After loading the nvidia_peermem module, the previous DMA mapping error has disappeared.
Now, I can see that packets from the O-RU are successfully arriving at the DU (verified with Wireshark).
However, the DU still reports the cell as “unhealthy” and UL 0bps, even though the U-plane packets are visible on the interface.
Do you have any suggestions on additional steps?
Thank you for your help and guidance.
Cannot find MPS control daemon process
Supermicro-G1SMH-G
Started cuphycontroller on CPU core 0
Aerial metrics backend address: 127.0.0.1:8081
06:15:43.989940 CON phy_init 0 [CTL.SCF] Config file: /opt/nvidia/cuBB/cuPHY-CP/cuphycontroller/config/cuphycontroller_P5G_FXN_GH.yaml
06:15:43.990941 CON phy_init 0 [CTL.SCF] low_priority_core=10
06:15:43.990955 CON phy_init 0 [APP.CONFIG] Current TAI offset: 0s
06:15:43.990992 CON phy_init 0 [NVLOG.CPP] Using /opt/nvidia/cuBB/cuPHY/nvlog/config/nvlog_config.yaml for nvlog configuration
06:15:43.992179 CON phy_init 0 [NVLOG.CPP] AERIAL_LOG_PATH set to /var/log/aerial
06:15:43.992182 CON phy_init 0 [NVLOG.CPP] Output log file path /var/log/aerial/phy.log
06:15:44.003558 CON phy_init 0 [CTL.YAML] cuphycontroller config. yaml does not have gpu_init_comms_via_cpu key; defaulting to 0.
06:15:44.003559 CON phy_init 0 [CTL.YAML] cuphycontroller config. yaml does not have cpu_init_comms key; defaulting to 0.
06:15:44.003694 CON phy_init 0 [CTL.YAML] cell_id 1 nic_index :0
06:15:44.003788 CON phy_init 0 [CTL.YAML] ta4_min_ns_srs/ta4_max_ns_srs not set in config file, using default ta4_min_ns_srs = 621 and ta4_max_ns_srs = 1831
06:15:44.003802 CON phy_init 0 [CTL.YAML] t1a_min_cp_dl_ns/t1a_max_cp_dl_ns not set in config file, using default t1a_min_cp_dl_ns = 419 and t1a_max_cp_dl_ns = 669
06:15:44.003806 CON phy_init 0 [CTL.YAML] t1a_min_cp_ul_ns not set in config file, using default of 285 us
06:15:44.003845 CON phy_init 0 [CTL.YAML] Num Slots: 8
06:15:44.003845 CON phy_init 0 [CTL.YAML] Enable UL cuPHY Graphs: 1
06:15:44.003845 CON phy_init 0 [CTL.YAML] Enable DL cuPHY Graphs: 1
06:15:44.003846 CON phy_init 0 [CTL.YAML] Accurate TX scheduling clock resolution (ns): 500
06:15:44.003846 CON phy_init 0 [CTL.YAML] DPDK core: 10
06:15:44.003846 CON phy_init 0 [CTL.YAML] Prometheus core: -1
06:15:44.003847 CON phy_init 0 [CTL.YAML] UL cores:
06:15:44.003847 CON phy_init 0 [CTL.YAML] - 4
06:15:44.003847 CON phy_init 0 [CTL.YAML] - 5
06:15:44.003847 CON phy_init 0 [CTL.YAML] DL cores:
06:15:44.003847 CON phy_init 0 [CTL.YAML] - 6
06:15:44.003847 CON phy_init 0 [CTL.YAML] - 7
06:15:44.003847 CON phy_init 0 [CTL.YAML] - 8
06:15:44.003847 CON phy_init 0 [CTL.YAML] Debug worker: -1
06:15:44.003848 CON phy_init 0 [CTL.YAML] Data Lake core: -1
06:15:44.003848 CON phy_init 0 [CTL.YAML] SRS starting Section ID: 3072
06:15:44.003848 CON phy_init 0 [CTL.YAML] PRACH starting Section ID: 2048
06:15:44.003849 CON phy_init 0 [CTL.YAML] USE GREEN CONTEXTS: 0
06:15:44.003849 CON phy_init 0 [CTL.YAML] USE BATCHED MEMCPY: 1
06:15:44.003849 CON phy_init 0 [CTL.YAML] MPS SM PUSCH: 100
06:15:44.003849 CON phy_init 0 [CTL.YAML] MPS SM PUCCH: 2
06:15:44.003849 CON phy_init 0 [CTL.YAML] MPS SM PRACH: 2
06:15:44.003849 CON phy_init 0 [CTL.YAML] MPS SM UL ORDER: 20
06:15:44.003849 CON phy_init 0 [CTL.YAML] MPS SM PDSCH: 102
06:15:44.003849 CON phy_init 0 [CTL.YAML] MPS SM PDCCH: 10
06:15:44.003850 CON phy_init 0 [CTL.YAML] MPS SM PBCH: 2
06:15:44.003850 CON phy_init 0 [CTL.YAML] MPS SM GPU_COMMS: 16
06:15:44.003850 CON phy_init 0 [CTL.YAML] MPS SM SRS: 16
06:15:44.003850 CON phy_init 0 [CTL.YAML] UL Order Kernel Mode: 0
06:15:44.003850 CON phy_init 0 [CTL.YAML] PDSCH fallback: 0
06:15:44.003851 CON phy_init 0 [CTL.YAML] Massive MIMO enable: 0
06:15:44.003851 CON phy_init 0 [CTL.YAML] mMIMO_enable feature 0
06:15:44.003851 CON phy_init 0 [CTL.YAML] Enable SRS : 1
06:15:44.003851 CON phy_init 0 [CTL.YAML] ul_order_timeout_gpu_log_enable: 0
06:15:44.003852 CON phy_init 0 [CTL.YAML] ue_mode: 0
06:15:44.003852 CON phy_init 0 [CTL.YAML] Aggr Obj Non-availability threshold: 5
06:15:44.003852 CON phy_init 0 [CTL.YAML] sendCPlane_timing_error_th_ns: 0
06:15:44.003852 CON phy_init 0 [CTL.YAML] pusch_aggr_per_ctx: 3
06:15:44.003852 CON phy_init 0 [CTL.YAML] prach_aggr_per_ctx: 2
06:15:44.003852 CON phy_init 0 [CTL.YAML] pucch_aggr_per_ctx: 4
06:15:44.003852 CON phy_init 0 [CTL.YAML] srs_aggr_per_ctx: 3
06:15:44.003852 CON phy_init 0 [CTL.YAML] max_harq_pools: 384
06:15:44.003852 CON phy_init 0 [CTL.YAML] ul_input_buffer_per_cell: 10
06:15:44.003852 CON phy_init 0 [CTL.YAML] ul_input_buffer_per_cell_srs: 6
06:15:44.003852 CON phy_init 0 [CTL.YAML] max_ru_unhealthy_ul_slots: 100
06:15:44.003852 CON phy_init 0 [CTL.YAML] srs_chest_algo_type: 0
06:15:44.003852 CON phy_init 0 [CTL.YAML] srs_chest_tol2_normalization_algo_type: 1
06:15:44.003853 CON phy_init 0 [CTL.YAML] srs_chest_tol2_constant_scaler: 32768
06:15:44.003853 CON phy_init 0 [CTL.YAML] bfw_power_normalization_alg_selector: 1
06:15:44.003853 CON phy_init 0 [CTL.YAML] bfw_beta_prescaler: 16384
06:15:44.003853 CON phy_init 0 [CTL.YAML] total_num_srs_chest_buffers: 6144
06:15:44.003853 CON phy_init 0 [CTL.YAML] send_static_bfw_wt_all_cplane: 1
06:15:44.003853 CON phy_init 0 [CTL.YAML] ul_pcap_capture_enable: 0
06:15:44.003853 CON phy_init 0 [CTL.YAML] ul_pcap_capture_thread_cpu_affinity: 117
06:15:44.003853 CON phy_init 0 [CTL.YAML] ul_pcap_capture_thread_sched_priority: 175
06:15:44.003853 CON phy_init 0 [CTL.YAML] pcap_logger_ul_cplane_enable: 0
