Issue of Slot Mismatching when Testing with ARC-OTA 1.7 [SFN 3.19 Slot Map 2 cell index 0 Dyn index -1 setting as unhealthy!]
I am testing with ARC-OTA 1.7 SDK with OAI L2, and I have a problem running the gNB. My build procedure strictly followed the Aerial CUDA accelerated RAN 25-3 installation guide, ARC-OTA 1.7 installation guide and OAI FAPI split guide. The log of cubb looks like:
10:43:12.543608 CON msg_processing 0 \[DRV.API\] Update cell: mplane_id=1 dl_grid_sz=273
10:43:12.543609 CON msg_processing 0 \[DRV.API\] Update cell: mplane_id=1 ul_grid_sz=273
10:43:12.543614 CON msg_processing 0 \[SCF.PHY\] on_config_request: create_cell_configs for cell_id=0 phy_cell_id=51 returned error_code=0
10:43:12.543623 CON msg_processing 0 \[SCF.PHY\] send_cell_config_response: Send CONFIG.response: cell_id=0 error_code=0x0
10:43:12.543669 CON msg_processing 0 \[L2A.TRANSPORT\] wrapper: configured_cells_mask=0x1 expected_mask=0x1 all_cells_configured=true - all cells configured
10:43:12.543719 WRN msg_processing 0 \[SCF.PHY\] on_msg: Incorrect msg length cell_id=0 msg_id=0x04 expected=8 received=16
10:43:12.543720 CON msg_processing 0 \[SCF.PHY\] on_cell_start_request: Cell 0 Received START.request, sending START.response… phy_cell_id=51
10:43:12.544052 CON msg_processing 0 \[L2A.TRANSPORT\] wrapper: configured_cells_mask=0x1 expected_mask=0x1 all_cells_configured=true - all cells configured
10:43:12.545789 CON timer_thread 0 \[L2A.TICK\] Thread slot_indication_thread_sleep_method initialized fmtlog
10:43:12.545792 CON timer_thread 0 \[L2A.TICK\] PTP Configs: gps_alpha: 0 gps_beta: 0
10:43:12.545796 CON timer_thread 0 \[L2A.TICK\] Start time: tick=1770288192545789721, seconds since epoch = 1770288192, nanoseconds = 545789721
10:43:12.545796 CON timer_thread 0 \[L2A.TICK\] FIRST tick scheduled for: tick=1770288193080000000, seconds since epoch = 1770288193, nanoseconds = 80000000
10:43:13.080036 CON timer_thread 0 \[SCF.PHY\] Cell  0 | DL    0.00 Mbps    0 Slots | UL    0.00 Mbps    0 Slots CRC   0 (     0) | Tick 0
10:43:13.099211 WRN UlPhyDriver04 0 \[DRV.FH\] sendCPlane_timingCheck : sendCPlane Timing error for ULC start_tx_time 1770288193099164000 current_time 1770288193099210398
10:43:13.099211 WRN UlPhyDriver04 0 \[DRV.FH\] sendCPlane_timingCheck: Error at oframe_id\_ 1 osfid\_ 9 oslotid\_ 1
10:43:13.099212 ERR UlPhyDriver04 0 \[AERIAL_CUPHYDRV_API_EVENT\] \[DRV.FUNC_UL\] UL C-plane send error for cell index 0,error type 2 Map 0 Abort UL Tasks!
10:43:13.099214 ERR UlPhyDriver04 0 \[AERIAL_CUPHYDRV_API_EVENT\] \[DRV.FUNC_UL\] Calling ul_tx_error_fn 1491
10:43:13.099217 ERR UlPhyDriver04 0 \[AERIAL_NVIPC_API_EVENT\] \[SCF.PHY\] Send Err.ind for SFN 1.19 cell_id=0 msg_id=0x81 err_code=0x37
10:43:13.099230 ERR UlPhyDriver04 0 \[AERIAL_CUPHYDRV_API_EVENT\] \[DRV.FUNC_UL\] Task ul_aggr_1_cplane 0 aborted the tasklist for an error
10:43:13.099231 WRN UlPhyDriver05 0 \[DRV.FUNC_UL\] task_work_function_ul_aggr_1_orderKernel Task aborted for Slot Map 0
10:43:13.099903 WRN UlPhyDriver05 0 \[DRV.FUNC_UL\] task_work_function_ul_aggr_1_prach Task aborted for Slot Map 0
10:43:13.100418 WRN UlPhyDriver04 0 \[DRV.FUNC_UL\] task_work_function_ul_aggr_3 Task aborted for Slot Map 0
10:43:13.121993 ERR UlPhyDriver04 0 \[AERIAL_CUPHY_API_EVENT\] \[DRV.FUNC_UL\] SFN 3.19 Slot Map 2 cell index 0 Dyn index -1 setting as unhealthy!
