Dear all
issue Delta between current and previous frame (Vslam) in issac sim
I use intel 455 USD file in isaac sim
this my file launch file
Dear all
I’m having the same issue … the realsense outputs are not the probelm though
Which version of Isaac Sim are you using?
Could you please check the camera message publish rate from the camera? Do it have normal frequency (say ~30 Hz)?
If the message from the camera has normal publish rate, could you please try to set the image_qos
of visual_slam_node
to DEFAULT
? The default value of image_qos
in visual_slam_node
is SENSOR_DATA
I will close this topic since there is no new replies. But please feel free to open a new topic if the issue persists.