06:15:44.003853 CON phy_init 0 [CTL.YAML] pcap_logger_dl_cplane_enable: 0
06:15:44.003853 CON phy_init 0 [CTL.YAML] pcap_logger_thread_cpu_affinity: 10
06:15:44.003854 CON phy_init 0 [CTL.YAML] pcap_logger_thread_sched_prio: 95
06:15:44.003854 CON phy_init 0 [CTL.YAML] pcap_logger_file_save_dir: ./
06:15:44.003854 CON phy_init 0 [CTL.YAML] static_beam_id_start: 1
06:15:44.003854 CON phy_init 0 [CTL.YAML] static_beam_id_end: 16527
06:15:44.003854 CON phy_init 0 [CTL.YAML] dynamic_beam_id_start: 16528
06:15:44.003854 CON phy_init 0 [CTL.YAML] dynamic_beam_id_end: 65535
06:15:44.003854 CON phy_init 0 [CTL.YAML] ul_order_timeout_gpu_log_enable: 0
06:15:44.003854 CON phy_init 0 [CTL.YAML] pusch_workCancelMode: 2
06:15:44.003854 CON phy_init 0 [CTL.YAML] GPU-initiated comms DL: 1
06:15:44.003855 CON phy_init 0 [CTL.YAML] GPU-initiated comms (via CPU): 0
06:15:44.003855 CON phy_init 0 [CTL.YAML] CPU-initiated comms : 0
06:15:44.003855 CON phy_init 0 [CTL.YAML] Cell group: 1
06:15:44.003855 CON phy_init 0 [CTL.YAML] Cell group num: 1
06:15:44.003855 CON phy_init 0 [CTL.YAML] puxchPolarDcdrListSz: 8
06:15:44.003855 CON phy_init 0 [CTL.YAML] split_ul_cuda_streams: 0
06:15:44.003855 CON phy_init 0 [CTL.YAML] serialize_pucch_pusch: 0
06:15:44.003855 CON phy_init 0 [CTL.YAML] bfw_c_plane_chaining_mode: 2
06:15:44.003855 CON phy_init 0 [CTL.YAML] fh_stats_dump_cpu_core: -1
06:15:44.003855 CON phy_init 0 [CTL.YAML] fix_beta_dl: 0
06:15:44.003856 CON phy_init 0 [CTL.YAML] pdump_client_thread: -1
06:15:44.003856 CON phy_init 0 [CTL.YAML] profiler_sec: 0
06:15:44.003856 CON phy_init 0 [CTL.YAML] datalake_address: localhost
06:15:44.003856 CON phy_init 0 [CTL.YAML] dpdk_file_prefix: cuphycontroller
06:15:44.003856 CON phy_init 0 [CTL.YAML] puschrxChestFactorySettingsFilename:
06:15:44.003856 CON phy_init 0 [CTL.YAML] accu_tx_sched_disable: 0
06:15:44.003856 CON phy_init 0 [CTL.YAML] cplane_disable: 0
06:15:44.003856 CON phy_init 0 [CTL.YAML] disable_empw: 0
06:15:44.003856 CON phy_init 0 [CTL.YAML] dlc_alloc_cplane_bfw_txq: 0
06:15:44.003856 CON phy_init 0 [CTL.YAML] dlc_bfw_enable_divide_per_cell: 0
06:15:44.003857 CON phy_init 0 [CTL.YAML] dpdk_verbose_logs: 0
06:15:44.003857 CON phy_init 0 [CTL.YAML] enable_cpu_task_tracing: 0
06:15:44.003857 CON phy_init 0 [CTL.YAML] enable_dl_cqe_tracing: 0
06:15:44.003857 CON phy_init 0 [CTL.YAML] enable_l1_param_sanity_check: 0
06:15:44.003857 CON phy_init 0 [CTL.YAML] enable_ok_tb: 0
06:15:44.003857 CON phy_init 0 [CTL.YAML] enable_prepare_tracing: 0
06:15:44.003857 CON phy_init 0 [CTL.YAML] mCh_segment_proc_enable: 0
06:15:44.003857 CON phy_init 0 [CTL.YAML] pmu_metrics: 0
06:15:44.003857 CON phy_init 0 [CTL.YAML] puschCfo: 1
06:15:44.003858 CON phy_init 0 [CTL.YAML] puschDftSOfdm: 0
06:15:44.003858 CON phy_init 0 [CTL.YAML] puschEnablePerPrgChEst: 0
06:15:44.003858 CON phy_init 0 [CTL.YAML] puschRssi: 1
06:15:44.003858 CON phy_init 0 [CTL.YAML] puschSelectChEstAlgo: 1
06:15:44.003858 CON phy_init 0 [CTL.YAML] puschSelectEqCoeffAlgo: 3
06:15:44.003858 CON phy_init 0 [CTL.YAML] puschSinr: 2
06:15:44.003858 CON phy_init 0 [CTL.YAML] puschTbSizeCheck: 1
06:15:44.003858 CON phy_init 0 [CTL.YAML] puschTdi: 1
06:15:44.003858 CON phy_init 0 [CTL.YAML] puschTo: 1
06:15:44.003859 CON phy_init 0 [CTL.YAML] pusch_deviceGraphLaunchEn: 1
06:15:44.003859 CON phy_init 0 [CTL.YAML] pusch_subSlotProcEn: 0
06:15:44.003859 CON phy_init 0 [CTL.YAML] ulc_alloc_cplane_bfw_txq: 1
06:15:44.003859 CON phy_init 0 [CTL.YAML] ulc_bfw_enable_divide_per_cell: 0
06:15:44.003859 CON phy_init 0 [CTL.YAML] ul_rx_pkt_tracing_level: 0
06:15:44.003859 CON phy_init 0 [CTL.YAML] ul_rx_pkt_tracing_level_srs: 0
06:15:44.003859 CON phy_init 0 [CTL.YAML] forcedNumCsi2Bits: 0
06:15:44.003859 CON phy_init 0 [CTL.YAML] pusch_waitTimeOutPostEarlyHarqUs: 3000
06:15:44.003859 CON phy_init 0 [CTL.YAML] pusch_waitTimeOutPreEarlyHarqUs: 3000
06:15:44.003859 CON phy_init 0 [CTL.YAML] validation: 0
06:15:44.003860 CON phy_init 0 [CTL.YAML] cqe_trace_slot_mask: 196800
06:15:44.003860 CON phy_init 0 [CTL.YAML] datalake_samples: 1000000
06:15:44.003860 CON phy_init 0 [CTL.YAML] num_ok_tb_slot: 0
06:15:44.003860 CON phy_init 0 [CTL.YAML] pusch_nMaxLdpcHetConfigs: 32
06:15:44.003860 CON phy_init 0 [CTL.YAML] sendCPlane_dlbfw_backoff_th_ns: 300000
06:15:44.003860 CON phy_init 0 [CTL.YAML] sendCPlane_ulbfw_backoff_th_ns: 300000
06:15:44.003860 CON phy_init 0 [CTL.YAML] ul_order_max_rx_pkts: 512
06:15:44.003860 CON phy_init 0 [CTL.YAML] ul_order_rx_pkts_timeout_ns: 100000
06:15:44.003860 CON phy_init 0 [CTL.YAML] ul_order_timeout_cpu_ns: 4000000
06:15:44.003860 CON phy_init 0 [CTL.YAML] ul_order_timeout_gpu_ns: 3000000
06:15:44.003860 CON phy_init 0 [CTL.YAML] ul_order_timeout_gpu_srs_ns: 5200000
06:15:44.003861 CON phy_init 0 [CTL.YAML] ul_order_timeout_log_interval_ns: 1000000000
06:15:44.003861 CON phy_init 0 [CTL.YAML] ul_srs_aggr3_task_launch_offset_ns: 4000000
06:15:44.003861 CON phy_init 0 [CTL.YAML] workers_sched_priority: 95
06:15:44.003861 CON phy_init 0 [CTL.YAML] cqe_trace_cell_mask: 1
06:15:44.003861 CON phy_init 0 [CTL.YAML] Number of Cell Configs: 1
06:15:44.003861 CON phy_init 0 [CTL.YAML] L2Adapter config file: /opt/nvidia/cuBB/cuPHY-CP/cuphycontroller/config/l2_adapter_config_P5G_GH.yaml
06:15:44.003861 CON phy_init 0 [CTL.YAML] Cell name: O-RU 0
06:15:44.003862 CON phy_init 0 [CTL.YAML] MU: 1
06:15:44.003862 CON phy_init 0 [CTL.YAML] ID: 1
06:15:44.003862 CON phy_init 0 [CTL.YAML] Number of MPlane Configs: 1
