iSer over SR-IOV.
I’m running into an issue initiating an iSer connection to a iSer enabled storage server. The connections times out when the initiator tries to log into the target. The iser initiator is a KVM Guest running Ubuntu 18.04 with all latest updates. And my target is a bare metal box also with Ubuntu 18.04 with all updates applied.
I have successfully configured the KVM guest using SR-IOV using this Mellanox Knowledge article :
https://community.mellanox.com/s/article/howto-configure-sr-iov-for-connectx-3-with-kvm–infiniband-x#jive_content_id_Manage_the_VM
I’ve successfully verified RDMA connectivity between the initiator and target using ib_send_bw, udaddy, rdma_server, rdma_client.
Output of running : ib_send_bw -i 2 10.0.X.X
Send BW Test
Dual-port : OFF Device : mlx4_0
Number of qps : 1 Transport type : IB
Connection type : RC Using SRQ : OFF
TX depth : 128
CQ Moderation : 100
Mtu : 2048[B]
Link type : IB
Max inline data : 0[B]
rdma_cm QPs : OFF
Data ex. method : Ethernet
local address: LID 0x07 QPN 0x0d64 PSN 0xff3d62
remote address: LID 0x04 QPN 0x0219 PSN 0xf01f6d
#bytes #iterations BW peak[MB/sec] BW average[MB/sec] MsgRate[Mpps]
65536 1000 3718.02 3716.43 0.059463
I’ve also verified that the target is setup as iSer :
/iscsi/iqn.20…0.XX.XX:3260> ls
o- 10.0.XX.XX:3260 … [iser]
Unfortunately, anytime I try to login into the target from the initiator, it just hangs until it timeouts :
Logging in to [iface: default, target: iqn.2003-01.org.setup.lun.test, portal: 10.0.XX.XX,3260] (multiple)
iscsiadm: Could not login to [iface: default, target: iqn.2003-01.org.setup.lun.test, portal: 10.0.XX.X,3260].
iscsiadm: initiator reported error (8 - connection timed out)
iscsiadm: Could not log into all portals
I’ve verified that the initiator works if the transport mode is setup to tcp. It only does not work when it’s set to iser.
I have even verified that ib_iser has been loaded on both servers. I have managed to get iSer connection established from other bare metal initiators to this target. The only difference is that initiator that I’m now using is a Virtual PCIe device in KVM.
I have MLNX_OFED_LINUX-4.6-1.0.1.1 running on both ends.
Can someone please help me identify what I’m missing here ?
Thanks in advance.
Hi Gurvinderpal,
As I have no ability to parse logs and run a comprehensive root cause analysis, and since you have not mention the explicit Mellanox nics & firmware you are using on the initiator & target, then I can only suggest the followings:
  1. Check that the SR-IOV configuration is configured properly and that you haven’t missed some params setting.
  2. Monitor the /var/log/messages & dmesg outputs to understand what the actual connection issue is.
  3. Use Mellanox article to ensure you have configured iSER (ini & tgt) as per Mellanox best practice
https://community.mellanox.com/s/article/howto-configure-tgt-enabled-with-iser-transport-for-ubuntu
Other than that, if you still need some higher debugging level from Mellanox, don’t hesitate to approach support@mellanox.com
Best Regards,
Chen
Hello Chen,
I apologize for not getting a change to respond earlier.
