Please review LiteON O-RU configuration for DGX Spark + FibroLAN Falcon RX + Aerial Testbed 1.0
Hi NVIDIA Aerial team,
We are currently bringing up an O-RAN testbed with the following setup:
  • Server: DGX Spark
  • Timing / PTP: FibroLAN Falcon RX
  • O-RU: LiteON O-RU
  • Software: Aerial CUDA-Accelerated RAN / cuBB 26-1
  • Testbed: Aerial Testbed 1.0
The LiteON O-RU has already synchronized to PTP and the RF state is ready, but the O-RU still reports DuConnected : notReady.
Current LiteON O-RU configuration:
# show running-config
Band Width = 100000000
Center Frequency = 3750000000
Compression Bit = 9
Control and User Plane vlan = 2
M Plane vlan = 100
default gateway = 10.101.131.254
dpd mode : Enable
DU MAC Address = 4cbb472ff26b
phase compensation mode : Enable
RX gain = 14
TX power = 24
subcarrier spacing = 1
rj45_vlan_ip = 10.101.131.61
SFP_vlan_ip = 10.101.131.62
SFP_non_vlan_static_ip = 192.168.1.100
prach eAxC-id port 0, 1, 2, 3 = 0x0004, 0x0005, 0x0006, 0x0007
slotid = 0x00000001
jumboframe = 0x00000001
sync source : PTP
O-RU status:
# show oru-status
Sync State  : SYNCHRONIZED
RF State    : Ready
DPD         : Ready
Our current assumption is that the PTP side is working correctly, and the remaining issue is likely related to C/U-plane connectivity or parameter mismatch between the Aerial DU configuration and the LiteON O-RU configuration.
Could you please review the above LiteON O-RU settings and advise whether any of them should be changed for DGX Spark + FibroLAN Falcon RX + LiteON O-RU + Aerial Testbed 1.0?
cuphycontroller_P5G_WNC_DGX.txt (20.3 KB)
gnb-vnf.sa.band78.273prb.aerial.txt (8.3 KB)
RU config and L1 config look good. The only change I have is
Compression Bit = 9
Control and User Plane vlan = 564
M Plane vlan = 0
dpd mode : Enable
DU MAC Address = 9c63c0f426d2
RX gain = 14
TX power = 24
prach eAxC-id port 0, 1, 2, 3 = 0x0000, 0x0001, 0x0002, 0x0003
slotid = 0x00000001
sync source : PTP
and L1 config
eAxC_id_prach: [0, 1, 2, 3]
Can you check that FH communication is working?
# show pm-data
1,POWER,2026-05-19T14:42:50Z,2026-05-19T14:43:05Z,o-ran-hardware:O-RAN-RADIO,9.4441,10.4813,9.6644,iana-hardware:cpu,9.4441,10.4813,9.6644
2,TEMPERATURE,2026-05-19T14:42:50Z,2026-05-19T14:43:05Z,o-ran-hardware:O-RAN-RADIO,50.9755,52.8718,51.7920,iana-hardware:cpu,49.1570,51.4729,50.2212
13,VOLTAGE,2026-05-19T14:42:50Z,2026-05-19T14:43:20Z,0,0.0000,2026-05-19T14:42:52Z,1.4191,2026-05-19T14:43:09Z,0.0458,2026-05-19T14:42:51Z,0.0000,2026-05-19T14:43:20Z,3750000000
1,POWER,2026-05-19T14:43:05Z,2026-05-19T14:43:20Z,o-ran-hardware:O-RAN-RADIO,9.4441,10.5344,9.7935,iana-hardware:cpu,9.4441,10.5344,9.7935
2,TEMPERATURE,2026-05-19T14:43:05Z,2026-05-19T14:43:20Z,o-ran-hardware:O-RAN-RADIO,49.7787,52.5454,51.1828,iana-hardware:cpu,49.3746,51.3641,50.3341
1,RX_ON_TIME,2026-05-19T14:42:50Z,2026-05-19T14:43:20Z,O-RU,2547084386
2,RX_EARLY,2026-05-19T14:42:50Z,2026-05-19T14:43:20Z,O-RU,14
3,RX_LATE,2026-05-19T14:42:50Z,2026-05-19T14:43:20Z,O-RU,0
6,RX_TOTAL,2026-05-19T14:42:50Z,2026-05-19T14:43:20Z,O-RU,2924501496
7,RX_ON_TIME_C,2026-05-19T14:42:50Z,2026-05-19T14:43:20Z,O-RU,377417040
8,RX_EARLY_C,2026-05-19T14:42:50Z,2026-05-19T14:43:20Z,O-RU,0
9,RX_LATE_C,2026-05-19T14:42:50Z,2026-05-19T14:43:20Z,O-RU,0
1,TX_TOTAL,2026-05-19T14:42:50Z,2026-05-19T14:43:20Z,O-RU,2660881703
Hi @fmolander
It can now connect successfully, but we found that the stability is relatively poor, and it is much less stable than the WNC O-RU.
