I am using a GPU with these parameters
Device 0: “Tesla K10.G1.8GB”
CUDA Driver Version / Runtime Version 5.5 / 5.0
CUDA Capability Major/Minor version number: 3.0
Total amount of global memory: 3584 MBytes (3757637632 bytes)
( 8) Multiprocessors x (192) CUDA Cores/MP: 1536 CUDA Cores
GPU Clock rate: 745 MHz (0.75 GHz)
Memory Clock rate: 2500 Mhz
Memory Bus Width: 256-bit
L2 Cache Size: 524288 bytes
Max Texture Dimension Size (x,y,z) 1D=(65536), 2D=(65536,65536), 3D=(4096,4096,4096)
Max Layered Texture Size (dim) x layers 1D=(16384) x 2048, 2D=(16384,16384) x 2048
Total amount of constant memory: 65536 bytes
Total amount of shared memory per block: 49152 bytes
Total number of registers available per block: 65536
Warp size: 32
Maximum number of threads per multiprocessor: 2048
Maximum number of threads per block: 1024
Maximum sizes of each dimension of a block: 1024 x 1024 x 64
Maximum sizes of each dimension of a grid: 2147483647 x 65535 x 65535
Maximum memory pitch: 2147483647 bytes
Texture alignment: 512 bytes
Concurrent copy and kernel execution: Yes with 2 copy engine(s)
Run time limit on kernels: No
Integrated GPU sharing Host Memory: No
Support host page-locked memory mapping: Yes
Alignment requirement for Surfaces: Yes
Device has ECC support: Enabled
Device supports Unified Addressing (UVA): Yes
Device PCI Bus ID / PCI location ID: 159 / 0
Compute Mode:
< Default (multiple host threads can use ::cudaSetDevice() with device simultaneously) >
If I invoke my kernel like this: kernel<<< 65535, 1024 >>> then everything works fine.
However, if I invoke it like this: kernel<<< 65536, 1024 >>> then it fails in that the kernel does not seem to get invoked.
I would have thought that 65536 is not excessive, as gridDim.x has a limit of 2147483647.
By the way, I can run it with 65536 or more blocks by arranging them in a multidimensional grid (as long as no dimension exceeds 65535).
Any suggestion?
