See TLT different results - #9 by Morganh
So, please modify the preprocessing according to the hint in deepstream_tlt_apps/pgie_peopleSegNetv2_tlt_config.txt at release/tlt3.0 · NVIDIA-AI-IOT/deepstream_tlt_apps · GitHub
net-scale-factor=0.017507
offsets=123.675;116.280;103.53
model-color-format=0
Similar to keras-applications/imagenet_utils.py at master · keras-team/keras-applications · GitHub
if mode == ‘torch’:
x /= 255.
mean = [0.485, 0.456, 0.406]
std = [0.224, 0.224, 0.224]
Here are the preprocessing steps in TLT.
- For a given image, keep its aspect ratio and rescale the image to make it the largest rectangle to be bounded by the rectangle specified by the
target_size. - Pad the rescaled image such that the height and width of the image become the smallest multiple of the stride that is larger or equal to the desired output dimension.
- As mentioned above, will scale pixels between 0 and 1 and then will normalize each channel
Refer to:
and Discrepancy between results from tlt-infer and trt engine - #8 by Morganh, change to inference_input = preprocess_input(inf_img.transpose(2, 0, 1), mode="torch")