If we want to improve the stability, which aspects should we focus on optimizing?
1、error
07:42:06.501018 CON timer_thread 0 [L2A.MODULE] tick_received: tick_err 17359
07:42:06.501018 ERR timer_thread 0 [AERIAL_L2ADAPTER_EVENT] [SCF.PHY] send_slot_error_indication: Late slot error encountered for SFN 830.5
07:42:06.501020 ERR timer_thread 0 [AERIAL_NVIPC_API_EVENT] [SCF.PHY] Send Err.ind for SFN 830.5 cell_id=0 msg_id=0x82 err_code=0x34
07:42:06.639506 CON timer_thread 0 [NVLOG.STAT] [TICK.ERROR][N=10000][MIN=1520 AVG=2398 MAX=17359] exceed limit
07:42:06.640005 CON timer_thread 0 [SCF.PHY] Cell  0 | DL    0.05 Mbps   58 Slots | UL    0.01 Mbps   31 Slots CRC   0 ( 30452) | Tick 3990000
2、 error
07:44:19.640005 CON timer_thread 0 [SCF.PHY] Cell  0 | DL    0.06 Mbps   54 Slots | UL    0.03 Mbps   32 Slots CRC   8 ( 31774) | Tick 4256000
07:44:20.640005 CON timer_thread 0 [SCF.PHY] Cell  0 | DL    0.06 Mbps   59 Slots | UL    0.03 Mbps   32 Slots CRC  18 ( 31792) | Tick 4258000
07:44:21.640005 CON timer_thread 0 [SCF.PHY] Cell  0 | DL    0.06 Mbps   59 Slots | UL    0.01 Mbps   31 Slots CRC   0 ( 31792) | Tick 4260000
07:44:22.153915 ERR UlPhyDriver06 0 [AERIAL_CUPHYDRV_API_EVENT] [DRV.HARQ_POOL] Error: MAC reusing hqbuf for SFN 59.7 cur sfn 59.9 rnti 18044 hpid 3 cell_id 0 ndi 0  existing buff size 262144 new buff size 9984 is_bundled_pdu false while UL processing in flight. Return failure
07:44:22.153915 ERR UlPhyDriver06 0 [AERIAL_CUPHYDRV_API_EVENT] [DRV.PUSCH] bucketAllocateBuffer returned error
07:44:22.153915 WRN UlPhyDriver06 0 [DRV.FUNC_UL] PUSCH setup returned error for Map 38
07:44:22.158419 ERR UlPhyDriver19 0 [AERIAL_CUPHYDRV_API_EVENT] [DRV.HARQ_POOL] Error: MAC reusing hqbuf for SFN 59.17 cur sfn 59.18 rnti 18044 hpid 4 cell_id 0 ndi 0  existing buff size 262144 new buff size 9984 is_bundled_pdu false while UL processing in flight. Return failure
07:44:22.158419 ERR UlPhyDriver19 0 [AERIAL_CUPHYDRV_API_EVENT] [DRV.PUSCH] bucketAllocateBuffer returned error
07:44:22.158419 WRN UlPhyDriver19 0 [DRV.FUNC_UL] PUSCH setup returned error for Map 40
07:44:22.163419 ERR UlPhyDriver06 0 [AERIAL_CUPHYDRV_API_EVENT] [DRV.HARQ_POOL] Error: MAC reusing hqbuf for SFN 60.7 cur sfn 60.8 rnti 18044 hpid 6 cell_id 0 ndi 0  existing buff size 262144 new buff size 9984 is_bundled_pdu false while UL processing in flight. Return failure
07:44:22.163419 ERR UlPhyDriver06 0 [AERIAL_CUPHYDRV_API_EVENT] [DRV.PUSCH] bucketAllocateBuffer returned error
07:44:22.163419 WRN UlPhyDriver06 0 [DRV.FUNC_UL] PUSCH setup returned error for Map 43
