Problem with CUDA/OPENGL Interoperability
Hi!
I have big problem with my OpenGL/CUDA program.
That’s what i have to do:
OpenGL
  1. Compute Vertex
  2. Make Sphere from these vertex
  3. texture this sphere from image read from file
above points i made without any problem.
here is my openGL code:
http://pastebin.com/YH1Gnq7V
I have problem, when i want make interoperability with cuda.
I executed kernel, which computed vertex.
But, when I’m run program, i see only black openGl window…
I have to finish that quickly, because its my school project.
Here is mu CU file with kernel:
http://pastebin.com/eXpNGiRQ
Could someone help me?
I have to finish that quickly…
PS. Sorry for my english, I’m foreigner
You’re using a number of CUDA functions I’m unfamiliar with, but I can show you how I to OpenGL interop. Creat the context:
cudaSetDevice( cutGetMaxGflopsDeviceId() );
cudaGLSetGLDevice( cutGetMaxGflopsDeviceId() );
Create a buffer in OpenGL and register it:
// Create a pixel unpack buffer to store the perspective texture
glGenBuffers ( 1, &glPerspectiveBufferPos );
glBindBuffer ( GL_PIXEL_UNPACK_BUFFER, glPerspectiveBufferPos );
glBufferData( GL_PIXEL_UNPACK_BUFFER, GL_IMAGE_SIZE, 0, GL_DYNAMIC_COPY );
glBindBuffer ( GL_PIXEL_UNPACK_BUFFER, 0);
// set pixel alignments
glPixelStorei ( GL_UNPACK_ALIGNMENT, 1 );
glPixelStorei ( GL_PACK_ALIGNMENT, 1 );
// register buffer object with CUDA
cutilSafeCall ( cudaGLRegisterBufferObject( glPerspectiveBufferPos ));
glut Idle func I do some operation on the buffer:
unsigned char *perspectiveCudaGlBuf;
cutilSafeCall( cudaGLMapBufferObject( (void**)&perspectiveCudaGlBuf, glPerspectiveBufferPos ) );
// some stuff with perspectiveCudaGlBuf as a device memory pointer
// unmap buffer object
cutilSafeCall( cudaGLUnmapBufferObject( glPerspectiveBufferPos ) );
And glut display just use the OpenGL texture buffer as normal:
// bind the perspective texture to the active GL texture
glTexImage2D ( GL_TEXTURE_2D, 0, 4 /* RGBA */, GL_IMAGE_WIDTH, GL_IMAGE_HEIGHT, 0, GL_RGBA, GL_UNSIGNED_BYTE, 0 );
glBindBuffer ( GL_PIXEL_UNPACK_BUFFER, 0 );
// first draw the perspective texture
glBegin ( GL_QUADS );
	glTexCoord2f ( 1, 1 );   glVertex2f ( GL_IMAGE_WIDTH, GL_IMAGE_HEIGHT );
	glTexCoord2f ( 1, 0 );   glVertex2f ( GL_IMAGE_WIDTH, 0.0 );
	glTexCoord2f ( 0, 0 );   glVertex2f ( 0.0, 0.0 );
	glTexCoord2f ( 0, 1 );   glVertex2f ( 0.0, GL_IMAGE_HEIGHT );
glEnd();
