Hi there,
I’m new to Cuda, and am attempting to make a kernel that will require > 65535 blocks in the x-dimension. I’ve found that using 65535 blocks works, however going over this limit results in a runtime invalid argument error when I execute the kernel. I’ve tried commenting all the contents of the kernel, just in case it has something to do with the kernel execution, and I get the same results. I’m using a 980ti, which reports the maximum grid x dimension as 2^31 - 1, which fits with compute capability 5.2. What am I doing wrong?
sample code:
int threadsPerBlock = 128;
dim3 blocks(65535, 1, 1);
processDataKernel << <blocks, threadsPerBlock >> >(…);
executes properly
dim3 blocks(65537, 1, 1);
spits out a runtime invalid argument error.
Can anyone help? Thanks!!