07:44:22.173915 ERR UlPhyDriver19 0 [AERIAL_CUPHYDRV_API_EVENT] [DRV.HARQ_POOL] Error: MAC reusing hqbuf for SFN 61.7 cur sfn 61.9 rnti 18044 hpid 8 cell_id 0 ndi 0  existing buff size 262144 new buff size 9984 is_bundled_pdu false while UL processing in flight. Return failure
07:44:22.173915 ERR UlPhyDriver19 0 [AERIAL_CUPHYDRV_API_EVENT] [DRV.PUSCH] bucketAllocateBuffer returned error
07:44:22.173915 WRN UlPhyDriver19 0 [DRV.FUNC_UL] PUSCH setup returned error for Map 50
07:44:22.178418 ERR UlPhyDriver06 0 [AERIAL_CUPHYDRV_API_EVENT] [DRV.HARQ_POOL] Error: MAC reusing hqbuf for SFN 61.17 cur sfn 61.18 rnti 18044 hpid 7 cell_id 0 ndi 0  existing buff size 262144 new buff size 9984 is_bundled_pdu false while UL processing in flight. Return failure
07:44:22.178418 ERR UlPhyDriver06 0 [AERIAL_CUPHYDRV_API_EVENT] [DRV.PUSCH] bucketAllocateBuffer returned error
07:44:22.178418 WRN UlPhyDriver06 0 [DRV.FUNC_UL] PUSCH setup returned error for Map 52
07:44:22.183417 ERR UlPhyDriver19 0 [AERIAL_CUPHYDRV_API_EVENT] [DRV.HARQ_POOL] Error: MAC reusing hqbuf for SFN 62.7 cur sfn 62.8 rnti 18044 hpid 9 cell_id 0 ndi 0  existing buff size 262144 new buff size 9984 is_bundled_pdu false while UL processing in flight. Return failure
07:44:22.183417 ERR UlPhyDriver19 0 [AERIAL_CUPHYDRV_API_EVENT] [DRV.PUSCH] bucketAllocateBuffer returned error
07:44:22.183417 WRN UlPhyDriver19 0 [DRV.FUNC_UL] PUSCH setup returned error for Map 55
07:44:22.188417 ERR UlPhyDriver19 0 [AERIAL_CUPHYDRV_API_EVENT] [DRV.HARQ_POOL] Error: MAC reusing hqbuf for SFN 62.17 cur sfn 62.18 rnti 18044 hpid 11 cell_id 0 ndi 0  existing buff size 262144 new buff size 9984 is_bundled_pdu false while UL processing in flight. Return failure
07:44:22.188417 ERR UlPhyDriver19 0 [AERIAL_CUPHYDRV_API_EVENT] [DRV.PUSCH] bucketAllocateBuffer returned error
07:44:22.188417 WRN UlPhyDriver19 0 [DRV.FUNC_UL] PUSCH setup returned error for Map 58
07:44:22.193418 ERR UlPhyDriver05 0 [AERIAL_CUPHYDRV_API_EVENT] [DRV.HARQ_POOL] Error: MAC reusing hqbuf for SFN 63.7 cur sfn 63.8 rnti 18044 hpid 10 cell_id 0 ndi 0  existing buff size 262144 new buff size 9984 is_bundled_pdu false while UL processing in flight. Return failure
07:44:22.193418 ERR UlPhyDriver05 0 [AERIAL_CUPHYDRV_API_EVENT] [DRV.PUSCH] bucketAllocateBuffer returned error
07:44:22.193418 WRN UlPhyDriver05 0 [DRV.FUNC_UL] PUSCH setup returned error for Map 61
07:44:22.640005 CON timer_thread 0 [SCF.PHY] Cell  0 | DL    0.15 Mbps   71 Slots | UL    0.05 Mbps  131 Slots CRC  66 ( 31858) | Tick 4262000
07:44:22.798914 ERR UlPhyDriver06 0 [AERIAL_CUPHYDRV_API_EVENT] [DRV.HARQ_POOL] Error: MAC reusing hqbuf for SFN 123.17 cur sfn 123.19 rnti 18044 hpid 6 cell_id 0 ndi 0  existing buff size 262144 new buff size 3120 is_bundled_pdu false while UL processing in flight. Return failure
