How do you take pictures inside an existing environment in isaac sim 4.5.0 without it crashing?
I’m using isaac sim 4.5.0 and am attempting to record a data set but my sim keep crashing when I attempt to take a picture. Here is the code I’m using:
Import the omniverse kit extension system instead of creating a new SimulationApp
import omni.kit.app
import omni.usd
Import other necessary modules
from isaacsim.sensors.camera import Camera
import numpy as np
import matplotlib.pyplot as plt
import isaacsim.core.utils.numpy.rotations as rot_utils
import os
Get the existing stage that’s already loaded in the running Isaac Sim
Add a camera to the existing stage
camera = Camera(
prim_path=“/World/camera”,
position=np.array([0.0, 0.0, 25.0]),
frequency=20,
resolution=(256, 256),
orientation=rot_utils.euler_angles_to_quats(np.array([0, 90, 0]), degrees=True),
Initialize the camera in the existing environment
camera.initialize()
Wait for a few frames to make sure the camera is properly set up
import omni.kit.app
for i in range(5):
# This advances the render frame in the existing application
omni.kit.app.get_app().update()
Now capture the image
rgba_data = camera.get_rgba()
print(“RGBA data shape:”, rgba_data.shape)
rgb_data = rgba_data[:, :, :3] # Extract just the RGB channels
Save the image to file
output_path = os.path.expanduser(“~/isaacsim_current_environment_capture.png”)
plt.imsave(output_path, rgb_data)
print(f"Image saved to: {output_path}")
Optional: Clean up the camera when done
Note that we’re not closing the application since it was already running
camera.release()
I already have a custom environment created with a saved .USD file. I would like to take pictures of this environment with the Isaac sim camera.
Have you checked the log file for any error messages or warnings that might provide clues about the crash?
Hello!
Best regards,