Regarding your questions:
I have verified that SR-IOV is configured per the documents I available online. This is the output when I reboot the server and look at the dmesg out:
[Sat Aug 24 20:48:42 2019] mlx4_core: Mellanox ConnectX core driver v4.6-1.0.1
[Sat Aug 24 20:48:42 2019] mlx4_core: Initializing 0000:00:10.0
[Sat Aug 24 20:48:42 2019] mlx4_core 0000:00:10.0**: Detected virtual function - running in slave mode**
[Sat Aug 24 20:48:42 2019] mlx4_core 0000:00:10.0**: Sending reset**
[Sat Aug 24 20:48:42 2019] mlx4_core 0000:00:10.0**: Sending vhcr0**
[Sat Aug 24 20:48:42 2019] mlx4_core 0000:00:10.0**: Requested number of MACs is too much for port 1, reducing to 64**
[Sat Aug 24 20:48:42 2019] mlx4_core 0000:00:10.0**: HCA minimum page size:512**
[Sat Aug 24 20:48:42 2019] mlx4_core 0000:00:10.0**: Timestamping is not supported in slave mode**
[Sat Aug 24 20:48:42 2019] mlx4_core: device is working in RoCE mode: Roce V1
[Sat Aug 24 20:48:42 2019] mlx4_core: UD QP Gid type is: V1
[Sat Aug 24 20:48:42 2019] <mlx4_ib> mlx4_ib_add: mlx4_ib: Mellanox ConnectX InfiniBand driver v4.6-1.0.1
[Sat Aug 24 20:48:42 2019] <mlx4_ib> check_flow_steering_support**: Device managed flow steering is unavailable for IB port in multifunction env.**
[Sat Aug 24 20:48:42 2019] <mlx4_ib> mlx4_ib_add: counter index 20 for port 1 allocated 0
[Sat Aug 24 20:48:42 2019] <mlx4_ib> mlx4_ib_add: counter index 21 for port 2 allocated 0
[Sat Aug 24 20:48:42 2019] mlx4_core 0000:00:10.0**: mlx4_ib: multi-function enabled**
[Sat Aug 24 20:48:42 2019] mlx4_core 0000:00:10.0**: mlx4_ib: operating in qp1 tunnel mode**
[Sat Aug 24 20:48:42 2019] pps_core: LinuxPPS API ver. 1 registered
[Sat Aug 24 20:48:42 2019] pps_core: Software ver. 5.3.6 - Copyright 2005-2007 Rodolfo Giometti giometti@linux.it
[Sat Aug 24 20:48:42 2019] PTP clock support registered
[Sat Aug 24 20:48:42 2019] mlx4_en: Mellanox ConnectX HCA Ethernet driver v4.6-1.0.1
[Sat Aug 24 20:48:42 2019] card: mlx4_0, QP: 0xad0, inline size: 120
[Sat Aug 24 20:48:42 2019] card: mlx4_0, QP: 0xad8, inline size: 120
[Sat Aug 24 20:48:42 2019] IPv6: ADDRCONF(NETDEV_UP): ib1: link is not ready
[Sat Aug 24 20:48:42 2019] IPv6: ADDRCONF(NETDEV_CHANGE): ib1: link becomes ready
[Sat Aug 24 20:49:24 2019] random: crng init done
[Sat Aug 24 20:49:24 2019] random: 7 urandom warning(s) missed due to ratelimiting
[Sat Aug 24 21:16:35 2019] iscsi: registered transport (iser)
[Sat Aug 24 21:16:36 2019] scsi host3: iSCSI Initiator over iSER
Also I’ve be able to successfully run ib_send_bw / ib_read_bw between the initiator and target hosts and running lspci give the following output :
00:10.0 Infiniband controller: Mellanox Technologies MT27500/MT27520 Family [ConnectX-3/ConnectX-3 Pro Virtual Function]
Please advise if there are other parameters that I need to check to verify functionality.
Regarding the iSer target, I have been able successfully connect to that target from the same hypervisor.
On the hypervisor, when I run iscsiadm -m session, I get the following :
root@pve:~# iscsiadm -m session
iser: [1] 10.1.1.1:3260,1 iqn.1986-03.com.sun:02:a7488577-9989-40c0-9aaa-e2b23c93b387 (non-flash)
root@pve:~#
Also running lsscsi, it lists the iser target luns :
[13:0:0:0] disk SUN COMSTAR 1.0 /dev/sds
[13:0:0:1] disk SUN COMSTAR 1.0 /dev/sdt
Getting back to the KVM guest, the output of dmesg when executing iscsiadm -m node -l, the only output that get added to /var/messages is :
[Sat Aug 24 21:57:53 2019] scsi host3: iSCSI Initiator over iSER
And there is no other output.
But the error on the login process is as follows :
Logging in to [iface: default, target: iqn.1986-03.com.sun:02:a7488577-9989-40c0-9aaa-e2b23c93b387, portal: 10.1.1.1,3260] (multiple)
iscsiadm: Could not login to [iface: default, target: iqn.1986-03.com.sun:02:a7488577-9989-40c0-9aaa-e2b23c93b387, portal: 10.1.1.1,3260].
iscsiadm: initiator reported error (11 - iSCSI PDU timed out)
But there are no other messages in /var/messages (dmesg).
I am using ConnectX-3 cards on both hosts. Both cards has firmware 2.42.5000 :
CA ‘mlx4_0’
CA type: MT4100
Number of ports: 2
Firmware version: 2.42.5000
Hardware version: 1
Please advise how else I can do to debug this.
Thanks in advance.
