Omni.replicator.core.scripts.randomizer has no attribute scatter_boxes
I am following a tutorial and I get this error. What is causing this error? I am running the code in Isaac Sim.
> /tmp/carb.uHGX1y/script_1675179111.py
AttributeError: module 'omni.replicator.core.scripts.randomizer' has no attribute 'scatter_boxes'
at:
/tmp/carb.uHGX1y/script_167579111.py(272):<module>
from omni.isaac.kit import SimulationApp
import os
# Set rendering parameters and create an instance of kit
CONFIG = {"renderer": "RayTracedLighting", "headless": True, "width": 1024, "height": 1024, "num_frames": 10}
#simulation_app = SimulationApp(launch_config=CONFIG)
ENV_URL = "omniverse://localhost/NVIDIA/Assets/Isaac/2022.2.0/Isaac/Environments/Simple_Warehouse/full_warehouse.usd"
FORKLIFT_URL = "omniverse://localhost/NVIDIA/Assets/Isaac/2022.2.0/Isaac/Props/Forklift/forklift.usd"
PALLET_URL = "omniverse://localhost/NVIDIA/Assets/Isaac/2022.2.0/Isaac/Environments/Simple_Warehouse/Props/SM_PaletteA_01.usd"
CARDBOX_URL = "omniverse://localhost/NVIDIA/Assets/Isaac/2022.2.0/Isaac/Environments/Simple_Warehouse/Props/SM_CardBoxD_04.usd"
CONE_URL = "omniverse://localhost/NVIDIA/Assets/Isaac/2022.2.0/Isaac/Environments/Simple_Warehouse/Props/S_TrafficCone.usd"
SCOPE_NAME = "/MyScope"
import carb
import random
import math
import numpy as np
from pxr import UsdGeom, Usd, Gf, UsdPhysics, PhysxSchema
import omni.usd
from omni.isaac.core import World
from omni.isaac.core.utils import prims
from omni.isaac.core.prims import RigidPrim
from omni.isaac.core.utils.nucleus import get_assets_root_path
from omni.isaac.core.utils.stage import get_current_stage, open_stage
from omni.isaac.core.utils.rotations import euler_angles_to_quat, quat_to_euler_angles, lookat_to_quatf
from omni.isaac.core.utils.bounds import compute_combined_aabb, create_bbox_cache
def main():
    # Open the environment in a new stage
    print(f"Loading Stage {ENV_URL}")
    open_stage(prefix_with_isaac_asset_server(ENV_URL))
    driver_cam_prim = prims.create_prim(
        prim_path=f"{SCOPE_NAME}/DriverCamera",
        prim_type="Camera",
        position=driver_cam_pos_gf,
        orientation=look_at_pallet_xyzw,
        attributes={"focusDistance": 400, "focalLength": 24, "clippingRange": (0.1, 10000000)},
    driver_cam_node = rep.get.prim_at_path(str(driver_cam_prim.GetPath()))
    # Camera looking at the pallet
    pallet_cam = rep.create.camera()
    # Camera looking at the forklift from a top view with large min clipping to see the scene through the ceiling
    top_view_cam = rep.create.camera(clipping_range=(6.0, 1000000.0))
    # Initialize and attach writer
    writer = rep.WriterRegistry.get("BasicWriter")
    output_directory = os.getcwd() + "/_output_headless"
    print("Outputting data to ", output_directory)
    writer.initialize(
        output_dir=output_directory,
        rgb=True,
        bounding_box_2d_tight=True,
        semantic_segmentation=True,
        instance_segmentation=True,
        distance_to_image_plane=True,
        bounding_box_3d=True,
        occlusion=True,
        normals=True,
    RESOLUTION = (CONFIG["width"], CONFIG["height"])
    driver_rp = rep.create.render_product(str(driver_cam_prim.GetPrimPath()), RESOLUTION)
    pallet_rp = rep.create.render_product(pallet_cam, RESOLUTION)
    forklift_rp = rep.create.render_product(top_view_cam, RESOLUTION)
    writer.attach([driver_rp, forklift_rp, pallet_rp])
    # Spawn a new forklift at a random pose
    forklift_prim = prims.create_prim(
        prim_path=f"{SCOPE_NAME}/Forklift",
        position=(random.uniform(-20, -2), random.uniform(-1, 3), 0),
        orientation=euler_angles_to_quat([0, 0, random.uniform(0, math.pi)]),
        usd_path=prefix_with_isaac_asset_server(FORKLIFT_URL),
        semantic_label="Forklift",
    # Spawn the pallet in front of the forklift with a random offset on the Y axis
