ValueError: Unable to set target prim of type <class 'pxr.Usd.Prim'> in Isaac Sim Script Editor
How should I fix this error? I want to throw the pallets using scatter_2d onto the floor_prims
Error:
import omni.usd
from pxr import Usd, UsdGeom, Gf
from datetime import datetime
import numpy as np
PALLET_URL = "omniverse://localhost/NVIDIA/Assets/ArchVis/Industrial/Pallets/Pallet_B1.usd"
ENV_URL ="omniverse://localhost/NVIDIA/Assets/Isaac/2022.2.0/Isaac/Samples/Replicator/Stage/full_warehouse_worker_and_anim_cameras.usd"
#open_stage(ENV_URL)
#result, error = omni.usd.get_context().open_stage(ENV_URL, load_set=omni.usd.UsdContextInitialLoadSet.LOAD_NONE)
omni.usd.get_context().open_stage(ENV_URL)
#stage = get_current_stage()
#floor_prims = [x.GetPath() for x in stage.Traverse() if "SM_floor" in x.GetName() and prims_utils.get_prim_type_name(x.GetPath()) == "Xform"]
floor_prims_paths = [x.GetPath() for x in stage.Traverse() if "SM_floor" in x.GetName() ]
floor_prims = []
for floor_prim_path in floor_prims_paths:
    floor_prims.append(omni.usd.get_prim_at_path(floor_prim_path))
#bb_cache = bounds_utils.create_bbox_cache()
#combined_range_arr = bounds_utils.compute_combined_aabb(bb_cache, prim_paths=floor_prims)
#min_x, min_y, min_z, max_x, max_y, max_z = combined_range_arr
# bbox = omni.usd.get_context().compute_path_world_bounding_box(floor_prims[0])
# min_x, min_y, min_z, max_x, max_y, max_z = bbox
# print("bbox is: ", bbox)
def compute_bbox_with_cache(cache: UsdGeom.BBoxCache, prim: Usd.Prim) -> Gf.Range3d:
    Compute Bounding Box using ComputeWorldBound at UsdGeom.BBoxCache. More efficient if used multiple times.
    See https://graphics.pixar.com/usd/dev/api/class_usd_geom_b_box_cache.html
    Args:
        cache: A cached, i.e. `UsdGeom.BBoxCache(Usd.TimeCode.Default(), ['default', 'render'])`
        prim: A prim to compute the bounding box.
    Returns:
        A range (i.e. bounding box), see more at: https://graphics.pixar.com/usd/release/api/class_gf_range3d.html
    bound = cache.ComputeWorldBound(prim)
    bound_range = bound.ComputeAlignedBox()
    return bound_range
bbcache = UsdGeom.BBoxCache(Usd.TimeCode.Default(), ["default", "render"])
bb = compute_bbox_with_cache(bbcache, floor_prims[0])
max_x, max_y, max_z = bb.GetMax()
min_x_arr = []
min_y_arr = []
min_z_arr = []
max_x_arr = []
max_y_arr = []
max_z_arr = []
for floor_prim in floor_prims:
    tmp_bb = compute_bbox_with_cache(bbcache, floor_prim)
    tmp_min_x, tmp_min_y, tmp_min_z = tmp_bb.GetMin()
    tmp_max_x, tmp_max_y, tmp_max_z = tmp_bb.GetMax()
    min_x_arr.append(tmp_min_x)
    min_y_arr.append(tmp_min_y)
    min_z_arr.append(tmp_min_z)
    max_x_arr.append(tmp_max_x)
    max_y_arr.append(tmp_max_y)
    max_z_arr.append(tmp_max_z)
min_x = min(min_x_arr)
min_y = min(min_y_arr)
min_z = min(min_z_arr)
max_x = max(max_x_arr)
max_y = max(max_y_arr)
max_z = max(max_z_arr)
margin = 3
def scatter_pallets(prim):
    pallets = rep.create.from_usd(PALLET_URL, semantics=[('class', 'pallet')], count=50)
    with pallets:
        rep.physics.collider()
        rep.modify.pose(scale=0.001)
        rep.randomizer.scatter_2d(surface_prims=prim, check_for_collisions=True),
    return pallets
# Register randomization
rep.randomizer.register(scatter_pallets)
# Setup camera and attach it to render product
camera = rep.create.camera(
    focus_distance=800,
    focal_length=40
    # f_stop=0.5,
    # f_stop=500,
    #focal_length=613.634
render_product = rep.create.render_product(camera, resolution=(1024, 1024))
timestamp = datetime.now().strftime("%Y_%m_%d-%I_%M_%S_%p")
# Initialize and attach writer
writer = rep.WriterRegistry.get("BasicWriter")
writer.initialize(output_dir="/home/mona/Desktop/Isaac_Sim_Dummy_Out/scattered_pallets_warehouse/" + timestamp , rgb=True, bounding_box_2d_tight=True)
writer.attach([render_product])
with rep.trigger.on_frame(num_frames=50):
    pallets = rep.randomizer.scatter_pallets(floor_prims)
    print('pallets is: ', pallets)
    print('pallets type is: ', type(pallets))
    # pallets = rep.randomizer.randomize_pallet()
    with camera:
        rep.modify.pose(position=rep.distribution.uniform((min_x + margin, min_y + margin, 4), (max_x - margin, max_y - margin, 7)),
                        look_at=pallets)
Hi there,
It seems I have issues running your script, can you provide a more succinct version that contains the error you are having?
Are you using the latest isaac sim version, 2022.2.1?
