Is there an uncomplicated method to support USB to Serial adapters using a PL-2303 chipset?
I have tried a couple of different vendor cables, and the PL-2303 and while the part is noticed by dmesg, there is device showing up in /dev or any other commend in
[34944.599954] usb 1-2.3: new full-speed USB device number 6 using tegra-xusb
[35797.371281] usb 1-2.3: USB disconnect, device number 6
[35803.997353] usb 1-2.3: new full-speed USB device number 7 using tegra-xusb
I do not decode the journal ell yet, but it seems to be a mismatch on device function
[35406.253021] audit: type=1326 audit(1756399720.378:8): auid=1000 uid=1000 gid=1000 ses=3 subj=? pid=8196 comm=“chrome” exe=“/snap/chromium/3219/usr/lib/chromium-browser/chrome” sig=0 arch=c00000b7 syscall=444 compat=0 ip=0xffff969d1c28 code=0x50000
lsusb identifies it as
Bus 001 Device 007: ID 067b:23a3 Prolific Technology, Inc. USB-Serial Controller
I have seen a post about not seeing output from a USB to serial, In this case I do not have a system device to connect to, or ask STTY for parameters.
Another post mentions a long process to include the PL-2303 device by pre-processor command and then rebuild the kernel. And also recommends against doing so.
I would think that the tegra release should be able to match what my PC version of 22.04 does and use this device.
Suggestions are appreciated.
Just to make sure I am looking at the right question, is this case one of plugging the USB into the Jetson and looking for the device special file existence as a result of that specific PL-2303 device? This is what I’m going to base my answer on.
On the Jetson in question, what do you see from:
zcat /proc/config.gz | grep -i 'pl2303'
sbonomi@AE250-1:~$ zcat /proc/config.gz | grep -i ‘pl2303’
#CONFIG_USB_SERIAL_PL2303 is not set
sbonomi@AE250-1:~$
The simplest thing would be to create a kernel module and then copy that file into place. What do you see from “uname -r”? It should be something ending in “-tegra”. Also, what is your current L4T release from “head -n 1 /etc/nv_tegra_release”?
Instructions for building this depend on whether you’ll be building natively on the Jetson, versus building on a Linux host PC. Both work fine, but the disk space required sometimes exceeds what people have on their Nano. For the Nano, what is the output from “df -H -T”? If you paste that into the forum thread and then highlight it and mark it as code (the “</>” icon), then it’ll preserve formatting.
Then note the URL this points for for your L4T release:
https://developer.nvidia.com/linux-tegra
(this is the best place to download any source for the kernel, but it depends on release)
My version is 5.15.148-tegra
Filesystem Type Size Used Avail Use% Mounted on
/dev/nvme0n1p1 ext4 2.0T 13G 1.9T 1% /
tmpfs tmpfs 8.3G 78M 8.2G 1% /dev/shm
tmpfs tmpfs 3.3G 28M 3.3G 1% /run
tmpfs tmpfs 5.3M 4.1k 5.3M 1% /run/lock
/dev/nvme0n1p10 vfat 67M 113k 66M 1% /boot/efi
tmpfs tmpfs 1.7G 144k 1.7G 1% /run/user/1001
I think I am well set for memory on the Nano. I can add another TB or two if needed.
The release is current:
R36 (release), REVISION: 4.4, GCID: 41062509, BOARD: generic, EABI: aarch64, DATE: Mon Jun 16 16:07:13 UTC 2025
From what I infer, the only solution is to rebuild the system with the 2303 enabled.
I have on occasion built a couple of yocto images and decades ago I build the slackware 2.4 system for a junkyard box I found. The support tools have changed a bit over the years.
Since your version is 5.15.148-tegra, then keep in mind that for any kernel build, if you use the same source code release and same base configuration, then you would be able to build a module which loads correctly on that running kernel. The configuration consists of any integrated feature (“=y” in a configuration), and CONFIG_LOCALVERSION is also considered. If those parts of a build do not match, then you can expect problems loading modules you’ve built separately. Restated, if you start with the original kernel configuration which is currently running, including setting “CONFIG_LOCALVERSION” to “-tegra” (which is what “uname -r” output was for determining), then you can add a module (such as “CONFIG_USB_SERIAL_PL2303”) and that module should work in the existing kernel without need to install everything. That’s basically a simple file copy to the right location.
For kernels prior to the one in L4T R36.x a default config of “make tegra_defconfig” is the start point; for your kernel in R36.x a default config is “make defconfig” (these are kernel make arguments); one would then use something like “make nconfig” or “make menuconfig” to change the symbol CONFIG_LOCALVERSION to “-tegra”, and add “CONFIG_USB_SERIAL_PL2303=m”. Or you could copy and decompress “/proc/config.gz” and use that as the starting config (which works even if you are not using the default config). Lots of ways to do this, just ask which method you want to use.
