I am using the Isaac ROS Visual SLAM and Isaac ROS Nvblox repositories for a project where each package requires different parameters, and the goal is to configure everything using only terminal commands. However, I have had to add and modify scripts because it seems there’s no way to pass some parameters directly from the terminal when using ros2 launch
For instance, I can run Isaac ROS VSLAM using only odometry with the command:
ros2 launch isaac_ros_visual_slam isaac_ros_visual_slam_realsense.launch.py enable_localization_n_mapping:=False
On the other hand, to preserve the mesh created by Isaac ROS Nvblox, I need to modify the parameter decay_tsdf_rate_hz = 0
in the nvblox_base.yaml
file. Since the objective is to rely solely on terminal commands, I had to create a new nvblox_base.yaml
file called nvblox_base_3D.yaml
and corresponding launch files like nvblox_3D.launch.py
and realsense_3D.launch.py
based on existing examples.
I did this because I couldn’t find an argument to change this parameter directly from the terminal. Maybe that’s the reason I cannot use Nav2 with realsense?
Is there a simpler way to handle this, or is this approach correct?