07:44:22.798914 ERR UlPhyDriver06 0 [AERIAL_CUPHYDRV_API_EVENT] [DRV.PUSCH] bucketAllocateBuffer returned error
07:44:22.798914 WRN UlPhyDriver06 0 [DRV.FUNC_UL] PUSCH setup returned error for Map 281
07:44:22.803416 ERR UlPhyDriver05 0 [AERIAL_CUPHYDRV_API_EVENT] [DRV.HARQ_POOL] Error: MAC reusing hqbuf for SFN 124.7 cur sfn 124.8 rnti 18044 hpid 5 cell_id 0 ndi 0  existing buff size 262144 new buff size 3120 is_bundled_pdu false while UL processing in flight. Return failure
07:44:22.803416 ERR UlPhyDriver05 0 [AERIAL_CUPHYDRV_API_EVENT] [DRV.PUSCH] bucketAllocateBuffer returned error
07:44:22.803416 WRN UlPhyDriver05 0 [DRV.FUNC_UL] PUSCH setup returned error for Map 283
07:44:22.813917 ERR UlPhyDriver19 0 [AERIAL_CUPHYDRV_API_EVENT] [DRV.HARQ_POOL] Error: MAC reusing hqbuf for SFN 125.7 cur sfn 125.9 rnti 18044 hpid 7 cell_id 0 ndi 0  existing buff size 262144 new buff size 3120 is_bundled_pdu false while UL processing in flight. Return failure
07:44:22.813917 ERR UlPhyDriver19 0 [AERIAL_CUPHYDRV_API_EVENT] [DRV.PUSCH] bucketAllocateBuffer returned error
07:44:22.813917 WRN UlPhyDriver19 0 [DRV.FUNC_UL] PUSCH setup returned error for Map 290
07:44:22.818416 ERR UlPhyDriver05 0 [AERIAL_CUPHYDRV_API_EVENT] [DRV.HARQ_POOL] Error: MAC reusing hqbuf for SFN 125.17 cur sfn 125.18 rnti 18044 hpid 9 cell_id 0 ndi 0  existing buff size 262144 new buff size 3120 is_bundled_pdu false while UL processing in flight. Return failure
07:44:22.818416 ERR UlPhyDriver05 0 [AERIAL_CUPHYDRV_API_EVENT] [DRV.PUSCH] bucketAllocateBuffer returned error
07:44:22.818416 WRN UlPhyDriver05 0 [DRV.FUNC_UL] PUSCH setup returned error for Map 292
07:44:22.828914 ERR UlPhyDriver05 0 [AERIAL_CUPHYDRV_API_EVENT] [DRV.HARQ_POOL] Error: MAC reusing hqbuf for SFN 126.17 cur sfn 126.19 rnti 18044 hpid 10 cell_id 0 ndi 0  existing buff size 262144 new buff size 3120 is_bundled_pdu false while UL processing in flight. Return failure
07:44:22.828914 ERR UlPhyDriver05 0 [AERIAL_CUPHYDRV_API_EVENT] [DRV.PUSCH] bucketAllocateBuffer returned error
07:44:22.828914 WRN UlPhyDriver05 0 [DRV.FUNC_UL] PUSCH setup returned error for Map 299
07:44:22.833419 ERR UlPhyDriver19 0 [AERIAL_CUPHYDRV_API_EVENT] [DRV.HARQ_POOL] Error: MAC reusing hqbuf for SFN 127.7 cur sfn 127.8 rnti 18044 hpid 12 cell_id 0 ndi 0  existing buff size 262144 new buff size 3120 is_bundled_pdu false while UL processing in flight. Return failure
07:44:22.833419 ERR UlPhyDriver19 0 [AERIAL_CUPHYDRV_API_EVENT] [DRV.PUSCH] bucketAllocateBuffer returned error