    forklift_tf = omni.usd.get_world_transform_matrix(forklift_prim)
    pallet_offset_tf = Gf.Matrix4d().SetTranslate(Gf.Vec3d(0, random.uniform(-1.2, -2.4), 0))
    pallet_pos_gf = (pallet_offset_tf * forklift_tf).ExtractTranslation()
    forklift_quat_gf = forklift_tf.ExtractRotation().GetQuaternion()
    forklift_quat_xyzw = (forklift_quat_gf.GetReal(), *forklift_quat_gf.GetImaginary())
    pallet_prim = prims.create_prim(
        prim_path=f"{SCOPE_NAME}/Pallet",
        position=pallet_pos_gf,
        orientation=forklift_quat_xyzw,
        usd_path=prefix_with_isaac_asset_server(PALLET_URL),
        semantic_label="Pallet",
def simulate_falling_objects(prim, num_sim_steps=250, num_boxes=8):
    # Create a simulation ready world
    world = World(physics_dt=1.0 / 90.0, stage_units_in_meters=1.0)
    # Choose a random spawn offset relative to the given prim
    prim_tf = omni.usd.get_world_transform_matrix(prim)
    spawn_offset_tf = Gf.Matrix4d().SetTranslate(Gf.Vec3d(random.uniform(-0.5, 0.5), random.uniform(3, 3.5), 0))
    spawn_pos_gf = (spawn_offset_tf * prim_tf).ExtractTranslation()
    # Spawn pallet prim
    # Spawn boxes falling on the pallet
    for i in range(num_boxes):
        # Spawn box prim
        cardbox_prim_name = f"SimulatedCardbox_{i}"
        box_prim = prims.create_prim(
            prim_path=f"{SCOPE_NAME}/{cardbox_prim_name}",
            usd_path=prefix_with_isaac_asset_server(CARDBOX_URL),
            semantic_label="Cardbox",
        # Add the height of the box to the current spawn height
        curr_spawn_height += bb_cache.ComputeLocalBound(box_prim).GetRange().GetSize()[2] * 1.1
        # Wrap the cardbox prim into a rigid prim to be able to simulate it
        box_rigid_prim = RigidPrim(
            prim_path=str(box_prim.GetPrimPath()),
            name=cardbox_prim_name,
            position=spawn_pos_gf + Gf.Vec3d(random.uniform(-0.2, 0.2), random.uniform(-0.2, 0.2), curr_spawn_height),
        # Make sure physics are enabled on the rigid prim
        box_rigid_prim.enable_rigid_body_physics()
        # Register rigid prim with the scene
        world.scene.add(box_rigid_prim)
    # Reset world after adding simulated assets for physics handles to be propagated properly
    world.reset()
    # Simulate the world for the given number of steps or until the highest box stops moving
    last_box = world.scene.get_object(f"SimulatedCardbox_{num_boxes - 1}")
    for i in range(num_sim_steps):
        world.step(render=False)
        if last_box and np.linalg.norm(last_box.get_linear_velocity()) < 0.001:
            print(f"Simulation stopped after {i} steps")
            break
# Randomize boxes materials and their location on the surface of the given prim
def register_scatter_boxes(prim):
    # Calculate the bounds of the prim to create a scatter plane of its size
    bb_cache = create_bbox_cache()
    bbox3d_gf = bb_cache.ComputeLocalBound(prim)
    prim_tf_gf = omni.usd.get_world_transform_matrix(prim)
    bbox3d_gf.Transform(prim_tf_gf)
    range_size = bbox3d_gf.GetRange().GetSize()
    # Get the quaterion of the prim in xyzw format from usd
    prim_quat_gf = prim_tf_gf.ExtractRotation().GetQuaternion()
    prim_quat_xyzw = (prim_quat_gf.GetReal(), *prim_quat_gf.GetImaginary())
    # Create a plane on the pallet to scatter the boxes on
    plane_scale = (range_size[0] * 0.8, range_size[1] * 0.8, 1)
    plane_pos_gf = prim_tf_gf.ExtractTranslation() + Gf.Vec3d(0, 0, range_size[2])
    plane_rot_euler_deg = quat_to_euler_angles(np.array(prim_quat_xyzw), degrees=True)
    scatter_plane = rep.create.plane(
        scale=plane_scale, position=plane_pos_gf, rotation=plane_rot_euler_deg, visible=False
    cardbox_mats = [
        prefix_with_isaac_asset_server("omniverse://localhost/NVIDIA/Assets/Isaac/2022.2.0/Isaac/Environments/Simple_Warehouse/Materials/MI_PaperNotes_01.mdl"),
