Hardware / software
- Module: NVIDIA Jetson AGX Orin 64GB, Part Number
699-13701-0005-502 K.0 - Carrier board: Custom ConnectTech
- JetPack 5.1.4 / L4T 35.6.0, kernel
5.10.216-tegra, Ubuntu 20.04 - BIOS:
202210.5-78a917ec-dirty
Summary
On a small fraction of boots (first occurrence across 100s of systems), the system comes up in a bad state:
timedatectlreportsFailed to query server: Connection timed outsudo hwclock -r -vreports eitherNo usable clock interface found, or it opens/dev/rtc0but thenselect() to /dev/rtc0 to wait for clock tick timed out
/dev/rtc0 and the /dev/rtc -> rtc0 symlink are present and correct, so this is not a missing device node.
Root cause appears to be an interrupt storm from the nvvrs-pseq PMIC
dmesg on a bad boot:
irq 244: nobody cared (try booting with the "irqpoll" option)
CPU: 0 PID: 152 Comm: irq/244-nvvrs-p Tainted: G OE 5.10.216-tegra #1
Hardware name: NVIDIA Jetson AGX Orin/Jetson, BIOS 202210.5-78a917ec-dirty 10/10/2024
handle_fasteoi_irq+0xc0/0x170
irq_finalize_oneshot.part.0+0x70/0x110
irq_thread_fn+0x68/0xb0
irq_thread+0x164/0x2e0
handlers:
[<...>] irq_default_primary_handler threaded [<...>] regmap_irq_thread
Disabling IRQ #244
So IRQ 244 is owned by the nvvrs-pseq PMIC, and it ends with the kernel disabling the line, which matches the RTC/timedatectl failures and the system hang.
Separately, on every hwclock -r we see the following, but it appears on healthy units too, so we believe it is normal and not the fault itself:
nvvrs_pseq 4-003c: CAUTION: interrupt status reg:0x10 set to 0x8
nvvrs_pseq 4-003c: Clearing interrupts
We compared a bad unit against two known-good units: the PMIC/RTC behaviour is identical on all of them, which suggests this is a latent software issue rather than a faulty module.
What we found
These threads describe what looks like the same issue and an engineer-provided patch by removing a stray mutex_unlock(&info->lock); from nvvrs_rtc_update_alarm_reg() in drivers/rtc/nvvrs-pseq-rtc.c:
The driver is built into our kernel (=y, no loadable .ko), so we cannot determine from userspace whether our build already contains this fix (probably not though).
Questions
- Is this
nvvrs-pseq-rtcfix included in any officially released JetPack? Or does it still exist only as the forum patch above? - Does this
nvvrs-pseq-rtcmutex issue match our symptoms (IRQ 244 storm and RTC/timedatectlfailure)? Is it the likely root cause, or should we be looking elsewhere? - Is there a recommended interim mitigation for fielded systems while we prepare a patched kernel image?
Thanks in advance.
