Is my RTX 4060 Ti faulty?
i have rtx 4060 ti and it works fine but randomly crash even when browsing or idle and cause the pc to restart/loose signal, i tested it with games, furmark, memtest vulkan, time spy and all good, its also not over clocked and all is stock, i got a bug check and a memory dump file as follows:
VIDEO_TDR_FAILURE (116)
Attempt to reset the display driver and recover from timeout failed.
Arguments:
Arg1: ffffc10fcd40d010, Optional pointer to internal TDR recovery context (TDR_RECOVERY_CONTEXT).
Arg2: fffff804e49da350, The pointer into responsible device driver module (e.g. owner tag).
Arg3: ffffffffc000009a, Optional error code (NTSTATUS) of the last failed operation.
Arg4: 0000000000000004, Optional internal context dependent data.
Debugging Details:
Unable to load image \SystemRoot\System32\DriverStore\FileRepository\nv_dispi.inf_amd64_0373d825005116d0\nvlddmkm.sys, Win32 error 0n2
*** WARNING: Check Image - Checksum mismatch - Dump: 0x15d0a, File: 0x17c7c - C:\ProgramData\Dbg\sym\watchdog.sys\28AF795D18000\watchdog.sys
Page 30e87e not present in the dump file. Type “.hh dbgerr004” for details
Page 15275 not present in the dump file. Type “.hh dbgerr004” for details
Page 3ee74 not present in the dump file. Type “.hh dbgerr004” for details
Page d84bd not present in the dump file. Type “.hh dbgerr004” for details
Page 3abebc not present in the dump file. Type “.hh dbgerr004” for details
Page 17b7bb not present in the dump file. Type “.hh dbgerr004” for details
Page d6bb7 not present in the dump file. Type “.hh dbgerr004” for details
KEY_VALUES_STRING: 1
Key  : Analysis.CPU.mSec
Value: 3531
Key  : Analysis.Elapsed.mSec
Value: 9919
Key  : Analysis.IO.Other.Mb
Value: 4
Key  : Analysis.IO.Read.Mb
Value: 1
Key  : Analysis.IO.Write.Mb
Value: 26
Key  : Analysis.Init.CPU.mSec
Value: 1078
Key  : Analysis.Init.Elapsed.mSec
Value: 28830
Key  : Analysis.Memory.CommitPeak.Mb
Value: 89
Key  : Analysis.Version.DbgEng
Value: 10.0.29617.1000
Key  : Analysis.Version.Description
Value: 10.2604.29.1 amd64fre
Key  : Analysis.Version.Ext
Value: 1.2604.29.1
Key  : Bugcheck.Code.KiBugCheckData
Value: 0x116
Key  : Bugcheck.Code.LegacyAPI
Value: 0x116
Key  : Bugcheck.Code.TargetModel
Value: 0x116
Key  : Failure.Bucket
Value: 0x116_IMAGE_nvlddmkm.sys
Key  : Failure.Exception.IP.Address
Value: 0xfffff804e49da350
Key  : Failure.Exception.IP.Module
Value: nvlddmkm
Key  : Failure.Exception.IP.Offset
Value: 0x195a350
Key  : Failure.Hash
Value: {c89bfe8c-ed39-f658-ef27-f2898997fdbd}
Key  : Faulting.IP.Type
Value: Paged
Key  : Hypervisor.Enlightenments.Value
Value: 0
Key  : Hypervisor.Enlightenments.ValueHex
Value: 0x0
Key  : Hypervisor.Flags.AnyHypervisorPresent
Value: 0
Key  : Hypervisor.Flags.ApicEnlightened
Value: 0
Key  : Hypervisor.Flags.ApicVirtualizationAvailable
Value: 0
Key  : Hypervisor.Flags.AsyncMemoryHint
Value: 0
Key  : Hypervisor.Flags.CoreSchedulerRequested
Value: 0
Key  : Hypervisor.Flags.CpuManager
Value: 0
Key  : Hypervisor.Flags.DeprecateAutoEoi
Value: 0
Key  : Hypervisor.Flags.DynamicCpuDisabled
Value: 0
Key  : Hypervisor.Flags.Epf
Value: 0
Key  : Hypervisor.Flags.ExtendedProcessorMasks
Value: 0
Key  : Hypervisor.Flags.HardwareMbecAvailable
Value: 0
Key  : Hypervisor.Flags.MaxBankNumber
Value: 0
Key  : Hypervisor.Flags.MemoryZeroingControl
Value: 0
Key  : Hypervisor.Flags.NoExtendedRangeFlush
Value: 0
Key  : Hypervisor.Flags.NoNonArchCoreSharing
Value: 0
Key  : Hypervisor.Flags.Phase0InitDone
Value: 0
Key  : Hypervisor.Flags.PowerSchedulerQos
Value: 0
Key  : Hypervisor.Flags.RootScheduler
Value: 0
