Hi there,
I’m trying to generate pose estimation dataset. I have own scene and object in USD file. I uploaded usd file and added semantic but the camera doesn’t capture anything.
How should I solve this problem?
Hi there,
I’ve attached code below:
from isaacsim.core.utils.stage import open_stage
from isaacsim.core.utils.prims import get_prim_at_path
from isaacsim.core.utils.semantics import add_labels
import omni.usd
usd_path = “/home/woojung/isaac/field/output/field_scene_fixed.usd”
open_stage(usd_path)
with rep.new_layer():
camera = rep.create.camera( focus_distance=400.0, focal_length=24.0, clipping_range=(0.1, 10000000.0), name="Cam")
render_product = rep.create.render_product(camera, (1024, 1024))
target_path = "/World/Strawberries/Strawberry_01/Geometry/Twig_d3/Flower_stalk_1/Receptacle"
strawberry = stage.GetPrimAtPath(target_path)
add_labels(strawberry, labels= \["strawberry"\], instance_name= "class")
rgb_writer = rep.WriterRegistry.get("BasicWriter")
rgb_writer.initialize(
output_dir=“/home/woojung/debug/rgb”,
rgb=True
rgb_writer.attach(\[render_product\])
with rep.trigger.on_frame(max_execs=10):
with camera:
rep.modify.pose(
position=rep.distribution.uniform((-500, 200, -500), (500, 500, 500)),
look_at=strawberry
rep.orchestrator.run()
@w.son i am just another user, but can you confirm if this is only happening to your custom assets or including NVIDIA assets shipped with Isaac Sim? would you able to take a screenshot of what the USD stage looks like on the custom USD asset?
Hi @Simplychenable ,
I think it’s happening only for my case.
I’ve attached screenshots of what the stage, layer is and error logs
I tried to run the example code, but it still doesn’t include anything.
The code example is below:
camera = rep.create.camera(position=(0, 0, 1000))
torus = rep.create.torus(semantics=\[('class', 'torus')\] , position=(0, -200 , 100))
sphere = rep.create.sphere(semantics=\[('class', 'sphere')\], position=(0, 100, 100))
cube = rep.create.cube(semantics=\[('class', 'cube')\], position=(100, -200 , 100) )
with rep.create.group([torus, sphere, cube]):
rep.modify.pose(
position=rep.distribution.uniform((-100, -100, -100), (200, 200, 200)),
scale=rep.distribution.uniform(0.1, 2))
# Initialize and attach writer
writer.initialize( output_dir="/home/woojung/debug", rgb=True, bounding_box_2d_tight=True)
rep.orchestrator.preview()
i believe that’s the snippet from the tutorial found in the following page, correct?
if so, try using the modified snippet i have included in another post where i increased the size and added rotation to the camera that helped with the visibility of the objects:
if the scaling on the tutorial snippet worked for you, it’s likely not an issue with replicator itself. the console seems to only include warnings, which don’t always result in an error. i wonder whether the size of your custom asset or the distance of those assets from the camera could be contributing to the issue?
that’s a new one. here’s a recap of what i did:
if you were to follow the steps exactly, do you still get blank outputs?
hmm, i don’t think that’s an issue. have you tried this in other versions of Isaac Sim in the past where it worked? 4.5 or 5.1?
I tried it on Isaac Sim 4.5.0. Finally, it worked.
Thank you so much, I really appreciate it!
@w.son i wonder what it could be thats causing the issue on your end. just know that 4.5 is going to be EOL in a few release cycles, so if it’s a bug in 5.0, would be great if the dev can chime in here. or give 5.1 a shot since it’s more current.
I tried it on Isaac Sim 5.0.1 this time, It also happened problem. hmm..
what’s your GPU and driver version, by the way?
I have two GPUs, RTX 3090 and RTX 4090. And the driver version is 545.29.06
another thing to consider is getting the specific driver version suggested by the mods in another thread (linked below) and see if the issue persists in 5.0:
I reinstalled NVDIA driver to 570.169. And the issue has been solved on Isaac Sim 5.0.1.
Thank you so much!