10:43:14.080010 CON timer_thread 0 \[SCF.PHY\] Cell  0 | DL    0.00 Mbps    0 Slots | UL    0.00 Mbps    0 Slots CRC   0 (     0) | Tick 2000
10:43:14.120414 ERR UlPhyDriver05 0 \[AERIAL_CUPHY_API_EVENT\] \[DRV.FUNC_UL\] SFN 103.19 Slot Map 102 cell index 0 Dyn index -1 setting as healthy!
10:43:14.141992 ERR UlPhyDriver05 0 \[AERIAL_CUPHY_API_EVENT\] \[DRV.FUNC_UL\] SFN 105.19 Slot Map 104 cell index 0 Dyn index -1 setting as unhealthy!
10:43:15.080008 CON timer_thread 0 \[SCF.PHY\] Cell  0 | DL    0.04 Mbps   50 Slots | UL    0.00 Mbps    0 Slots CRC   0 (     0) | Tick 4000
10:43:15.140414 ERR UlPhyDriver04 0 \[AERIAL_CUPHY_API_EVENT\] \[DRV.FUNC_UL\] SFN 205.19 Slot Map 204 cell index 0 Dyn index -1 setting as healthy!
10:43:15.161989 ERR UlPhyDriver05 0 \[AERIAL_CUPHY_API_EVENT\] \[DRV.FUNC_UL\] SFN 207.19 Slot Map 206 cell index 0 Dyn index -1 setting as unhealthy!
10:43:16.080008 CON timer_thread 0 \[SCF.PHY\] Cell  0 | DL    0.04 Mbps   50 Slots | UL    0.00 Mbps    0 Slots CRC   0 (     0) | Tick 6000
10:43:16.160414 ERR UlPhyDriver04 0 \[AERIAL_CUPHY_API_EVENT\] \[DRV.FUNC_UL\] SFN 307.19 Slot Map 306 cell index 0 Dyn index -1 setting as healthy!
10:43:16.181983 ERR UlPhyDriver04 0 \[AERIAL_CUPHY_API_EVENT\] \[DRV.FUNC_UL\] SFN 309.19 Slot Map 308 cell index 0 Dyn index -1 setting as unhealthy!
10:43:17.080010 CON timer_thread 0 \[SCF.PHY\] Cell  0 | DL    0.04 Mbps   50 Slots | UL    0.00 Mbps    0 Slots CRC   0 (     0) | Tick 8000
10:43:17.180414 ERR UlPhyDriver04 0 \[AERIAL_CUPHY_API_EVENT\] \[DRV.FUNC_UL\] SFN 409.19 Slot Map 408 cell index 0 Dyn index -1 setting as healthy!
10:43:17.201989 ERR UlPhyDriver04 0 \[AERIAL_CUPHY_API_EVENT\] \[DRV.FUNC_UL\] SFN 411.19 Slot Map 410 cell index 0 Dyn index -1 setting as unhealthy!
Could anyone share some advice or point me in the right direction?
Thanks in advance!
Hi @siyao.li
The problem is likely due to the DU didn’t received the packets or the the packets not coming in the proper timing window from O-RU. would you please confirm two
  1. are DU and O-RU ptp synced? you can get check the status on DU by running “sudo systemctl status ptp4l.service” and “sudo systemctl status ptp4l.service”, and on O-RU to check the ptp clock lock status .
2 ) is dst_mac_addr in cuphycontroller_scf_* yaml match with O-RU FH interface MAC address? is the RU dst_mac_addr matching with DU FH interface MAC address?
  1. are vlan and pcp DU matching with O-RU’s vlan and pcp?
Hi jixu, thank you for the reply!
I think the main issue is that we are testing with an LITEON O-RU that is out of support anymore. Do you have any idea about the O-RU?
I checked the DU and O-RU’s sync status and they look perfect with only one digit ns offset from the GM. The mac address is probably fine as well, because I checked the FH packet using Wireshark and both RU and DU are correctly parsed. Vlan also seems fine and I will go on check with the pcp.
