I hope to have my nvidia GPU 100% for computation, and use the integrated intel graphics for display.
Now under Ubuntu 19.04, I can achieve this by booting with Prime set to Intel, and run “prime-select nvidia” to turn the nvidia GPU on. However, I have to manually turn it back to Intel every time I turn my desktop off and vice versa.
I wonder if there’s an easy way to have Prime set to Intel and Nvidia GPU power on automatically at the same time?
I am using the NVIDIA P5000 VPX form factor for computing and Intel graphics for display.
When I run CUDA graphics example I get the following error:
[tre@localhost bindlessTexture]$ ./bindlessTexture
CUDA bindlessTexture Starting…
GPU Device 0: “Pascal” with compute capability 6.1
CUDA error at bindlessTexture.cpp:240 code=999(cudaErrorUnknown) “cudaGraphicsGLRegisterBuffer(&cuda_pbo_resource, pbo, cudaGraphicsMapFlagsWriteDiscard)”
The non Graphic Cuda Samples are working correctly.
