I have this script
## State of code: Throwing errors (incompatible types)
# This needs to be run inside Isaac Sim Script Editor not Omniverse Code Script Editor
from datetime import datetime
import omni.usd
from omni.isaac.core.utils.stage import get_current_stage, open_stage
import omni.isaac.core.utils.bounds as bounds_utils
import omni.isaac.core.utils.prims as prims_utils
import numpy as np
# with rep.new_layer():
# Define paths for the character, the props, the environment and the surface where the assets will be scattered in.
FORKLIFT_URL = "omniverse://localhost/NVIDIA/Assets/Isaac/2022.2.1/Isaac/Props/Forklift/forklift.usd"
ENV_URL ="omniverse://localhost/NVIDIA/Assets/Isaac/2022.2.0/Isaac/Samples/Replicator/Stage/full_warehouse_worker_and_anim_cameras.usd"
open_stage(ENV_URL)
stage =get_current_stage()
floor_prims = [x.GetPath() for x in stage.Traverse() if "SM_floor" in x.GetName() and prims_utils.get_prim_type_name(x.GetPath()) == "Xform"]
print('dir floor_prims: ', dir(floor_prims))
bb_cache = bounds_utils.create_bbox_cache()
combined_range_arr = bounds_utils.compute_combined_aabb(bb_cache, prim_paths=floor_prims)
print('combined_range_arr: ', combined_range_arr)
margin = 2
min_x, min_y, min_z, max_x, max_y, max_z = combined_range_arr
def randomize_forklift():
forklift = rep.create.from_usd(FORKLIFT_URL, semantics=[('class', 'forklift')])
with forklift:
rep.physics.collider()
rep.modify.pose(
position=rep.distribution.uniform((min_x + margin, min_y + margin, 0), (max_x - margin, max_y - margin, 0)),
rotation=rep.distribution.uniform((-90, 0, 0), (90, 0, 0)),
#scale=100
return forklift
# Register randomization
rep.randomizer.register(randomize_forklift)
# Setup camera and attach it to render product
camera = rep.create.camera(
focus_distance=800,
f_stop=0.5,
#focal_length=613.634
render_product = rep.create.render_product(camera, resolution=(640, 480))
timestamp = datetime.now().strftime("%Y_%m_%d-%I_%M_%S_%p")
# Initialize and attach writer
writer = rep.WriterRegistry.get("BasicWriter")
writer.initialize(output_dir="/home/mona/Desktop/Isaac_Sim_Dummy_Out/forklift_warehouse/" + timestamp , rgb=True, bounding_box_2d_tight=True)
writer.attach([render_product])
with rep.trigger.on_frame(num_frames=100):
print('inside trigger frame')
forklift = rep.randomizer.randomize_forklift()
print("forklift is: ", forklift)
print("type(forklift): ", type(forklift))
with camera:
print('camera: ', camera)
rep.modify.pose(position=rep.distribution.uniform((min_x + margin, min_y + margin, 5), (max_x - margin, max_y - margin, 12)),
look_at=forklift)
That I run inside Isaac Sim Script Editor. When I click Run and then from Replicator menu I click Start, I observe the taken photos are all blurry. I have used same parameters, same forklift, but a simple plane instead of warehouse in Omniverse Code Script Editor and none of the photos were blurry.
How can I fix this situation?
Please note I am using libraries from isaac sim for calculating bounding box because of which I am not able to use Omniverse Code Script Editor.
and
are two examples of such blurry photos.
