Hello.
I am trying to implement Inverse Reachability Map(IRM) in Omniverse, and got some problems.
In Extension mode, I implemented the basic method for IRM.
I intended that the IsaacSim IK solver can compute the fact whether the solution exist or not at each grid points.
However, it is very slow because of the step size or redering issue.
I know that Standalone mode provides the acceleration of rendering or time step, but it could be slow to compute the huge size of grid data.
I just want the rapid computation of IRM without every rendering process.
This is the main part of code and video below.
class M1013(BaseSample):
def __init__(self) -> None:
self._controller = None
self._articulation_controller = None
super().__init__()
return
def setup_scene(self):
self.draw = _debug_draw.acquire_debug_draw_interface()
x = np.linspace(-5, 14, 100)
y = np.linspace(-10, 8, 100)
xx, yy = np.meshgrid(x, y)
self.grid_array = np.vstack((xx.ravel(), yy.ravel())).T
self.i = 0
return
async def setup_post_load(self):
self.target_name = task_params["target_name"]["value"]
self.denso_name = task_params["robot_name"]["value"]
self.my_denso = world.scene.get_object(self.denso_name)
self._controller = KinematicsSolver(self.my_denso)
self._articulation_controller = self.my_denso.get_articulation_controller()
self._world.add_physics_callback("sim_step", callback_fn=self._on_sim_step)
await self._world.play_async()
return
def _on_sim_step(self, step_size):
if self.i < len(self.grid_array):
x, y = self.grid_array[self.i]
observations = self._world.get_observations()
robot_pos = get_prim_property(prim_path = "/World/M1013", property_name = "xformOp:translate")
IRM_point = np.array(robot_pos)
actions, succ = self._controller.compute_inverse_kinematics( #Dist Base 2 Link6 #Dist EE 2 Tip
target_position=observations[self.target_name]["position"] - robot_pos, #+np.array([0,0,1.8927]), # Calibration for the manipulator's translation
target_orientation=observations[self.target_name]["orientation"],
if succ:
self.my_denso.set_joint_positions(actions.get_dict()['joint_positions'])
self.draw.draw_points([(IRM_point[0],IRM_point[1],IRM_point[2])], [(0, 1, 0, 1)], [10])
else:
self.draw.draw_points([(IRM_point[0],IRM_point[1],IRM_point[2])], [(1, 0, 0, 1)], [10])
carb.log_warn("IK did not converge to a solution. No action is being taken.")
set_prim_property(prim_path="/World/M1013", property_name="xformOp:translate", property_value=Gf.Vec3d(x, y, 6.9655))
self.i += 1
return
How can I accelerate the computation of IRM in Omniverse ?
Should I make the additional external python code for it ?
I referenced this ROS package(reuleaux - ROS Wiki), but I do not want to connect this to Omniverse.
Thank you.
