I am creating a standalone application that simulates a camera with an f-number of 2.8 (and therefore f_stop = 2.8
). I am following the OpenCV Rational Polynomial Example of this guide to do so however I am encountering a few issues.
The first issue is that the camera does not focus when set_lens_aperture
is set to any value other than 0 (i.e. disabled). Below I have attached 2 images, the first is with focusing disabled and the second is with the aperture set to what is recommended in the guide. I have tried values up to 10000 and effectively get the same image as the second image every time.
Setting lens aperture to 0 (disabling focusing)
280 (f_stop * 100.0 as suggested in documentation)
The second issue I am having is that a vignette is applied to an image when distortion coefficients are set, however this is not what the image would look like in real life.
The third issue I am having is that the frequency parameter of the camera class does not seem to do anything and so I am having to control the frequency by adjusting the Isaac Simulation Gate node in the SDGPipeline graph. This is the same as what is done in the example found at standalone_examples/api/omni.isaac.ros2_bridge/camera_periodic.py
Below is the code for the camera.
width, height = 612, 512
camera_matrix = [[605.4796091670199, 0.0, 305.6297619145443], [0.0, 605.6656786507847, 260.2272299567676], [0.0, 0.0, 1.0]]
distortion_coefficients = [-0.3818920627803916, 0.15178401791432322, -0.00017830161196350367, 0.0002184177735682275, 0.0, 0.0, 0.0, 0.0]
camera = Camera(
prim_path="/World/camera",
position=np.array([60.0, 60.0, 100]),
frequency=None, # Doesn't seem to do anything
resolution=(width, height),
orientation=rot_utils.euler_angles_to_quats(np.array([0, 90, 0]), degrees=True),
simulation_context.reset()
camera.initialize()
# Camera sensor size and optical path parameters. These parameters are not the part of the
# OpenCV camera model, but they are nessesary to simulate the depth of field effect.
# To disable the depth of field effect, set the f_stop to 0.0. This is useful for debugging.
pixel_size = 3.45 * 4 # multiplied by 4 as we have binning of 4 in x and y
f_stop = 2.8 # f-number, the ratio of the lens focal length to the diameter of the entrance pupil
focus_distance = 0.1 # in meters, the distance from the camera to the object plane
diagonal_fov = 77 # in degrees, the diagonal field of view to be rendered
((fx,_,cx),(_,fy,cy),(_,_,_)) = camera_matrix
horizontal_aperture = pixel_size * 1e-3 * width
vertical_aperture = pixel_size * 1e-3 * height
focal_length_x = fx * pixel_size * 1e-3
focal_length_y = fy * pixel_size * 1e-3
focal_length = (focal_length_x + focal_length_y) / 2 # in mm
# Set the camera parameters, note the unit conversion between Isaac Sim sensor and Kit
camera.set_focal_length(focal_length / 10.0)
camera.set_focus_distance(focus_distance)
camera.set_lens_aperture(f_stop * 100.0)
camera.set_horizontal_aperture(horizontal_aperture / 10.0)
camera.set_vertical_aperture(vertical_aperture / 10.0)
camera.set_clipping_range(0.05, 1.0e5)
# Set the distortion coefficients
camera.set_projection_type("fisheyePolynomial")
camera.set_rational_polynomial_properties(width, height, cx, cy, diagonal_fov, distortion_coefficients)
keys = og.Controller.Keys
(camera_graph, _, _, _) = og.Controller.edit(
"graph_path": "/World/camera/camera_graph",
"evaluator_name": "push",
"pipeline_stage": og.GraphPipelineStage.GRAPH_PIPELINE_STAGE_ONDEMAND,
keys.CREATE_NODES: [
("onTick", "omni.graph.action.OnTick"),
("createViewport", "omni.isaac.core_nodes.IsaacCreateViewport"),
("getRenderProduct", "omni.isaac.core_nodes.IsaacGetViewportRenderProduct"),
("setCamera", "omni.isaac.core_nodes.IsaacSetCameraOnRenderProduct"),
("cameraHelperRgb", "omni.isaac.ros2_bridge.ROS2CameraHelper"),
("cameraHelperInfo", "omni.isaac.ros2_bridge.ROS2CameraHelper"),
keys.CONNECT: [
("onTick.outputs:tick", "createViewport.inputs:execIn"),
("createViewport.outputs:execOut", "getRenderProduct.inputs:execIn"),
("createViewport.outputs:viewport", "getRenderProduct.inputs:viewport"),
("getRenderProduct.outputs:execOut", "setCamera.inputs:execIn"),
("getRenderProduct.outputs:renderProductPath", "setCamera.inputs:renderProductPath"),
("setCamera.outputs:execOut", "cameraHelperRgb.inputs:execIn"),
("setCamera.outputs:execOut", "cameraHelperInfo.inputs:execIn"),
("getRenderProduct.outputs:renderProductPath", "cameraHelperRgb.inputs:renderProductPath"),
("getRenderProduct.outputs:renderProductPath", "cameraHelperInfo.inputs:renderProductPath"),
keys.SET_VALUES: [
("createViewport.inputs:viewportId", 1),
("setCamera.inputs:cameraPrim", [usdrt.Sdf.Path("/World/camera")]),
("cameraHelperRgb.inputs:frameId", "sim_camera"),
("cameraHelperRgb.inputs:topicName", "rgb"),
("cameraHelperRgb.inputs:type", "rgb"),
("cameraHelperInfo.inputs:frameId", "sim_camera"),
("cameraHelperInfo.inputs:topicName", "camera_info"),
("cameraHelperInfo.inputs:type", "camera_info"),
# Run the ROS Camera graph once to generate ROS image publishers in SDGPipeline
og.Controller.evaluate_sync(camera_graph)
simulation_app.update()