06:15:44.003862 CON phy_init 0 [CTL.YAML] Mplane ID: 1
06:15:44.003862 CON phy_init 0 [CTL.YAML] VLAN ID: 564
06:15:44.003863 CON phy_init 0 [CTL.YAML] Source Eth Address: a0:88:c2:a9:c0:d0
06:15:44.003863 CON phy_init 0 [CTL.YAML] Destination Eth Address: e8:c7:4f:25:7f:ff
06:15:44.003863 CON phy_init 0 [CTL.YAML] NIC port: 0000:01:00.0
06:15:44.003863 CON phy_init 0 [CTL.YAML] RU Type: 1
06:15:44.003863 CON phy_init 0 [CTL.YAML] U-plane TXQs: 1
06:15:44.003863 CON phy_init 0 [CTL.YAML] DL compression method: 1
06:15:44.003863 CON phy_init 0 [CTL.YAML] DL iq bit width: 9
06:15:44.003863 CON phy_init 0 [CTL.YAML] UL compression method: 1
06:15:44.003864 CON phy_init 0 [CTL.YAML] UL iq bit width: 9
06:15:44.003864 CON phy_init 0 [CTL.YAML] Flow list SSB/PBCH:
06:15:44.003864 CON phy_init 0 [CTL.YAML] 0
06:15:44.003864 CON phy_init 0 [CTL.YAML] 1
06:15:44.003864 CON phy_init 0 [CTL.YAML] 2
06:15:44.003864 CON phy_init 0 [CTL.YAML] 3
06:15:44.003864 CON phy_init 0 [CTL.YAML] Flow list PDCCH:
06:15:44.003864 CON phy_init 0 [CTL.YAML] Flow list PDSCH:
06:15:44.003865 CON phy_init 0 [CTL.YAML] 1
06:15:44.003865 CON phy_init 0 [CTL.YAML] 2
06:15:44.003865 CON phy_init 0 [CTL.YAML] 3
06:15:44.003865 CON phy_init 0 [CTL.YAML] Flow list CSIRS:
06:15:44.003865 CON phy_init 0 [CTL.YAML] 0
06:15:44.003865 CON phy_init 0 [CTL.YAML] Flow list PUSCH:
06:15:44.003865 CON phy_init 0 [CTL.YAML] Flow list PUCCH:
06:15:44.003866 CON phy_init 0 [CTL.YAML] 0
06:15:44.003866 CON phy_init 0 [CTL.YAML] 1
06:15:44.003866 CON phy_init 0 [CTL.YAML] 2
06:15:44.003866 CON phy_init 0 [CTL.YAML] 3
06:15:44.003866 CON phy_init 0 [CTL.YAML] Flow list SRS:
06:15:44.003866 CON phy_init 0 [CTL.YAML] Flow list PRACH:
06:15:44.003866 CON phy_init 0 [CTL.YAML] PUSCH TV: /opt/nvidia/cuBB/testVectors/cuPhyChEstCoeffs.h5
06:15:44.003867 CON phy_init 0 [CTL.YAML] SRS TV: /opt/nvidia/cuBB/testVectors/cuPhyChEstCoeffs.h5
06:15:44.003867 CON phy_init 0 [CTL.YAML] Section_3 time offset: 58369
06:15:44.003867 CON phy_init 0 [CTL.YAML] nMaxRxAnt: 4
06:15:44.003867 CON phy_init 0 [CTL.YAML] PUSCH PRBs Stride: 273
06:15:44.003867 CON phy_init 0 [CTL.YAML] PRACH PRBs Stride: 12
06:15:44.003867 CON phy_init 0 [CTL.YAML] SRS PRBs Stride: 273
06:15:44.003867 CON phy_init 0 [CTL.YAML] PUSCH nMaxPrb: 273
06:15:44.003867 CON phy_init 0 [CTL.YAML] PUSCH nMaxRx: 4
06:15:44.003867 CON phy_init 0 [CTL.YAML] UL Gain Calibration: 48.68
06:15:44.003868 CON phy_init 0 [CTL.YAML] Lower guard bw: 845
06:15:44.591752 CON phy_init 0 [CTL.SCF] Network interface for PCIe address 0000:01:00.0 : aerial00
06:15:44.591824 CON phy_init 0 [APP.UTILS] PHC clock: 1762150544.591819626
06:15:44.591835 CON phy_init 0 [APP.UTILS] CLOCK_TAI: 1762150544.591829200
06:15:44.591836 CON phy_init 0 [APP.UTILS] CLOCK_REALTIME: 1762150544.591829136
06:15:44.591836 CON phy_init 0 [APP.UTILS] TAI/REALTIME offset: 0 seconds
06:15:44.594803 CON phy_init 0 [DRV.CTX] CUDA_DEVICE_MAX_CONNECTIONS 8
06:15:44.594807 CON phy_init 0 [DRV.CTX] use_green_contexts 0
EAL: Detected CPU lcores: 72
EAL: Detected NUMA nodes: 1
EAL: Detected shared linkage of DPDK
EAL: Multi-process socket /var/run/dpdk/cuphycontroller/mp_socket
EAL: Selected IOVA mode ‘VA’
EAL: VFIO support initialized
EAL: Probe PCI driver: gpu_cuda (10de:2342) device: 0009:01:00.0 (socket 0)
EAL: Probe PCI driver: mlx5_pci (15b3:a2dc) device: 0000:01:00.0 (socket 0)
06:15:46.594565 CON phy_init 0 [FH.DOCA] doca_gpu_dmabuf_fd returned 0 (DOCA_SUCCESS is 0)
06:15:46.594577 CON phy_init 0 [FH.DOCA] Mapping transmit queue buffer (0xfdda00000000 size 4294967296B dmabuf fd 219) with dmabuf mode
PCAP_LOGGER Initialized
06:15:46.627652 CON phy_init 0 [FH.PEER] Doca sem created!: sem_in gpu_addr 0xfdec8e3a0000 cpu_addr 0x52ed33f5ee0
gRPC Server listening on 0.0.0.0:50051
06:15:47.121439 CON phy_main 0 [CTL.SCF]
====> PhyDriver initialized!
06:15:47.121662 CON phy_main 0 [NVIPC:YAML] nv_ipc_parse_yaml_node: PCAP msg_filter: enable all messages: 0x00-0xFF
06:15:47.121670 CON phy_main 0 [NVIPC:YAML] nv_ipc_parse_yaml_node: PCAP cell_filter: enable all cells 0-255
06:15:47.121881 CON phy_main 0 [NVIPC.DEBUG] nv_ipc_debug_open: prefix=nvipc fapi_type=1 pcap_sync_save=0 nvipc_version=25.2.0 OK
06:15:47.144948 CON 138 0 [NVIPC.DEBUG] pcap_shm_caching_thread_func: thread [nvipc_pcap_shm] started on CPU core [10] …
06:15:47.169645 CON 138 0 [NVIPC.DEBUG] Open PCAP logger: prefix=nvipc_pcap shm_caching_core=10 file_saving_core=10 max_data_size=8000 cache_size=512MB round_save_size=2048MB
06:15:47.179229 CON phy_main 0 [NVIPC.SHM] nvipc server initialized
06:15:47.179313 CON phy_main 0 [NVIPC.SHM] shm_ipc_open: forward_enable=-1 fw_max_msg_buf_count=1365 fw_max_data_buf_count=341
06:15:47.179318 CON phy_main 0 [NVIPC.SHM] create_shm_nv_ipc_interface: OK. buf_size: cpu_msg=15000 cpu_data=576000 cpu_large=4096000
06:15:47.179329 CON phy_main 0 [L2A.TRANSPORT] phy_mac_transport[0] created. phy_cell_map.size=0 mac_cell_map.size=0 mapped=false cell_num=1
06:15:47.179332 CON phy_main 0 [L2A.TRANSPORT] init: loaded 1 nvipc instance, total_cell_num=1
06:15:47.179363 CON phy_main 0 [L2A.MODULE] PHY_module: transport_num=1 total_cell_num=1
06:15:47.183399 CON 142 0 [NVIPC.EFD] [nvipc][core 10 ] share event_fd thread info: sched_policy=0 sched_priority=0
06:15:47.183457 CON 142 0 [NVIPC.EFD] [nvipc] Listening for nvipc client to connect …
06:15:47.208388 CON phy_main 0 [CTL.SCF] cuPHYController configured for 1 cells
06:15:47.208391 CON phy_main 0 [CTL.SCF]
====> cuPHYController initialized, L1 is ready!
