Overview
CUPTI Python provides Python APIs for creation of profiling tools that target CUDA Python applications.
This release of CUPTI Python supports a subset of CUPTI C Activity and Callback APIs on Linux x86_64 . This includes Python samples to show use of the CUPTI Python APIs.
Please refer to the CUPTI Python 12.6.0 overview, release notes, and user guide for more details.
For more information on CUPTI, please see the CUPTI Overview page.
Platform support
- Linux x86_64
Runtime requirements
- CUDA Toolkit version 12.6
- Only the NVRTC redistributable component is required from the CUDA Toolkit.
CUDA Toolkit Documentation Installation Guides can be used for guidance. - Note that the NVRTC component in the Toolkit can be obtained via PYPI, Conda or Local Installer.
- Python version >= 3.9
Installing from PyPI
pip install cupti-python
Setting for CUPTI C Library
- cupti-python has a dependency on nvidia-cuda-cupti-cu12. It uses the CUPTI C library “libcupti.so” from nvidia-cuda-cupti-cu12.
- However, if nvidia-cuda-cupti-cu12 is uninstalled, the
LD_LIBRARY_PATHenvironment variable needs to be set to the directory in which “libcupti.so” is present. - When the CUDA Toolkit is installed, “libcupti.so” is present under
CUDA_TOOLKIT_INSTALL_PATH/extras/CUPTI/lib64.
e.g. If theCUDA_TOOLKIT_INSTALL_PATHis/usr/local/cuda-12.6:
$export LD_LIBRARY_PATH=/usr/local/cuda-12.6/extras/CUPTI/lib64
Cupti Python Samples
Once CUPTI Python is installed, the CUPTI samples are located under the “site-packages/cupti-python-samples” directory.
You can determine the location of your site-packages directory by executing the following command.
python3 -m site
Prior to executing the samples you need to install the following:
- numba
- numpy
Refer “cupti-python-samples/README.txt” for usage of samples.
Known Limitations
- The
function_paramsfield ofcupti.cupti.CallbackDatais currently not supported, “None” will be returned if used.
