The default coordinate system in Isaac Sim is Z-up, and the cameras in USD are always y-up.
As many issues in Forums have mentioned, when you creating a camera and set its world pose to dafult using set_world_pose(),
from omni.isaac.sensor import Camera
camera = Camera(
prim_path="/World/camera",
position=np.array([0, 0, 0]),
orientation=np.array([1, 0, 0, 0]),
camera.set_world_pose(np.array([0, 0, 0]), np.array([1, 0, 0, 0]))
my_world.step(render=True)
the camera pose is not aligned with the world frame in Isaac Sim, as it theoretically should be. Instead, the camera automatically rotates itself to +Y up. Specifically, the XYZ rotation is (90, -90, 0).
That causes a lot of troubles. For example, when you set the camera pose under the world frame, the camera will first be set to the correct transformation, an then apply a rotation automatically like mentioned above.
Solution
According to the discussion in the form, I think its a designed mechanism to automatically keep the same camera coordinate system(+Y up) across different USD files.
And if you want to cancel this “auto-rotation” effect, you can use camera_axes="usd" args in set_world_pose().
camera = Camera(
camera.set_world_pose(np.array([0, 0, 0]), np.array([1, 0, 0, 0]), camera_axes="usd")
This way, the default camera pose will aligned with the world frame.
I encountered the same problem when collecting data, and was troubled by this mechanism for a long time, It prevented me from collecting the camera pose correctly.