06:15:47.208406 CON phy_main 0 [CTL.STARTUP_TIMES] {TI PERCENTAGE} Start Main:0.3,Parse Cuphycontroller YAML:0.0,Init nvlog:0.4,Cuda Set Device:17.4,Cuphy PTI Init:0.8,Init PHYDriver:78.3,Init cuphydriver:0.0,Make PHYDriverProxy:0.0,Init SCF FAPI:0.0,Create PHY_group:2.7,Start PHY_group:0.0, (total: 3229268.5us),
06:15:47.208410 CON phy_main 0 [CTL.STARTUP_TIMES] {TI DURATION} Start Main:10783.457,Parse Cuphycontroller YAML:1062.916,Init nvlog:12900.808,Cuda Set Device:560928.645,Cuphy PTI Init:27039.285,Init PHYDriver:2529606.398,Init cuphydriver:0.640,Make PHYDriverProxy:7.168,Init SCF FAPI:1.056,Create PHY_group:86736.791,Start PHY_group:201.345,
06:15:47.208412 CON phy_main 0 [CTL.STARTUP_TIMES] {TI TIMESTAMPS} Start Main:1762150543979121097,Parse Cuphycontroller YAML:1762150543989904554,Init nvlog:1762150543990967470,Cuda Set Device:1762150544003868278,Cuphy PTI Init:1762150544564796923,Init PHYDriver:1762150544591836208,Init cuphydriver:1762150547121442606,Make PHYDriverProxy:1762150547121443246,Init SCF FAPI:1762150547121450414,Create PHY_group:1762150547121451470,Start PHY_group:1762150547208188261,End Main:1762150547208389606,
06:15:47.208434 CON 144 0 [L2A.MODULE] cell_update_thread_func: OAM thread affinity set to cpu core 10
06:15:47.209129 CON msg_processing 0 [L2A.MODULE] Thread thread_func on CPU 9 initialized fmtlog
06:15:48.108358 CON UlPhyDriver05 0 [DRV.WORKER] Thread UlPhyDriver05(worker_default) on CPU 5 initialized fmtlog
06:15:48.108424 CON UlPhyDriver04 0 [DRV.WORKER] Thread UlPhyDriver04(worker_default) on CPU 4 initialized fmtlog
06:15:48.108462 CON DlPhyDriver08 0 [DRV.WORKER] Thread DlPhyDriver08(worker_default) on CPU 8 initialized fmtlog
06:15:48.108504 CON DlPhyDriver07 0 [DRV.WORKER] Thread DlPhyDriver07(worker_default) on CPU 7 initialized fmtlog
06:15:48.108513 CON DlPhyDriver06 0 [DRV.WORKER] Thread DlPhyDriver06(worker_default) on CPU 6 initialized fmtlog
06:16:05.278346 CON 142 0 [NVIPC.EFD] [nvipc] nvipc unix socket server connected
06:16:05.278386 CON 142 0 [NVIPC.EFD] [nvipc] Received peer event_fd: 228
06:16:05.478466 CON 142 0 [NVIPC.EFD] Share event_fd succeed: efd_tx=228, efd_rx=238
06:16:05.478467 CON 142 0 [NVIPC.EFD] [nvipc] Listening for nvipc client to connect …
06:16:06.385240 WRN msg_processing 0 [SCF.PHY] RECV: msg_len is not set correctly: cell_id=0 msg_id=0x02 msg_len=6201 head_len=8 body_len=6185
06:16:06.385253 CON msg_processing 0 [SCF.PHY] on_config_request: cell_id=0 numTLVs=33 state=0
06:16:06.385504 WRN msg_processing 0 [SCF.PHY] on_config_request unknown config request message ID 4171
06:16:06.385538 CON msg_processing 0 [SCF.PHY] PHY Cell Id = 51, M-Plane Id= 1
06:16:06.392504 CON msg_processing 0 [DRV.PUSCH] tvStatPrms: PUSCH enableDeviceGraphLaunch=1 enableCsiP2Fapiv3 = 0 nMaxLdpcHetConfigs = 32
06:16:06.392508 CON msg_processing 0 [DRV.PUSCH] static_params.nMaxPrb: 273
06:16:06.392508 CON msg_processing 0 [DRV.PUSCH] static_params.nMaxRx: 4
06:16:06.398331 CON msg_processing 0 [CUPHY.MEMFOOT] cuphyMemoryFootprint - GPU allocation: 54.706 MiB for cuPHY PUSCH channel object (0x52f4d4b6000).
06:16:06.398332 CON msg_processing 0 [CUPHY.PUSCH_RX] PuschRx: Running with eqCoeffAlgo 3
06:16:06.401978 CON msg_processing 0 [DRV.PUSCH] tvStatPrms: PUSCH enableDeviceGraphLaunch=1 enableCsiP2Fapiv3 = 0 nMaxLdpcHetConfigs = 32
06:16:06.401978 CON msg_processing 0 [DRV.PUSCH] static_params.nMaxPrb: 273
06:16:06.401978 CON msg_processing 0 [DRV.PUSCH] static_params.nMaxRx: 4
06:16:06.407007 CON msg_processing 0 [CUPHY.MEMFOOT] cuphyMemoryFootprint - GPU allocation: 54.706 MiB for cuPHY PUSCH channel object (0x52f4d4c2000).
06:16:06.407007 CON msg_processing 0 [CUPHY.PUSCH_RX] PuschRx: Running with eqCoeffAlgo 3
06:16:06.410611 CON msg_processing 0 [DRV.PUSCH] tvStatPrms: PUSCH enableDeviceGraphLaunch=1 enableCsiP2Fapiv3 = 0 nMaxLdpcHetConfigs = 32
06:16:06.410611 CON msg_processing 0 [DRV.PUSCH] static_params.nMaxPrb: 273
06:16:06.410612 CON msg_processing 0 [DRV.PUSCH] static_params.nMaxRx: 4
06:16:06.415784 CON msg_processing 0 [CUPHY.MEMFOOT] cuphyMemoryFootprint - GPU allocation: 54.706 MiB for cuPHY PUSCH channel object (0x52f4d4ce000).
06:16:06.415785 CON msg_processing 0 [CUPHY.PUSCH_RX] PuschRx: Running with eqCoeffAlgo 3
06:16:06.417966 CON msg_processing 0 [CUPHY.MEMFOOT] cuphyMemoryFootprint - GPU allocation: 3.341 MiB for cuPHY PUCCH channel object (0x52f4ec50000).
06:16:06.418947 CON msg_processing 0 [CUPHY.MEMFOOT] cuphyMemoryFootprint - GPU allocation: 3.341 MiB for cuPHY PUCCH channel object (0x52f4ec50e00).
06:16:06.419730 CON msg_processing 0 [CUPHY.MEMFOOT] cuphyMemoryFootprint - GPU allocation: 3.341 MiB for cuPHY PUCCH channel object (0x52f4ec51c00).
06:16:06.420569 CON msg_processing 0 [CUPHY.MEMFOOT] cuphyMemoryFootprint - GPU allocation: 3.341 MiB for cuPHY PUCCH channel object (0x52f4ec52a00).