Download the sources for that L4T release, get all of the kernel related sources within that group of sources (it is a tar archive within a tar archive, and there may be more than one kernel source whereby one is the public main source, and other out of tree source could be in a separate package). You can build natively since your NVMe has a lot of spare space, but do not install with any make install type of command. Or cross compile on your host PC.
More specifically, to extract just the kernel packages:
  • To see kernel packages:
    tar -jtvf ./public_sources.tbz2 | grep kernel
  • To extract a specific source within the sources (example for Linux_for_Tegra/source/kernel_src.tbz2):
    tar xjf public_sources.tbz2 Linux_for_Tegra/source/kernel_src.tbz2
  • Then extract kernel_src.tbz2:
    tar xvf public_sources.tbz2
  • You might be extracting others as well, e.g., Linux_for_Tegra/source/kernel_oot_modules_src.tbz2. Each will unpack into a “Linux_for_Tegra/source/...” subdirectory. The flash software (if you are compiling on the host PC and not on the Jetson) is actually all in a “~/nvidia/nvidia_sdk/JetPack...version.../Linux_for_Tegra/” subdirectory, and so if you extract with Linux_for_Tegra/ as a child directory, then the content will “just be in the right place” for any documented cross compile information. You won’t care about this if you build directly on your Jetson; you’ll still end up extracting yet more files from “Linux_for_Tegra/sources/” (do this for any “kernel” file that isn’t a sha1sum):
    • tar xvf kernel_src.tbz2
      (it is yet another tar archive within an archive)
    • You now have “Linux_for_Tegra/source/kernel/kernel-jammy-src/”, and this is where most work will be from.
More specifically for actual build configuration (after configuration actual build changes depending on where you compile from: natively on the Jetson versus PC cross compile). Assuming you have all of the build requirements in place, then this sets default configuration (there may be variations depending on build platform, so this is just a summary…add in this thread if you want to compile from Jetson versus from PC to get proper details, this is just to get an idea of steps):
  • make defconfig (if you were using L4T R35.x or earlier it would be tegra_defconfig)
  • make nconfig, search for symbol (F8 searches when using nconfig build target) “CONFIG_LOCALVERSION” or “LOCALVERSION”, which shows it is in “General Setup”, then hit the enter key for () Local version - append to kernel release, and set it to “-tegra”.
  • Now search for symbol CONFIG_USB_SERIAL_PL2303. You will find it here (IMPORTANT: The manufacturer of this serial UART is Prolific; the name within this configuration to look for is “USB Prolific 2303 Single Port Serial Driver”:
      -> Device Drivers
        -> USB support (USB_SUPPORT [=y])
          -> USB Serial Converter support (USB_SERIAL [=m])
  • Use the “m” key to enable this as a module.
  • Configuration is now complete if Save. There will be a .config file generated, you can keep this somewhere safe, maybe rename the copy to “config-5.15.148-tegra-pl2303”. Depending on where you plan to compile this file can simply be dropped in place and used as your config without going through all of the above steps. If you do this once it is actually far more simple than this explanation, and having the config already makes it even simpler.
Where will you compile from, native or cross compile?
I am (intending to) going to compile natively. starting from /home/user/projects/Linux_for_Tegra
I have collected and unpacked the public_source kernel elements.
and I have found a .config file to change PL2303 to “M”
and I also allowed CONFIG_U_SERIAL_CONSOLE=Y
However, the PL2303 change in .config is not sticking. deeply hidden in the nconfig package
For some reason running the script relocate-sdk.sh doe not seem to have any useful effect.
The active image is built with 11.3, my sysem has 11.4. Downloading the tarball and unpacking gives me executable that identify as 11.03 with –version. After the script, I am getting a can of link spaghetti that reports Exec format error when commanding aarch64–glibc–stable-2022-08-1/usr/bin/aarch64-linux-gcc –version.
Cross compiling requires some environment setup, it isn’t just a case of using a different compiler. I have not used that script though, I suppose it is probably part of the shell scripts NVIDIA provides with the source for convenience. Do you want to cross compile from the host PC, or natively on the Jetson? Also, do you want to set up for some removable media, or just from some available location? It is quite difficult to give advice for all cases. If you want to have something like a thumb drive or external USB drive which can be moved around among the different Jetsons the answer would be different than building directly on them without removable media, and also different from cross compile on the host PC.
It is my intent to compile on the Jetson. The compiler question is because you told me the R36.4.4 build was crated with 11.3.0 and I should use the same compiler if it is to be a drop in replacement.
