Is there a way to print RAW image buffer in deepstream source code? I am using deepstream-test3.c code for reference
**• Hardware Platform (Jetson / GPU)**GPU RTX 2060
• DeepStream Version 5.0
• TensorRT Version 7.0.0
• NVIDIA GPU Driver Version (valid for GPU only) 460
• Issue Type( questions, new requirements, bugs) question
I want to print Raw image data read from source file for debugging. How to achieve that?
Do you mean you want to dump raw RGB(YUV) data from the sources? If so, please add filesink plugin after your source. filesink
You can add it in create_source_bin()
No, not save the frame to a file but print the matrix in console or file., the Image array.
Please refer to the sample in /opt/nvidia/deepstream/deepstream/sources/gst-plugins/gst-dsexample, how to read the surface into opencv matrix.