06:16:06.422351 CON msg_processing 0 [CUPHY.MEMFOOT] cuphyMemoryFootprint - GPU allocation: 0.112 MiB for cuPHY PRACH channel object (0x52f4e6fd600).
06:16:06.422848 CON msg_processing 0 [CUPHY.MEMFOOT] cuphyMemoryFootprint - GPU allocation: 0.112 MiB for cuPHY PRACH channel object (0x52f4e6fd7c0).
06:16:06.442199 CON msg_processing 0 [CUPHY.MEMFOOT] cuphyMemoryFootprint - GPU allocation: 3.587 MiB for cuPHY SRS channel object (0x52f4e30d280).
06:16:06.459614 CON msg_processing 0 [CUPHY.MEMFOOT] cuphyMemoryFootprint - GPU allocation: 3.587 MiB for cuPHY SRS channel object (0x52f4e30d600).
06:16:06.476765 CON msg_processing 0 [CUPHY.MEMFOOT] cuphyMemoryFootprint - GPU allocation: 3.587 MiB for cuPHY SRS channel object (0x52f4e30d980).
06:16:06.482458 CON msg_processing 0 [CUPHY.MEMFOOT] cuphyMemoryFootprint - GPU allocation: 98.130 MiB for cuPHY PDSCH channel object (0x52f4ec31800).
06:16:06.487280 CON msg_processing 0 [CUPHY.MEMFOOT] cuphyMemoryFootprint - GPU allocation: 98.130 MiB for cuPHY PDSCH channel object (0x52f4ec39000).
06:16:06.491997 CON msg_processing 0 [CUPHY.MEMFOOT] cuphyMemoryFootprint - GPU allocation: 98.130 MiB for cuPHY PDSCH channel object (0x52f4ec3a800).
06:16:06.497076 CON msg_processing 0 [CUPHY.MEMFOOT] cuphyMemoryFootprint - GPU allocation: 98.130 MiB for cuPHY PDSCH channel object (0x52f4ec3c000).
06:16:06.502228 CON msg_processing 0 [CUPHY.MEMFOOT] cuphyMemoryFootprint - GPU allocation: 98.130 MiB for cuPHY PDSCH channel object (0x52f4ec3d800).
06:16:06.507222 CON msg_processing 0 [CUPHY.MEMFOOT] cuphyMemoryFootprint - GPU allocation: 98.130 MiB for cuPHY PDSCH channel object (0x52f4ec3f000).
06:16:06.512415 CON msg_processing 0 [CUPHY.MEMFOOT] cuphyMemoryFootprint - GPU allocation: 98.130 MiB for cuPHY PDSCH channel object (0x52f64840c00).
06:16:06.517511 CON msg_processing 0 [CUPHY.MEMFOOT] cuphyMemoryFootprint - GPU allocation: 98.130 MiB for cuPHY PDSCH channel object (0x52f64842400).
06:16:06.522806 CON msg_processing 0 [CUPHY.MEMFOOT] cuphyMemoryFootprint - GPU allocation: 98.130 MiB for cuPHY PDSCH channel object (0x52f64843c00).
06:16:06.527988 CON msg_processing 0 [CUPHY.MEMFOOT] cuphyMemoryFootprint - GPU allocation: 98.130 MiB for cuPHY PDSCH channel object (0x52f64845400).
06:16:06.529408 CON msg_processing 0 [CUPHY.MEMFOOT] cuphyMemoryFootprint - GPU allocation: 0.001 MiB for cuPHY SSB channel object (0x52f4e30e080).
06:16:06.529617 CON msg_processing 0 [CUPHY.MEMFOOT] cuphyMemoryFootprint - GPU allocation: 0.001 MiB for cuPHY SSB channel object (0x52f4e30dd00).
06:16:06.529762 CON msg_processing 0 [CUPHY.MEMFOOT] cuphyMemoryFootprint - GPU allocation: 0.001 MiB for cuPHY SSB channel object (0x52f4e30e780).
06:16:06.529914 CON msg_processing 0 [CUPHY.MEMFOOT] cuphyMemoryFootprint - GPU allocation: 0.001 MiB for cuPHY SSB channel object (0x52f4e30e400).
06:16:06.530065 CON msg_processing 0 [CUPHY.MEMFOOT] cuphyMemoryFootprint - GPU allocation: 0.001 MiB for cuPHY SSB channel object (0x52f4e30eb00).
06:16:06.530216 CON msg_processing 0 [CUPHY.MEMFOOT] cuphyMemoryFootprint - GPU allocation: 0.001 MiB for cuPHY SSB channel object (0x52f4e30ee80).
06:16:06.530367 CON msg_processing 0 [CUPHY.MEMFOOT] cuphyMemoryFootprint - GPU allocation: 0.001 MiB for cuPHY SSB channel object (0x52f4e30f200).
06:16:06.530507 CON msg_processing 0 [CUPHY.MEMFOOT] cuphyMemoryFootprint - GPU allocation: 0.001 MiB for cuPHY SSB channel object (0x52f4e30f580).
06:16:06.530641 CON msg_processing 0 [CUPHY.MEMFOOT] cuphyMemoryFootprint - GPU allocation: 0.001 MiB for cuPHY SSB channel object (0x52f4e30f900).
06:16:06.530777 CON msg_processing 0 [CUPHY.MEMFOOT] cuphyMemoryFootprint - GPU allocation: 0.001 MiB for cuPHY SSB channel object (0x52f4e30fc80).
06:16:06.531056 CON msg_processing 0 [CUPHY.MEMFOOT] cuphyMemoryFootprint - GPU allocation: 0.965 MiB for cuPHY PDCCH channel object (0x52f4eb7e100).
06:16:06.531223 CON msg_processing 0 [CUPHY.MEMFOOT] cuphyMemoryFootprint - GPU allocation: 0.965 MiB for cuPHY PDCCH channel object (0x52f4eb7f000).
06:16:06.531469 CON msg_processing 0 [CUPHY.MEMFOOT] cuphyMemoryFootprint - GPU allocation: 0.965 MiB for cuPHY PDCCH channel object (0x52f4eb7f500).
06:16:06.531612 CON msg_processing 0 [CUPHY.MEMFOOT] cuphyMemoryFootprint - GPU allocation: 0.965 MiB for cuPHY PDCCH channel object (0x52f4eb7fa00).
06:16:06.531866 CON msg_processing 0 [CUPHY.MEMFOOT] cuphyMemoryFootprint - GPU allocation: 0.965 MiB for cuPHY PDCCH channel object (0x52f65b60000).
06:16:06.532010 CON msg_processing 0 [CUPHY.MEMFOOT] cuphyMemoryFootprint - GPU allocation: 0.965 MiB for cuPHY PDCCH channel object (0x52f65b60500).
06:16:06.532327 CON msg_processing 0 [CUPHY.MEMFOOT] cuphyMemoryFootprint - GPU allocation: 0.965 MiB for cuPHY PDCCH channel object (0x52f65b60a00).
06:16:06.532638 CON msg_processing 0 [CUPHY.MEMFOOT] cuphyMemoryFootprint - GPU allocation: 0.965 MiB for cuPHY PDCCH channel object (0x52f65b60f00).
06:16:06.532887 CON msg_processing 0 [CUPHY.MEMFOOT] cuphyMemoryFootprint - GPU allocation: 0.965 MiB for cuPHY PDCCH channel object (0x52f65b61400).
06:16:06.533044 CON msg_processing 0 [CUPHY.MEMFOOT] cuphyMemoryFootprint - GPU allocation: 0.965 MiB for cuPHY PDCCH channel object (0x52f65b61900).
06:16:06.533254 CON msg_processing 0 [CUPHY.MEMFOOT] cuphyMemoryFootprint - GPU allocation: 0.093 MiB for cuPHY CSIRS channel object (0x52f658fbd80).
06:16:06.533389 CON msg_processing 0 [CUPHY.MEMFOOT] cuphyMemoryFootprint - GPU allocation: 0.093 MiB for cuPHY CSIRS channel object (0x52f658fc080).
06:16:06.533623 CON msg_processing 0 [CUPHY.MEMFOOT] cuphyMemoryFootprint - GPU allocation: 0.093 MiB for cuPHY CSIRS channel object (0x52f658fc380).
