This is a followup question on
So, even though I am trying to change the camera properties interactively, I don’t see any changes in the photo. Are you able to create a video to showcase how you achieve it?
current script that produces blurry photos:
# Run this inside Omniverse Code Replicator Script Editor
from datetime import datetime
import omni.usd
# import omni.isaac.core.utils.bounds as bounds_utils
# import omni.isaac.core.utils.prims as prims_utils
with rep.new_layer():
# Define paths for the character, the props, the environment and the surface where the assets will be scattered in.
PALLET_URL = "omniverse://localhost/NVIDIA/Assets/ArchVis/Industrial/Pallets/Pallet_B1.usd"
plane = rep.create.plane(scale=25, visible=True, semantics=[("class", "plane")])
print('type of plane: ', print(plane))
# bb_cache = bounds_utils.create_bbox_cache()
# combined_range_arr = bounds_utils.compute_combined_aabb(bb_cache, prim_paths=plane)
# print('combined_range_arr: ', combined_range_arr)
def randomize_pallet():
pallet = rep.create.from_usd(PALLET_URL, semantics=[('class', 'pallet')])
with pallet:
rep.physics.collider()
rep.modify.pose(
position=rep.distribution.uniform((-1000, 0, -1000), (1000, 0, 1000)),
rotation=rep.distribution.uniform((-90,-45, 0), (-90, 45, 0)),
return pallet
# Register randomization
rep.randomizer.register(randomize_pallet)
# Setup camera and attach it to render product
camera = rep.create.camera(
focus_distance=800,
f_stop=0.5,
# focal_length=613.634
render_product = rep.create.render_product(camera, resolution=(640, 480))
timestamp = datetime.now().strftime("%Y_%m_%d-%I_%M_%S_%p")
# Initialize and attach writer
writer = rep.WriterRegistry.get("BasicWriter")
writer.initialize(output_dir="/home/mona/Desktop/Isaac_Sim_Dummy_Out/pallet/" + timestamp , rgb=True, bounding_box_2d_tight=True)
writer.attach([render_product])
with rep.trigger.on_frame(num_frames=100):
pallet = rep.randomizer.randomize_pallet()
with camera:
rep.modify.pose(position=rep.distribution.uniform((-1000, 200, 1500), (1000, 400, 2000)), look_at=pallet)
Before commenting this line focal_length=613.634 photos were like below
after commenting that line, photos are visible but still blurry. I want my produced synthetic data to be sharp.
