Because I built an image based on ROS2 jazzy using docker, and then needed to use yolov11 on this basis. However, ROS2 jazzy uses python 3.12
DavidDDD
3
Please build the torch using the source code.
Please refer to below topic:
Related topics
| Pytorch for JetPack6.0 | 3 | 1064 | May 11, 2024 | |
| PyTorch for Jetpack 6.0 | 3 | 2412 | May 15, 2024 | |
| Problem to install PyTorch on Jetson Nano Orin | 6 | 1779 | October 14, 2024 | |
| Looking for PyTorch compatible with cuda and jetpack 6.2 | 11 | 901 | November 17, 2025 | |
| Looking for a pre-built wheel for PyTorch for Jetson Nano | 2 | 2314 | February 24, 2025 | |
| Pytorch 2.7.1 for jetpack 6.2.1 on jetson orin nano | 2 | 370 | August 13, 2025 | |
| Pytorch with CUDA support Jetson Orin Nano | 3 | 3006 | May 14, 2024 | |
| Installing Pytorch & Torchvision for Jetpack 6.2 and cuda 12.6 | 6 | 2809 | October 2, 2025 | |
| Torch version for Jetson Nano, Jetpack 6.0 and how to install it? | 2 | 246 | May 16, 2025 | |
| Can i get torch torchaudio torchvision wheel file link corresponding to jetson 6.2 python 3.12? my cuda version is 12.6 | 1 | 163 | December 30, 2025 |