06:16:06.533746 CON msg_processing 0 [CUPHY.MEMFOOT] cuphyMemoryFootprint - GPU allocation: 0.093 MiB for cuPHY CSIRS channel object (0x52f658fe180).
06:16:06.533846 CON msg_processing 0 [CUPHY.MEMFOOT] cuphyMemoryFootprint - GPU allocation: 0.093 MiB for cuPHY CSIRS channel object (0x52f658fe480).
06:16:06.533949 CON msg_processing 0 [CUPHY.MEMFOOT] cuphyMemoryFootprint - GPU allocation: 0.093 MiB for cuPHY CSIRS channel object (0x52f658fe780).
06:16:06.534049 CON msg_processing 0 [CUPHY.MEMFOOT] cuphyMemoryFootprint - GPU allocation: 0.093 MiB for cuPHY CSIRS channel object (0x52f658fea80).
06:16:06.534146 CON msg_processing 0 [CUPHY.MEMFOOT] cuphyMemoryFootprint - GPU allocation: 0.093 MiB for cuPHY CSIRS channel object (0x52f658fed80).
06:16:06.534254 CON msg_processing 0 [CUPHY.MEMFOOT] cuphyMemoryFootprint - GPU allocation: 0.093 MiB for cuPHY CSIRS channel object (0x52f658ff080).
06:16:06.534555 CON msg_processing 0 [CUPHY.MEMFOOT] cuphyMemoryFootprint - GPU allocation: 0.093 MiB for cuPHY CSIRS channel object (0x52f658ff380).
06:16:06.534568 CON msg_processing 0 [DRV.API] Update cell: mplane_id=1 dl_grid_sz=273
06:16:06.534569 CON msg_processing 0 [DRV.API] Update cell: mplane_id=1 ul_grid_sz=273
06:16:06.534574 CON msg_processing 0 [SCF.PHY] on_config_request: create_cell_configs for cell_id=0 phy_cell_id=51 returned error_code=0
06:16:06.534585 CON msg_processing 0 [SCF.PHY] Send CONFIG.response: cell_id=0 error_code=0x0
06:16:06.534613 CON msg_processing 0 [L2A.TRANSPORT] wrapper: configured_cells_mask=0x1 expected_mask=0x1 all_cells_configured=true - all cells configured
06:16:06.534645 WRN msg_processing 0 [SCF.PHY] RECV: msg_len is not set correctly: cell_id=0 msg_id=0x04 msg_len=16 head_len=8 body_len=0
06:16:06.534647 CON msg_processing 0 [SCF.PHY] on_cell_start_request: Cell 0 Received START.request, sending START.response… phy_cell_id=51
06:16:06.534804 CON msg_processing 0 [L2A.TRANSPORT] wrapper: configured_cells_mask=0x1 expected_mask=0x1 all_cells_configured=true - all cells configured
06:16:06.536554 CON timer_thread 0 [L2A.TICK] Thread slot_indication_thread_sleep_method initialized fmtlog
06:16:06.536557 CON timer_thread 0 [L2A.TICK] PTP Configs: gps_alpha: 0 gps_beta: 0
06:16:06.536561 CON timer_thread 0 [L2A.TICK] Start time: tick=1762150566536555266, seconds since epoch = 1762150566, nanoseconds = 536555266
06:16:06.536562 CON timer_thread 0 [L2A.TICK] FIRST tick scheduled for: tick=1762150567480000000, seconds since epoch = 1762150567, nanoseconds = 480000000
06:16:07.480026 CON timer_thread 0 [SCF.PHY] Cell 0 | DL 0.00 Mbps 0 Slots | UL 0.00 Mbps 0 Slots CRC 0 ( 0) | Tick 0
06:16:07.511972 ERR UlPhyDriver04 0 [AERIAL_CUPHY_API_EVENT] [DRV.FUNC_UL] SFN 2.19 Slot Map 1 cell index 0 Dyn index -1 setting as unhealthy!
06:16:08.480006 CON timer_thread 0 [SCF.PHY] Cell 0 | DL 0.00 Mbps 0 Slots | UL 0.00 Mbps 0 Slots CRC 0 ( 0) | Tick 2000
06:16:08.510414 ERR UlPhyDriver04 0 [AERIAL_CUPHY_API_EVENT] [DRV.FUNC_UL] SFN 102.19 Slot Map 101 cell index 0 Dyn index -1 setting as healthy!
06:16:08.531963 ERR UlPhyDriver04 0 [AERIAL_CUPHY_API_EVENT] [DRV.FUNC_UL] SFN 104.19 Slot Map 103 cell index 0 Dyn index -1 setting as unhealthy!
06:16:09.480005 CON timer_thread 0 [SCF.PHY] Cell 0 | DL 0.04 Mbps 50 Slots | UL 0.00 Mbps 0 Slots CRC 0 ( 0) | Tick 4000
06:16:09.530414 ERR UlPhyDriver04 0 [AERIAL_CUPHY_API_EVENT] [DRV.FUNC_UL] SFN 204.19 Slot Map 203 cell index 0 Dyn index -1 setting as healthy!
06:16:09.551964 ERR UlPhyDriver05 0 [AERIAL_CUPHY_API_EVENT] [DRV.FUNC_UL] SFN 206.19 Slot Map 205 cell index 0 Dyn index -1 setting as unhealthy!
06:16:10.480008 CON timer_thread 0 [SCF.PHY] Cell 0 | DL 0.04 Mbps 50 Slots | UL 0.00 Mbps 0 Slots CRC 0 ( 0) | Tick 6000
06:16:10.550413 ERR UlPhyDriver05 0 [AERIAL_CUPHY_API_EVENT] [DRV.FUNC_UL] SFN 306.19 Slot Map 305 cell index 0 Dyn index -1 setting as healthy!
06:16:10.571965 ERR UlPhyDriver04 0 [AERIAL_CUPHY_API_EVENT] [DRV.FUNC_UL] SFN 308.19 Slot Map 307 cell index 0 Dyn index -1 setting as unhealthy!
06:16:11.480005 CON timer_thread 0 [SCF.PHY] Cell 0 | DL 0.04 Mbps 50 Slots | UL 0.00 Mbps 0 Slots CRC 0 ( 0) | Tick 8000
06:16:11.570414 ERR UlPhyDriver05 0 [AERIAL_CUPHY_API_EVENT] [DRV.FUNC_UL] SFN 408.19 Slot Map 407 cell index 0 Dyn index -1 setting as healthy!
06:16:11.591962 ERR UlPhyDriver04 0 [AERIAL_CUPHY_API_EVENT] [DRV.FUNC_UL] SFN 410.19 Slot Map 409 cell index 0 Dyn index -1 setting as unhealthy!
06:16:12.480006 CON timer_thread 0 [SCF.PHY] Cell 0 | DL 0.04 Mbps 50 Slots | UL 0.00 Mbps 0 Slots CRC 0 ( 0) | Tick 10000
06:16:12.590415 ERR UlPhyDriver04 0 [AERIAL_CUPHY_API_EVENT] [DRV.FUNC_UL] SFN 510.19 Slot Map 509 cell index 0 Dyn index -1 setting as healthy!
06:16:12.611963 ERR UlPhyDriver04 0 [AERIAL_CUPHY_API_EVENT] [DRV.FUNC_UL] SFN 512.19 Slot Map 511 cell index 0 Dyn index -1 setting as unhealthy!
06:16:13.480007 CON timer_thread 0 [SCF.PHY] Cell 0 | DL 0.04 Mbps 50 Slots | UL 0.00 Mbps 0 Slots CRC 0 ( 0) | Tick 12000
06:16:13.610413 ERR UlPhyDriver05 0 [AERIAL_CUPHY_API_EVENT] [DRV.FUNC_UL] SFN 612.19 Slot Map 99 cell index 0 Dyn index -1 setting as healthy!
06:16:13.631965 ERR UlPhyDriver05 0 [AERIAL_CUPHY_API_EVENT] [DRV.FUNC_UL] SFN 614.19 Slot Map 101 cell index 0 Dyn index -1 setting as unhealthy!
