Is there a way to detect and track objects within multiple ROIs of the frame?
I’m working on a use case to detect and track objects from a live video feed, however i have ROI’s within the frame where i need to detect and track objects within these ROI’s. Is it doable using jetson.inference and jetson.utils?
Hi @sairaghava2013, you can use the cudaCrop() function from jetson_utils to crop the image to the ROI you want: https://github.com/dusty-nv/jetson-inference/blob/master/docs/aux-image.md#cropping
There is an example of using this here:
Note that DeepStream has more advanced and optimized tracking that you may want to investigate using as well.
