROC glDeleteBuffers = NULL;
PFNGLGENBUFFERSARBPROC glGenBuffers = NULL;
PFNGLBUFFERDATAARBPROC glBufferData = NULL;
GLuint bufferObj;
cudaGraphicsResource *resource;
int main( void ) {
cudaDeviceProp prop;
int dev;
int c=1;
char* dummy = "";
glutInit( &c, &dummy );
glutInitDisplayMode( GLUT_DOUBLE | GLUT_RGBA );
glutInitWindowSize( DIM, DIM );
glutCreateWindow( "bitmap" );
glBindBuffer = (PFNGLBINDBUFFERARBPROC)GET_PROC_ADDRESS("glBindBuffer");
glDeleteBuffers = (PFNGLDELETEBUFFERSARBPROC)GET_PROC_ADDRESS("glDeleteBuffers");
glGenBuffers = (PFNGLGENBUFFERSARBPROC)GET_PROC_ADDRESS("glGenBuffers");
glBufferData = (PFNGLBUFFERDATAARBPROC)GET_PROC_ADDRESS("glBufferData");
glGenBuffers(1, &bufferObj);
glBindBuffer(GL_PIXEL_UNPACK_BUFFER_ARB, bufferObj);
glBufferData(GL_PIXEL_UNPACK_BUFFER_ARB, DIM*DIM*4, NULL, GL_DYNAMIC_DRAW_ARB);
memset(&prop, 0, sizeof(cudaDeviceProp));
prop.major = 1;
prop.minor = 0;
HANDLE_ERROR(cudaChooseDevice(&dev, &prop));
HANDLE_ERROR(cudaGLSetGLDevice(dev));
HANDLE_ERROR(cudaGraphicsGLRegisterBuffer(&resource, bufferObj, cudaGraphicsRegisterFlagsWriteDiscard));
Regardless, the problem occurs on the last line. I have tried running example code for CUDA-6.5 provided with the installation, but everything seems to result in this error. I can, however, render in OpenGL if I just swap the memory back to CPU (not do interoperation…). And normal kernels work fine as well.
I have tried closing all windows except VS2010, but same problem persists.
I am using Windows 7 x64, Visual Studio 2010, CUDA 6.5. I have a GTX650.
Please let me know if you have any clues as to why this is happening. Given that the book and all the code do not seem to cause other people problems (Google search turned up nothing), I’m guessing it is something I did.
Thanks in advance