06:16:14.480005 CON timer_thread 0 [SCF.PHY] Cell 0 | DL 0.04 Mbps 50 Slots | UL 0.00 Mbps 0 Slots CRC 0 ( 0) | Tick 14000
06:16:14.630413 ERR UlPhyDriver05 0 [AERIAL_CUPHY_API_EVENT] [DRV.FUNC_UL] SFN 714.19 Slot Map 201 cell index 0 Dyn index -1 setting as healthy!
06:16:14.651965 ERR UlPhyDriver05 0 [AERIAL_CUPHY_API_EVENT] [DRV.FUNC_UL] SFN 716.19 Slot Map 203 cell index 0 Dyn index -1 setting as unhealthy!
06:16:15.480005 CON timer_thread 0 [SCF.PHY] Cell 0 | DL 0.04 Mbps 50 Slots | UL 0.00 Mbps 0 Slots CRC 0 ( 0) | Tick 16000
06:16:15.650413 ERR UlPhyDriver05 0 [AERIAL_CUPHY_API_EVENT] [DRV.FUNC_UL] SFN 816.19 Slot Map 303 cell index 0 Dyn index -1 setting as healthy!
06:16:15.671966 ERR UlPhyDriver05 0 [AERIAL_CUPHY_API_EVENT] [DRV.FUNC_UL] SFN 818.19 Slot Map 305 cell index 0 Dyn index -1 setting as unhealthy!
06:16:16.480005 CON timer_thread 0 [SCF.PHY] Cell 0 | DL 0.04 Mbps 50 Slots | UL 0.00 Mbps 0 Slots CRC 0 ( 0) | Tick 18000
06:16:16.670413 ERR UlPhyDriver05 0 [AERIAL_CUPHY_API_EVENT] [DRV.FUNC_UL] SFN 918.19 Slot Map 405 cell index 0 Dyn index -1 setting as healthy!
06:16:16.691964 ERR UlPhyDriver04 0 [AERIAL_CUPHY_API_EVENT] [DRV.FUNC_UL] SFN 920.19 Slot Map 407 cell index 0 Dyn index -1 setting as unhealthy!
06:16:17.480005 CON timer_thread 0 [SCF.PHY] Cell 0 | DL 0.04 Mbps 50 Slots | UL 0.00 Mbps 0 Slots CRC 0 ( 0) | Tick 20000
06:16:17.690415 ERR UlPhyDriver05 0 [AERIAL_CUPHY_API_EVENT] [DRV.FUNC_UL] SFN 1020.19 Slot Map 507 cell index 0 Dyn index -1 setting as healthy!
06:16:17.711966 ERR UlPhyDriver05 0 [AERIAL_CUPHY_API_EVENT] [DRV.FUNC_UL] SFN 1022.19 Slot Map 509 cell index 0 Dyn index -1 setting as unhealthy!
06:16:18.480006 CON timer_thread 0 [SCF.PHY] Cell 0 | DL 0.04 Mbps 50 Slots | UL 0.00 Mbps 0 Slots CRC 0 ( 0) | Tick 22000
06:16:18.710412 ERR UlPhyDriver04 0 [AERIAL_CUPHY_API_EVENT] [DRV.FUNC_UL] SFN 98.19 Slot Map 97 cell index 0 Dyn index -1 setting as healthy!
06:16:18.731963 ERR UlPhyDriver04 0 [AERIAL_CUPHY_API_EVENT] [DRV.FUNC_UL] SFN 100.19 Slot Map 99 cell index 0 Dyn index -1 setting as unhealthy!
06:16:19.480006 CON timer_thread 0 [SCF.PHY] Cell 0 | DL 0.04 Mbps 50 Slots | UL 0.00 Mbps 0 Slots CRC 0 ( 0) | Tick 24000
06:16:19.730413 ERR UlPhyDriver04 0 [AERIAL_CUPHY_API_EVENT] [DRV.FUNC_UL] SFN 200.19 Slot Map 199 cell index 0 Dyn index -1 setting as healthy!
06:16:19.751962 ERR UlPhyDriver04 0 [AERIAL_CUPHY_API_EVENT] [DRV.FUNC_UL] SFN 202.19 Slot Map 201 cell index 0 Dyn index -1 setting as unhealthy!
06:16:20.480005 CON timer_thread 0 [SCF.PHY] Cell 0 | DL 0.04 Mbps 50 Slots | UL 0.00 Mbps 0 Slots CRC 0 ( 0) | Tick 26000
06:16:20.750415 ERR UlPhyDriver05 0 [AERIAL_CUPHY_API_EVENT] [DRV.FUNC_UL] SFN 302.19 Slot Map 301 cell index 0 Dyn index -1 setting as healthy!
06:16:20.771961 ERR UlPhyDriver04 0 [AERIAL_CUPHY_API_EVENT] [DRV.FUNC_UL] SFN 304.19 Slot Map 303 cell index 0 Dyn index -1 setting as unhealthy!
06:16:21.480005 CON timer_thread 0 [SCF.PHY] Cell 0 | DL 0.04 Mbps 50 Slots | UL 0.00 Mbps 0 Slots CRC 0 ( 0) | Tick 28000
06:16:21.770414 ERR UlPhyDriver05 0 [AERIAL_CUPHY_API_EVENT] [DRV.FUNC_UL] SFN 404.19 Slot Map 403 cell index 0 Dyn index -1 setting as healthy!
06:16:21.791964 ERR UlPhyDriver04 0 [AERIAL_CUPHY_API_EVENT] [DRV.FUNC_UL] SFN 406.19 Slot Map 405 cell index 0 Dyn index -1 setting as unhealthy!
06:16:22.480006 CON timer_thread 0 [SCF.PHY] Cell 0 | DL 0.04 Mbps 50 Slots | UL 0.00 Mbps 0 Slots CRC 0 ( 0) | Tick 30000
06:16:22.790415 ERR UlPhyDriver05 0 [AERIAL_CUPHY_API_EVENT] [DRV.FUNC_UL] SFN 506.19 Slot Map 505 cell index 0 Dyn index -1 setting as healthy!
06:16:22.811965 ERR UlPhyDriver05 0 [AERIAL_CUPHY_API_EVENT] [DRV.FUNC_UL] SFN 508.19 Slot Map 507 cell index 0 Dyn index -1 setting as unhealthy!
06:16:23.480005 CON timer_thread 0 [SCF.PHY] Cell 0 | DL 0.04 Mbps 50 Slots | UL 0.00 Mbps 0 Slots CRC 0 ( 0) | Tick 32000
06:16:23.810413 ERR UlPhyDriver04 0 [AERIAL_CUPHY_API_EVENT] [DRV.FUNC_UL] SFN 608.19 Slot Map 95 cell index 0 Dyn index -1 setting as healthy!
06:16:23.831966 ERR UlPhyDriver04 0 [AERIAL_CUPHY_API_EVENT] [DRV.FUNC_UL] SFN 610.19 Slot Map 97 cell index 0 Dyn index -1 setting as unhealthy!
06:16:24.480005 CON timer_thread 0 [SCF.PHY] Cell 0 | DL 0.04 Mbps 50 Slots | UL 0.00 Mbps 0 Slots CRC 0 ( 0) | Tick 34000
06:16:24.830416 ERR UlPhyDriver05 0 [AERIAL_CUPHY_API_EVENT] [DRV.FUNC_UL] SFN 710.19 Slot Map 197 cell index 0 Dyn index -1 setting as healthy!
06:16:24.851963 ERR UlPhyDriver04 0 [AERIAL_CUPHY_API_EVENT] [DRV.FUNC_UL] SFN 712.19 Slot Map 199 cell index 0 Dyn index -1 setting as unhealthy!
06:16:25.480005 CON timer_thread 0 [SCF.PHY] Cell 0 | DL 0.04 Mbps 50 Slots | UL 0.00 Mbps 0 Slots CRC 0 ( 0) | Tick 36000
06:16:25.850413 ERR UlPhyDriver05 0 [AERIAL_CUPHY_API_EVENT] [DRV.FUNC_UL] SFN 812.19 Slot Map 299 cell index 0 Dyn index -1 setting as healthy!