Best,
Andrei
Here’s the code (removed comments – but the code is interleaved/needed)
# problem with scaling of pallets (pallets encompass the warehouse as of 09.07.2023)
import omni.usd
import numpy as np
floor_prims = []
    return bound_range
min_x_arr = []
min_y_arr = []
min_z_arr = []
max_x_arr = []
max_y_arr = []
max_z_arr = []
    # tmp_corners = tmp_bb.GetCorner
margin = 3
    with pallets:
        # rep.modify.pose(scale=0.001)
        rep.modify.pose(scale=(0.01, 0.01, 0.01))
    return pallets
    focus_distance=800,
    focal_length=40
    with camera:
                        look_at=pallets)
Version is: Isaac Sim Release 2022.2.1
Here’s the error:
The goal is:
  1. find the bounding box of the warehouse
  2. consider the result from #1 as floor prims
  3. use the floor_prim as the scatter plane for scatter_2d for the pallets
  4. look at the scattered pallets with the camera and take photos
Hi there,
the look_at arguments requires a list of paths in case of multiple prims. In the newer replicator version you can use get_output_prims on the node to access these:
    pallets = rep.create.from_usd(PALLET_URL, semantics=[("class", "pallet")], count=10)
    pallets_paths = [prim.GetPath() for prim in pallets.get_output_prims()["prims"]]
Here is a fixed script which should work with the shipping of version isaac sim version 2023.1.0:
import os
import omni
from omni.isaac.core.utils.nucleus import get_assets_root_path
from pxr import Gf, Usd, UsdGeom
PALLET_URL = "/Isaac/Environments/Simple_Warehouse/Props/SM_PaletteA_01.usd"
ENV_URL = "/Isaac/Environments/Simple_Warehouse/full_warehouse.usd"
assets_root_path = get_assets_root_path()
omni.usd.get_context().open_stage(assets_root_path + ENV_URL)
floor_prims_paths = [prim.GetPath() for prim in stage.Traverse() if "SM_floor" in prim.GetName()]
floor_prims = []
    return bound_range
min_x_arr = []
min_y_arr = []
min_z_arr = []
max_x_arr = []
max_y_arr = []
max_z_arr = []
margin = 3
camera = rep.create.camera()
out_dir = os.path.join(os.getcwd(), "_out_scattered_pallets_warehouse")
writer.initialize(output_dir=out_dir, rgb=True, bounding_box_2d_tight=True)
    print(f"pallets_paths: {pallets_paths}")
    with pallets:
        floor_paths_as_str = [str(path) for path in floor_prims_paths]
        rep.randomizer.scatter_2d(surface_prims=floor_paths_as_str, check_for_collisions=True),
    with camera:
        rep.modify.pose(
            look_at=pallets_paths,
Thanks a lot for your response. I don’t have access to the version you mentioned and the latest I have access to is 2022.2.1
Is there a way to get early access to your version?
running the code I got this error:
2023.1.0 should be out in a couple of weeks, until then you could spawn the pallets using usd/isaac sim api before creating the graph and use their paths as inputs.
sorry to hijack this thread, but will 2023.1.0 improve multi camera rendering gpu memory footprint? https://forums.developer.nvidia.com/t/2022-2-1-rendering-20-cameras-without-running-out-of-memory/266877
You will get answered by different dev in your thread. I would request to avoid adding different topic in different thread.
so I was finally able to try the code you shared in Isaac Sim 2023.1.0 today. If I use the PALLET_URL = "/Isaac/Environments/Simple_Warehouse/Props/SM_PaletteA_01.usd" it will show no pallet in created data. If I use PALLET_URL = "omniverse://localhost/NVIDIA/Assets/ArchVis/Industrial/Pallets/Pallet_B1.usd" it still encompasses a pallet around the warehouse. Could you please share the results you see? I don’t see any pallets created in the output images. Since there is none, the look_at param is also taking random photos that there is no pallet.
## running code in Isaac Sim 2023.1.0
import os
import omni
# PALLET_URL = "omniverse://localhost/NVIDIA/Assets/ArchVis/Industrial/Pallets/Pallet_B1.usd"
# ENV_URL ="omniverse://localhost/NVIDIA/Assets/Isaac/2023.1.0/Isaac/Samples/Replicator/Stage/full_warehouse_worker_and_anim_cameras.usd"
floor_prims = []
    return bound_range
min_x_arr = []
min_y_arr = []
min_z_arr = []
max_x_arr = []
max_y_arr = []
max_z_arr = []
margin = 3
#out_dir = os.path.join(os.getcwd(), "_out_scattered_pallets_warehouse")
out_dir = os.path.join('/home/mona/Desktop/Omniverse_Out/Scatter_Pallet_Isaac/', "_out_scattered_pallets_warehouse")
    with pallets:
    with camera:
        rep.modify.pose(
I quickly checked the script and it seems the pallets are outside of the warehouse. You can go to the /Replicator scope and press F on the generated Xforms to find the assets in the stage.
Thanks for your response. I am not sure how to go to /Replicator scope/ Is there a tutorial link you can share? I know pressing F focuses. But when I click on ‘Replicator’ in ‘Stage’ in right handside and then press F, it shows black screen.
Also, my goal was to scatter pallets inside the warehouse and have the camera look at them. Do you know why the code scatters them outside and if there is a fix?
You can expand the /Replicator scope using the [+] sign, there you have the replicator generated prims. As you can see the pallets are scattered outside the warehouse.
I would suggest starting small, with a simple scatter function and build on top of that, this makes it easier to debug.