07:44:22.833419 WRN UlPhyDriver19 0 [DRV.FUNC_UL] PUSCH setup returned error for Map 301
07:44:22.958911 ERR UlPhyDriver06 0 [AERIAL_CUPHYDRV_API_EVENT] [DRV.HARQ_POOL] Error: MAC reusing hqbuf for SFN 139.17 cur sfn 139.19 rnti 18044 hpid 5 cell_id 0 ndi 0  existing buff size 262144 new buff size 3120 is_bundled_pdu false while UL processing in flight. Return failure
07:44:22.958912 ERR UlPhyDriver06 0 [AERIAL_CUPHYDRV_API_EVENT] [DRV.PUSCH] bucketAllocateBuffer returned error
07:44:22.958912 WRN UlPhyDriver06 0 [DRV.FUNC_UL] PUSCH setup returned error for Map 355
07:44:22.963417 ERR UlPhyDriver06 0 [AERIAL_CUPHYDRV_API_EVENT] [DRV.HARQ_POOL] Error: MAC reusing hqbuf for SFN 140.7 cur sfn 140.8 rnti 18044 hpid 8 cell_id 0 ndi 0  existing buff size 262144 new buff size 3120 is_bundled_pdu false while UL processing in flight. Return failure
07:44:22.963417 ERR UlPhyDriver06 0 [AERIAL_CUPHYDRV_API_EVENT] [DRV.PUSCH] bucketAllocateBuffer returned error
07:44:22.963417 WRN UlPhyDriver06 0 [DRV.FUNC_UL] PUSCH setup returned error for Map 357
07:44:22.973914 ERR UlPhyDriver19 0 [AERIAL_CUPHYDRV_API_EVENT] [DRV.HARQ_POOL] Error: MAC reusing hqbuf for SFN 141.7 cur sfn 141.9 rnti 18044 hpid 9 cell_id 0 ndi 0  existing buff size 262144 new buff size 3120 is_bundled_pdu false while UL processing in flight. Return failure
07:44:22.973914 ERR UlPhyDriver19 0 [AERIAL_CUPHYDRV_API_EVENT] [DRV.PUSCH] bucketAllocateBuffer returned error
07:44:22.973914 WRN UlPhyDriver19 0 [DRV.FUNC_UL] PUSCH setup returned error for Map 364
07:44:22.978416 ERR UlPhyDriver05 0 [AERIAL_CUPHYDRV_API_EVENT] [DRV.HARQ_POOL] Error: MAC reusing hqbuf for SFN 141.17 cur sfn 141.18 rnti 18044 hpid 11 cell_id 0 ndi 0  existing buff size 262144 new buff size 3120 is_bundled_pdu false while UL processing in flight. Return failure
07:44:22.978416 ERR UlPhyDriver05 0 [AERIAL_CUPHYDRV_API_EVENT] [DRV.PUSCH] bucketAllocateBuffer returned error
07:44:22.978416 WRN UlPhyDriver05 0 [DRV.FUNC_UL] PUSCH setup returned error for Map 366
07:44:22.988916 ERR UlPhyDriver06 0 [AERIAL_CUPHYDRV_API_EVENT] [DRV.HARQ_POOL] Error: MAC reusing hqbuf for SFN 142.17 cur sfn 142.19 rnti 18044 hpid 12 cell_id 0 ndi 0  existing buff size 262144 new buff size 3120 is_bundled_pdu false while UL processing in flight. Return failure
07:44:22.988916 ERR UlPhyDriver06 0 [AERIAL_CUPHYDRV_API_EVENT] [DRV.PUSCH] bucketAllocateBuffer returned error
07:44:22.988916 WRN UlPhyDriver06 0 [DRV.FUNC_UL] PUSCH setup returned error for Map 373