06:16:25.871966 ERR UlPhyDriver05 0 [AERIAL_CUPHY_API_EVENT] [DRV.FUNC_UL] SFN 814.19 Slot Map 301 cell index 0 Dyn index -1 setting as unhealthy!
06:16:26.480006 CON timer_thread 0 [SCF.PHY] Cell 0 | DL 0.04 Mbps 50 Slots | UL 0.00 Mbps 0 Slots CRC 0 ( 0) | Tick 38000
06:16:26.870414 ERR UlPhyDriver05 0 [AERIAL_CUPHY_API_EVENT] [DRV.FUNC_UL] SFN 914.19 Slot Map 401 cell index 0 Dyn index -1 setting as healthy!
06:16:26.891962 ERR UlPhyDriver05 0 [AERIAL_CUPHY_API_EVENT] [DRV.FUNC_UL] SFN 916.19 Slot Map 403 cell index 0 Dyn index -1 setting as unhealthy!
06:16:27.480005 CON timer_thread 0 [SCF.PHY] Cell 0 | DL 0.04 Mbps 50 Slots | UL 0.00 Mbps 0 Slots CRC 0 ( 0) | Tick 40000
06:16:27.890414 ERR UlPhyDriver04 0 [AERIAL_CUPHY_API_EVENT] [DRV.FUNC_UL] SFN 1016.19 Slot Map 503 cell index 0 Dyn index -1 setting as healthy!
06:16:27.911969 ERR UlPhyDriver04 0 [AERIAL_CUPHY_API_EVENT] [DRV.FUNC_UL] SFN 1018.19 Slot Map 505 cell index 0 Dyn index -1 setting as unhealthy!
06:16:28.480006 CON timer_thread 0 [SCF.PHY] Cell 0 | DL 0.04 Mbps 50 Slots | UL 0.00 Mbps 0 Slots CRC 0 ( 0) | Tick 42000
06:16:28.910413 ERR UlPhyDriver05 0 [AERIAL_CUPHY_API_EVENT] [DRV.FUNC_UL] SFN 94.19 Slot Map 93 cell index 0 Dyn index -1 setting as healthy!
06:16:28.931966 ERR UlPhyDriver04 0 [AERIAL_CUPHY_API_EVENT] [DRV.FUNC_UL] SFN 96.19 Slot Map 95 cell index 0 Dyn index -1 setting as unhealthy!
06:16:29.480006 CON timer_thread 0 [SCF.PHY] Cell 0 | DL 0.04 Mbps 50 Slots | UL 0.00 Mbps 0 Slots CRC 0 ( 0) | Tick 44000
06:16:29.930414 ERR UlPhyDriver04 0 [AERIAL_CUPHY_API_EVENT] [DRV.FUNC_UL] SFN 196.19 Slot Map 195 cell index 0 Dyn index -1 setting as healthy!
06:16:29.951966 ERR UlPhyDriver04 0 [AERIAL_CUPHY_API_EVENT] [DRV.FUNC_UL] SFN 198.19 Slot Map 197 cell index 0 Dyn index -1 setting as unhealthy!
06:16:30.480005 CON timer_thread 0 [SCF.PHY] Cell 0 | DL 0.04 Mbps 50 Slots | UL 0.00 Mbps 0 Slots CRC 0 ( 0) | Tick 46000
06:16:30.950414 ERR UlPhyDriver05 0 [AERIAL_CUPHY_API_EVENT] [DRV.FUNC_UL] SFN 298.19 Slot Map 297 cell index 0 Dyn index -1 setting as healthy!
06:16:30.971965 ERR UlPhyDriver04 0 [AERIAL_CUPHY_API_EVENT] [DRV.FUNC_UL] SFN 300.19 Slot Map 299 cell index 0 Dyn index -1 setting as unhealthy!
06:16:31.480007 CON timer_thread 0 [SCF.PHY] Cell 0 | DL 0.04 Mbps 50 Slots | UL 0.00 Mbps 0 Slots CRC 0 ( 0) | Tick 48000
06:16:31.970413 ERR UlPhyDriver05 0 [AERIAL_CUPHY_API_EVENT] [DRV.FUNC_UL] SFN 400.19 Slot Map 399 cell index 0 Dyn index -1 setting as healthy!
06:16:31.991965 ERR UlPhyDriver04 0 [AERIAL_CUPHY_API_EVENT] [DRV.FUNC_UL] SFN 402.19 Slot Map 401 cell index 0 Dyn index -1 setting as unhealthy!
06:16:32.480005 CON timer_thread 0 [SCF.PHY] Cell 0 | DL 0.04 Mbps 50 Slots | UL 0.00 Mbps 0 Slots CRC 0 ( 0) | Tick 50000
06:16:32.990414 ERR UlPhyDriver04 0 [AERIAL_CUPHY_API_EVENT] [DRV.FUNC_UL] SFN 502.19 Slot Map 501 cell index 0 Dyn index -1 setting as healthy!
06:16:33.011967 ERR UlPhyDriver04 0 [AERIAL_CUPHY_API_EVENT] [DRV.FUNC_UL] SFN 504.19 Slot Map 503 cell index 0 Dyn index -1 setting as unhealthy!
06:16:33.480005 CON timer_thread 0 [SCF.PHY] Cell 0 | DL 0.04 Mbps 50 Slots | UL 0.00 Mbps 0 Slots CRC 0 ( 0) | Tick 52000
06:16:34.010415 ERR UlPhyDriver04 0 [AERIAL_CUPHY_API_EVENT] [DRV.FUNC_UL] SFN 604.19 Slot Map 91 cell index 0 Dyn index -1 setting as healthy!
06:16:34.031965 ERR UlPhyDriver05 0 [AERIAL_CUPHY_API_EVENT] [DRV.FUNC_UL] SFN 606.19 Slot Map 93 cell index 0 Dyn index -1 setting as unhealthy!
06:16:34.480006 CON timer_thread 0 [SCF.PHY] Cell 0 | DL 0.04 Mbps 50 Slots | UL 0.00 Mbps 0 Slots CRC 0 ( 0) | Tick 54000
06:16:35.030414 ERR UlPhyDriver05 0 [AERIAL_CUPHY_API_EVENT] [DRV.FUNC_UL] SFN 706.19 Slot Map 193 cell index 0 Dyn index -1 setting as healthy!
06:16:35.051963 ERR UlPhyDriver04 0 [AERIAL_CUPHY_API_EVENT] [DRV.FUNC_UL] SFN 708.19 Slot Map 195 cell index 0 Dyn index -1 setting as unhealthy!
06:16:35.480006 CON timer_thread 0 [SCF.PHY] Cell 0 | DL 0.04 Mbps 50 Slots | UL 0.00 Mbps 0 Slots CRC 0 ( 0) | Tick 56000
06:16:36.050412 ERR UlPhyDriver05 0 [AERIAL_CUPHY_API_EVENT] [DRV.FUNC_UL] SFN 808.19 Slot Map 295 cell index 0 Dyn index -1 setting as healthy!
06:16:36.071967 ERR UlPhyDriver04 0 [AERIAL_CUPHY_API_EVENT] [DRV.FUNC_UL] SFN 810.19 Slot Map 297 cell index 0 Dyn index -1 setting as unhealthy!
06:16:36.480005 CON timer_thread 0 [SCF.PHY] Cell 0 | DL 0.04 Mbps 50 Slots | UL 0.00 Mbps 0 Slots CRC 0 ( 0) | Tick 58000
06:16:37.070413 ERR UlPhyDriver04 0 [AERIAL_CUPHY_API_EVENT] [DRV.FUNC_UL] SFN 910.19 Slot Map 397 cell index 0 Dyn index -1 setting as healthy!
06:16:37.091965 ERR UlPhyDriver04 0 [AERIAL_CUPHY_API_EVENT] [DRV.FUNC_UL] SFN 912.19 Slot Map 399 cell index 0 Dyn index -1 setting as unhealthy!
06:16:37.480004 CON timer_thread 0 [SCF.PHY] Cell 0 | DL 0.03 Mbps 41 Slots | UL 0.00 Mbps 0 Slots CRC 0 ( 0) | Tick 60000