Key  : Hypervisor.Flags.SynicAvailable
Value: 0
Key  : Hypervisor.Flags.UseQpcBias
Value: 0
Key  : Hypervisor.Flags.Value
Value: 0
Key  : Hypervisor.Flags.ValueHex
Value: 0x0
Key  : Hypervisor.Flags.VpAssistPage
Value: 0
Key  : Hypervisor.Flags.VsmAvailable
Value: 0
Key  : Hypervisor.RootFlags.AccessStats
Value: 0
Key  : Hypervisor.RootFlags.CrashdumpEnlightened
Value: 0
Key  : Hypervisor.RootFlags.CreateVirtualProcessor
Value: 0
Key  : Hypervisor.RootFlags.DisableHyperthreading
Value: 0
Key  : Hypervisor.RootFlags.HostTimelineSync
Value: 0
Key  : Hypervisor.RootFlags.HypervisorDebuggingEnabled
Value: 0
Key  : Hypervisor.RootFlags.IsHyperV
Value: 0
Key  : Hypervisor.RootFlags.LivedumpEnlightened
Value: 0
Key  : Hypervisor.RootFlags.MapDeviceInterrupt
Value: 0
Key  : Hypervisor.RootFlags.MceEnlightened
Value: 0
Key  : Hypervisor.RootFlags.Nested
Value: 0
Key  : Hypervisor.RootFlags.StartLogicalProcessor
Value: 0
Key  : Hypervisor.RootFlags.Value
Value: 0
Key  : Hypervisor.RootFlags.ValueHex
Value: 0x0
Key  : SecureKernel.HalpHvciEnabled
Value: 0
Key  : WER.OS.Branch
Value: vb_release
Key  : WER.OS.Version
Value: 10.0.19041.1
Key  : WER.System.BIOSRevision
Value: 4.6.0.0
BUGCHECK_CODE: 116
BUGCHECK_P1: ffffc10fcd40d010
BUGCHECK_P2: fffff804e49da350
BUGCHECK_P3: ffffffffc000009a
BUGCHECK_P4: 4
FILE_IN_CAB: MEMORY.DMP
FAULTING_THREAD: ffffc10fd1ae5080
VIDEO_TDR_CONTEXT: dt dxgkrnl!_TDR_RECOVERY_CONTEXT ffffc10fcd40d010
Symbol dxgkrnl!_TDR_RECOVERY_CONTEXT not found.
PROCESS_OBJECT: 0000000000000004
BLACKBOXBSD: 1 (!blackboxbsd)
BLACKBOXNTFS: 1 (!blackboxntfs)
BLACKBOXPNP: 1 (!blackboxpnp)
BLACKBOXWINLOGON: 1 (!blackboxwinlogon) (!blackboxwinlogonnotify)
PROCESS_NAME: System
IP_IN_PAGED_CODE:
nvlddmkm+195a350
fffff804e49da350 488b05e95ca1ff mov rax,qword ptr [nvlddmkm+0x1370040 (fffff804e43f0040)]
STACK_TEXT:
ffff830333d56a18 fffff8042dde7d5e : 0000000000000116 ffffc10fcd40d010 fffff804e49da350 ffffffffc000009a : nt!KeBugCheckEx
ffff830333d56a20 fffff8042dd98404 : fffff804e49da350 ffffc10fccc888a0 0000000000002000 ffffc10fccc88960 : dxgkrnl!TdrBugcheckOnTimeout+0xfe
ffff830333d56a60 fffff8042dd90f3c : ffffc10fcccef000 0000000001000000 0000000000000004 0000000000000004 : dxgkrnl!ADAPTER_RENDER::Reset+0x174
ffff830333d56a90 fffff8042dde7485 : 0000000000000100 ffffc10fcccefa70 00000000cf777040 0000000000000000 : dxgkrnl!DXGADAPTER::Reset+0x4dc
ffff830333d56b10 fffff8042dde75f7 : fffff80422125440 0000000000000000 0000000000000000 0000000000000200 : dxgkrnl!TdrResetFromTimeout+0x15
ffff830333d56b40 fffff804216418f5 : ffffc10fd1ae5080 fffff8042dde75d0 ffffc10fc0cb0cd0 0000000000000000 : dxgkrnl!TdrResetFromTimeoutWorkItem+0x27
ffff830333d56b70 fffff8042175d6e5 : ffffc10fd1ae5080 0000000000000080 ffffc10fc0c92040 0000000000000080 : nt!ExpWorkerThread+0x105
ffff830333d56c10 fffff804218065c8 : ffff9400558e5180 ffffc10fd1ae5080 fffff8042175d690 858d08421d21c688 : nt!PspSystemThreadStartup+0x55
ffff830333d56c60 0000000000000000 : ffff830333d57000 ffff830333d51000 0000000000000000 0000000000000000 : nt!KiStartSystemThread+0x28
SYMBOL_NAME: nvlddmkm+195a350
MODULE_NAME: nvlddmkm
IMAGE_NAME: nvlddmkm.sys
STACK_COMMAND: .process /r /p 0xffffc10fc0c92040; .thread /r /p 0xffffc10fd1ae5080 ; kb
FAILURE_BUCKET_ID: 0x116_IMAGE_nvlddmkm.sys
OS_VERSION: 10.0.19041.1
BUILDLAB_STR: vb_release
OSPLATFORM_TYPE: x64
OSNAME: Windows 10
FAILURE_ID_HASH: {c89bfe8c-ed39-f658-ef27-f2898997fdbd}
Followup: MachineOwner
Welcome to the NVIDIA Developer forums. This community serves the developer ecosystem.
For consumer issues, please visit the GeForce forums.
Best regards.