07:44:22.993420 ERR UlPhyDriver19 0 [AERIAL_CUPHYDRV_API_EVENT] [DRV.HARQ_POOL] Error: MAC reusing hqbuf for SFN 143.7 cur sfn 143.8 rnti 18044 hpid 15 cell_id 0 ndi 0  existing buff size 262144 new buff size 3120 is_bundled_pdu false while UL processing in flight. Return failure
07:44:22.993420 ERR UlPhyDriver19 0 [AERIAL_CUPHYDRV_API_EVENT] [DRV.PUSCH] bucketAllocateBuffer returned error
07:44:22.993420 WRN UlPhyDriver19 0 [DRV.FUNC_UL] PUSCH setup returned error for Map 375
07:44:23.198914 ERR UlPhyDriver05 0 [AERIAL_CUPHYDRV_API_EVENT] [DRV.HARQ_POOL] Error: MAC reusing hqbuf for SFN 163.17 cur sfn 163.19 rnti 18044 hpid 2 cell_id 0 ndi 0  existing buff size 262144 new buff size 3120 is_bundled_pdu false while UL processing in flight. Return failure
07:44:23.198914 ERR UlPhyDriver05 0 [AERIAL_CUPHYDRV_API_EVENT] [DRV.PUSCH] bucketAllocateBuffer returned error
07:44:23.198914 WRN UlPhyDriver05 0 [DRV.FUNC_UL] PUSCH setup returned error for Map 492
07:44:23.203415 ERR UlPhyDriver05 0 [AERIAL_CUPHYDRV_API_EVENT] [DRV.HARQ_POOL] Error: MAC reusing hqbuf for SFN 164.7 cur sfn 164.8 rnti 18044 hpid 3 cell_id 0 ndi 0  existing buff size 262144 new buff size 3120 is_bundled_pdu false while UL processing in flight. Return failure
07:44:23.203415 ERR UlPhyDriver05 0 [AERIAL_CUPHYDRV_API_EVENT] [DRV.PUSCH] bucketAllocateBuffer returned error
07:44:23.203415 WRN UlPhyDriver05 0 [DRV.FUNC_UL] PUSCH setup returned error for Map 494
07:44:23.213915 ERR UlPhyDriver05 0 [AERIAL_CUPHYDRV_API_EVENT] [DRV.HARQ_POOL] Error: MAC reusing hqbuf for SFN 165.7 cur sfn 165.9 rnti 18044 hpid 6 cell_id 0 ndi 0  existing buff size 262144 new buff size 3120 is_bundled_pdu false while UL processing in flight. Return failure
07:44:23.213915 ERR UlPhyDriver05 0 [AERIAL_CUPHYDRV_API_EVENT] [DRV.PUSCH] bucketAllocateBuffer returned error
07:44:23.213915 WRN UlPhyDriver05 0 [DRV.FUNC_UL] PUSCH setup returned error for Map 501
07:44:23.218417 ERR UlPhyDriver05 0 [AERIAL_CUPHYDRV_API_EVENT] [DRV.HARQ_POOL] Error: MAC reusing hqbuf for SFN 165.17 cur sfn 165.18 rnti 18044 hpid 5 cell_id 0 ndi 0  existing buff size 262144 new buff size 3120 is_bundled_pdu false while UL processing in flight. Return failure
07:44:23.218417 ERR UlPhyDriver05 0 [AERIAL_CUPHYDRV_API_EVENT] [DRV.PUSCH] bucketAllocateBuffer returned error
07:44:23.218417 WRN UlPhyDriver05 0 [DRV.FUNC_UL] PUSCH setup returned error for Map 503
07:44:23.228911 ERR UlPhyDriver06 0 [AERIAL_CUPHYDRV_API_EVENT] [DRV.HARQ_POOL] Error: MAC reusing hqbuf for SFN 166.17 cur sfn 166.19 rnti 18044 hpid 7 cell_id 0 ndi 0  existing buff size 262144 new buff size 3120 is_bundled_pdu false while UL processing in flight. Return failure
