Different methods for creating camera
I found two methods to create a camera.
Method 1:
from omni.isaac.core.utils.stage import get_current_stage
from pxr import UsdGeom
camera_path = "/Camera"
camera = get_current_stage().DefinePrim(camera_path, "Camera")
camera.GetAttribute("clippingRange").Set(Gf.Vec2f(0.001, 100.0))
camera.GetAttribute("focalLength").Set(30)
UsdGeom.Xformable(camera).AddTranslateOp().Set((0.0, 0.0, 1.0))
UsdGeom.Xformable(camera).AddRotateXYZOp().Set((0.0, 0.0, 0.0))
render_product = rep.create.render_product(camera_path, (512, 512))
Method 2:
camera = rep.create.camera(position=(0.0, 0.0, 1.0), rotation=(0, 0, 0))
render_product = rep.create.render_product(camera, (512, 512))
If I render an image with these two methods I obtain two different results. In fact if I place an object at (0.0, 0.0, 0.0) it can be seen with the first method whereas with the second method I get a black image with no objects rendered.
Is this because these two methods use two different conventions for transformations (translation and rotation)?
Hi @federico.domeniconi. Method 1 is using the USD API directly, Method 2 is using the Replicator API which wraps the USD API. Both are valid.
Without more information about you Stage, my guess is that the clippingRange is a play here. Here is the clipping range for the camera created with the Replicator code:
The camera() function does accept a keyword argument called clipping_range that might get you what you want:
camera = rep.create.camera(position=(0.0, 0.0, 1.0), rotation=(0, 0, 0), clipping_range=(0.001, 100.0))
Moving this to the SDG forum since this is good feedback for the Replicator team.
Is there a list of possible arguments for creating the camera?
Hopefully the Replicator team can jump in here and point to the documentation. I found it by looking at the implemention in the omni.replicator.core extension. I show how to do that here: 6 Crucial Tips For New NVIDIA Omniverse Developers - YouTube
@federico.domeniconi thank you for the question. The discrepancy is due to the coordinate system in Isaac defaulting to Z-up. Because cameras in USD are always y-up regardless of coordinate system, an additional rotation is added with Replicator to provide intuitive camera orientation that is consistent with the rest of Kit - the same rotation is added when creating a camera using the menu system (Create->Camera). You can cancel out the additional rotation in a Z-up stage by creating a camera as so:
camera = rep.create.camera(position=(0.0, 0.0, 1.0), rotation=(-90, -90, 0))
Hi, I found the similar problem with you, and I wrote a pose of it, hope it can help you out.
Part of the post is following.
Solution
According to the discussion in the form, I think its a designed mechanism to automatically keep the same camera coordinate system(+Y up) across different USD files.
And if you want to cancel this “auto-rotation” effect, you can use camera_axes="usd" args in set_world_pose().
from omni.isaac.sensor import Camera
camera = Camera(
    prim_path="/World/camera",
    position=np.array([0, 0, 0]),
    orientation=np.array([1, 0, 0, 0]),
camera.set_world_pose(np.array([0, 0, 0]), np.array([1, 0, 0, 0]), camera_axes="usd")
my_world.step(render=True)
This way, the default camera pose will aligned with the world frame.
You can find more detailed information about set_world_pose() in the API docs of it here.