        prefix_with_isaac_asset_server("omniverse://localhost/NVIDIA/Assets/Isaac/2022.2.0/Isaac/Environments/Simple_Warehouse/Materials/MI_CardBoxB_05.mdl"),
    def scatter_boxes():
        cardboxes = rep.create.from_usd(
            prefix_with_isaac_asset_server(CARDBOX_URL), semantics=[("class", "Cardbox")], count=5
        with cardboxes:
            rep.randomizer.scatter_2d(scatter_plane, check_for_collisions=True)
            rep.randomizer.materials(cardbox_mats)
        return cardboxes.node
    rep.randomizer.register(scatter_boxes)
# Randomly place cones from calculated locations around the working area (combined bounds) of the forklift and pallet
def register_cone_placement(forklift_prim, pallet_prim):
    # Helper function to get the combined bounds of the forklift and pallet
    combined_range_arr = compute_combined_aabb(bb_cache, [forklift_prim.GetPrimPath(), pallet_prim.GetPrimPath()])
    min_x = float(combined_range_arr[0])
    min_y = float(combined_range_arr[1])
    min_z = float(combined_range_arr[2])
    max_x = float(combined_range_arr[3])
    max_y = float(combined_range_arr[4])
    corners = [(min_x, min_y, min_z), (max_x, min_y, min_z), (min_x, max_y, min_z), (max_x, max_y, min_z)]
    def place_cones():
        cones = rep.create.from_usd(prefix_with_isaac_asset_server(CONE_URL), semantics=[("class", "TrafficCone")])
        with cones:
            rep.modify.pose(position=rep.distribution.sequence(corners))
        return cones.node
    rep.randomizer.register(place_cones)
# Randomize lights around the scene
def register_lights_placement(forklift_prim, pallet_prim):
    pos_min = (combined_range_arr[0], combined_range_arr[1], 6)
    pos_max = (combined_range_arr[3], combined_range_arr[4], 7)
    def randomize_lights():
        lights = rep.create.light(
            light_type="Sphere",
            color=rep.distribution.uniform((0.2, 0.1, 0.1), (0.9, 0.8, 0.8)),
            intensity=rep.distribution.uniform(500, 2000),
            position=rep.distribution.uniform(pos_min, pos_max),
            scale=rep.distribution.uniform(5, 10),
            count=3,
        return lights.node
    rep.randomizer.register(randomize_lights)
with rep.trigger.on_frame(num_frames=CONFIG["num_frames"]):
    rep.randomizer.scatter_boxes()
    rep.randomizer.place_cones()
    rep.randomizer.randomize_lights()
    pallet_cam_min = (pallet_pos_gf[0] - 2, pallet_pos_gf[1] - 2, 2)
    pallet_cam_max = (pallet_pos_gf[0] + 2, pallet_pos_gf[1] + 2, 4)
    with pallet_cam:
        rep.modify.pose(
            position=rep.distribution.uniform(pallet_cam_min, pallet_cam_max),
            look_at=str(pallet_prim.GetPrimPath()),
    top_view_cam_min = (foklift_pos_gf[0], foklift_pos_gf[1], 9)
    top_view_cam_max = (foklift_pos_gf[0], foklift_pos_gf[1], 11)
    with top_view_cam:
        rep.modify.pose(
            position=rep.distribution.uniform(top_view_cam_min, top_view_cam_max),
            rotation=rep.distribution.uniform((0, -90, 0), (0, -90, 180)),
    driver_cam_min = (driver_cam_pos_gf[0], driver_cam_pos_gf[1], driver_cam_pos_gf[2] - 0.25)
    driver_cam_max = (driver_cam_pos_gf[0], driver_cam_pos_gf[1], driver_cam_pos_gf[2] + 0.25)
    with driver_cam_node:
        rep.modify.pose(
            position=rep.distribution.uniform(driver_cam_min, driver_cam_max),
# # Starts replicator and waits until all data was successfully written
# def run_orchestrator():
#     rep.orchestrator.run()
#     # Wait until started
#     # while not rep.orchestrator.get_is_started():
#     #     simulation_app.update()
#     # Wait until stopped
#     while rep.orchestrator.get_is_started():
#     rep.BackendDispatch.wait_until_done()
#     rep.orchestrator.stop()
I resolved it by running it from terminal vs Script Editor.
(isaac-sim) mona@ard-gpu-01:~/.local/share/ov/pkg/isaac_sim-2022.2.0$ ./python.sh standalone_examples/replicator/offline_generation.py