I suceeded in creating an image last night, ~40 MB and when I dropped it into the Boot directory and booted I did not get any activity at all. rebooting with the SD card and copying the image from it to my NVMe will get me back to trying to get a working build
Check this out:
https://forums.developer.nvidia.com/t/cannot-use-usb-devices/343707/10
All of that is for setting up a thumb drive or other external drive someone expects to use on different Jetsons.
The really big question is how did you configure? You should start with an unconfigured kernel, and choose an empty location for all temporary output. That is what a lot of the above URL is about, although it is way more detailed than just basic instructions. Keep in mind that if you build the kernel Image itself, and if that Image has any change in integrated features (a change to an “=y”), then most likely you’ve invalidated all modules, including those in the initrd. The install procedure for that is far different than the simple file copy of building a module intended to load into the original kernel.
If you have already replaced your kernel with one which did not exactly match the earlier kernel’s integrated features, then you probably have to start over.
Note that it is almost always safer to add a boot entry for a new kernel with a new name and other details, and leave the old kernel in place. If the new one fails, then you have a backup boot plan. If the system fails now, then you might need to flash again (you could clone first, or if it is on an SD card, simply fix it on a host PC by putting the original kernel back in place).
Also, booting from SD card on a dev kit Orin Nano is quite different than booting from an NVMe. The boot chain is somewhat custom, and so you can’t just interchange bootable devices the same way you could on a computer which has an actual hardware BIOS.
Let me know what the situation is.
For the original NVMe failure, I booted from a newly flashed SD card and then copied the Image to the nVMe device which returned that to usable. I then flashed a new NVME with a fresh download of JetPack and made about 160 GB available on my desktop machine to build there instead. I need to add in a Marvel AQ113 device to give me a faster Ethernet over USB3 option and I expect to use a custom dtsi file enabling a couple of the 3.3V compatability options on GPIOs.
Is there no need for more PL2303 information? I just don’t want to leave the thread hanging if the NVMe success was not the full solution.
Getting the NVME running again was not success, it was a band-aid over the non-running Image I built.
I need to see what I need to do to build a custom image on my laptop and then see if that can be flashed using Jetson. The custom HW is now a week away and my expectation that anything that runs on the 20.04 laptop would also run on the 20.04 GPU was perhaps a bit overoptimistic.
Just keep in mind that the boot chain differs between booting to an NVMe versus an SD card (for dev kits) and versus eMMC (for commercial modules). The location where the kernel Image is stored may differ. The location where the modules are found to load into that Image may also differ. If you set up boot to be verbose (e.g., remove any “quiet” from “/boot/extlinux/extlinux.conf”), and probably flash using the debug version of boot chain, you will get a lot more detail in serial console logs. Saving that log just one time when it works and prior to updating the kernel will tell you exactly where the kernel is from, where the device tree is from, so on. Once you get into the initrd the kernel itself is already loaded, and the modules could still come from different devices. If you replace the wrong Image, or if you change modules not loading to the expected Image, then I’m sure there will be a lot of mysterious time-consuming issues. Getting a serial console boot log (with enough verbosity that it tells you where the kernel is loaded from) could save a lot of work and time.
Overall, just be careful to leave any kernel Image in place, and if you add a new kernel, then rename the new kernel something like “Image-pl2303”, rename the device tree (if it changes; it may not change) with something like a “-pl2303” suffix, and add an alternate boot entry named after pl2303. Or, if you are only adding a module, then you can skip that and copy just the one module and leave everything else in place; if the module does not appear to be available after boot, then it might be loading modules from a different device (e.g., some content might load from eMMC if it is present depending on setup, or from the initrd…the point is to use a log to keep a record of where it is from and you’ll not need to create that log again and you’ll always get the right location).
it might be a bit less entertaining, but identifying which bit of the openssl source is required could be helpful. I expect it to need 3.0,2 but that is a random guess. I do not find openssl mentioned other than it is required, and a make crashes without it. The source files needed (.h) are made locally (from *.h.in) which is another issue left for the student. Having the tarball for the source files generate a 505 equivalent from the AI makes the issue a bit muddier.
OpenSSL would seem to be unrelated to the PL2303, but was this an issue in loading a driver? If so, then adding any new item in configuration of kernel build (after starting with matching the running kernel) would add this as well if using a context-aware kernel configuration editor, e.g., make targets of menuconfig or nconfig. If you do add something like the PL2303, while in that editor, if you’ve checked “m” for module, then it should list any other dependencies (which it will enable); those dependencies would also have to be copied in and not just the PL2303 (but I’d be surprised if it wanted OpenSSL-related content). I suppose a more specific question would be “what triggered a request for that OpenSSL content?”.
