My understanding is that the Jetson Nano is also made in Taiwan. If that’s the case, does anyone know how to specifically source Taiwan-manufactured boards?
Please check Jetson FAQ | NVIDIA Developer
@kayccc - Yes, I’ve checked that document. I think the issue is that I’m specifically interested in the Jetson Nano. It says that the Jetson Nano is made in Taiwan and in China. There is not a origin specific SKU for the nano. Does anyone know how to source a Jetson Nano from Taiwan?
Please contact with local distributor.
I have contacted the suppliers they say they have no control over which boards they have and at the moment they all have Chinese boards.
Even if I were to use an origin specific SKU (like 900-13767-0000-0A0) NVIDIA lists one supplier for the US. That supplier claims they do not carry 900-13767-0000-0A0 manufactured in the USA. They only carry 900-13767-0000-000 which is made in China.
So, I have contacted the local distributor. Is there a supplier outside the US I should contact to order either Taiwan-made Jetson Nanos or US-made Jetson Orin NX 16BG boards?
If the FAQ lists Origin for a particular Part Number as X or Y, there is no way to order just X or just Y for that PN. Example: Jetson Nano module has Origin “China or Taiwan.”
We have set up a separate PN for a few of those modules so you can be sure of the Origin. However, those PNs have specific terms of sale: they are built to order and there is a Minimum Order Quantity. This is why you need to “contact your local distributor” to initiate the purchase.
Any Jetson distributor can arrange that order for you. It’s a problem if you call the distributor and the representative doesn’t understand how to place such an order. Give it another try and report back if still no luck – we’ll reach out from the other end if needed.
