Replicator Pose Writer on Isaac Sim 5.0.1
I found the document that PoseWriter is existed in the replicator writer extension.
BasicWriter works for me, but the PoseWriter doesn’t work properly. Replicator created dataset file, but it’s empty.
The code that I used down below:
from isaacsim.core.utils.stage import open_stage
from isaacsim.core.utils.semantics import add_labels
import omni.usd
from isaacsim.replicator.writers import PoseWriter
usd_path = "/home/work/isaac-5.1/replicator/field/output/field.usd"
open_stage(usd_path)
with rep.new_layer():
    camera = rep.create.camera( focus_distance=400.0, focal_length=24.0, clipping_range=(0.1, 10000000.0), name="Cam")
    render_product = rep.create.render_product(camera, (1024, 1024))
    target_path = "/World/Strawberries/Strawberry_01/Geometry/Twig_d3/Flower_stalk_1/Receptacle"
    strawberry = stage.GetPrimAtPath(target_path)
    add_labels(strawberry, labels=["strawberry"], instance_name= "class")
    pose_writer = rep.WriterRegistry.get("PoseWriter")
    pose_writer.initialize(
        output_dir = "/home/work/isaac-5.1/replicator/dataset",
        use_subfolders= True
    pose_writer.attach([render_product])
    with rep.trigger.on_frame(max_execs=10):
        with camera:
            rep.modify.pose(
                position=rep.distribution.uniform((-0.5, 0.2, -0.5), (0.5, 0.5, 0.5)),
                look_at=target_path
rep.orchestrator.preview()
It didn’t show any error log in terminal.
Have you had a chance to try running the example script from our documentation for PoseWriter? Does it produce the same (empty) output or any errors?
Hello!
Best regards,