07:44:23.228911 ERR UlPhyDriver06 0 [AERIAL_CUPHYDRV_API_EVENT] [DRV.PUSCH] bucketAllocateBuffer returned error
07:44:23.228911 WRN UlPhyDriver06 0 [DRV.FUNC_UL] PUSCH setup returned error for Map 510
07:44:23.233418 ERR UlPhyDriver19 0 [AERIAL_CUPHYDRV_API_EVENT] [DRV.HARQ_POOL] Error: MAC reusing hqbuf for SFN 167.7 cur sfn 167.8 rnti 18044 hpid 9 cell_id 0 ndi 0  existing buff size 262144 new buff size 3120 is_bundled_pdu false while UL processing in flight. Return failure
07:44:23.233418 ERR UlPhyDriver19 0 [AERIAL_CUPHYDRV_API_EVENT] [DRV.PUSCH] bucketAllocateBuffer returned error
07:44:23.233418 WRN UlPhyDriver19 0 [DRV.FUNC_UL] PUSCH setup returned error for Map 0
07:44:23.640004 CON timer_thread 0 [SCF.PHY] Cell  0 | DL    1.24 Mbps   99 Slots | UL    0.05 Mbps  278 Slots CRC  40 ( 31898) | Tick 4264000
07:44:24.640005 CON timer_thread 0 [SCF.PHY] Cell  0 | DL   15.16 Mbps  348 Slots | UL    0.31 Mbps  124 Slots CRC  53 ( 31951) | Tick 4266000
3、 error
07:43:02.640005 CON timer_thread 0 [SCF.PHY] Cell  0 | DL    0.28 Mbps  122 Slots | UL    0.39 Mbps   90 Slots CRC   0 ( 30819) | Tick 4102000
07:43:03.640005 CON timer_thread 0 [SCF.PHY] Cell  0 | DL    0.23 Mbps  109 Slots | UL    0.31 Mbps   83 Slots CRC   7 ( 30826) | Tick 4104000
07:43:04.529434 WRN UlPhyDriver06 0 [DRV.HARQ_POOL] HARQ pool[0/1] at less than 30 percent availability. Hystersis=1
07:43:04.534432 WRN UlPhyDriver19 0 [DRV.HARQ_POOL] HARQ pool[0/1] at less than 30 percent availability. Hystersis=2
07:43:04.539435 WRN UlPhyDriver05 0 [DRV.HARQ_POOL] HARQ pool[0/1] at less than 30 percent availability. Hystersis=3
07:43:04.544434 WRN UlPhyDriver06 0 [DRV.HARQ_POOL] HARQ pool[0/1] at less than 30 percent availability. Hystersis=4
07:43:04.549433 WRN UlPhyDriver05 0 [DRV.HARQ_POOL] HARQ pool[0/1] at less than 30 percent availability. Entering massive cleanup
07:43:04.549579 WRN UlPhyDriver05 0 [DRV.HARQ_POOL]  Tried to free 99 stale buffers, but only freed 416 buffers
07:43:04.549579 WRN UlPhyDriver05 0 [DRV.HARQ_POOL] HARQ pool[0] has 213 buffers
07:43:04.549579 WRN UlPhyDriver05 0 [DRV.HARQ_POOL] HARQ pool[1] has 256 buffers
07:43:04.549580 WRN UlPhyDriver05 0 [DRV.HARQ_POOL] HARQ pool[2] has 256 buffers
07:43:04.640005 CON timer_thread 0 [SCF.PHY] Cell  0 | DL    0.12 Mbps   86 Slots | UL    0.04 Mbps  113 Slots CRC 105 ( 30931) | Tick 4106000
07:43:05.640005 CON timer_thread 0 [SCF.PHY] Cell  0 | DL    0.09 Mbps  130 Slots | UL    0.12 Mbps   99 Slots CRC  39 ( 30970) | Tick 4108000
HI
I have only tested Liteon on Grace Hopper. For reference please have a look at my L1 config for Liteon.
With UEsim i could do 1000Mbps DL and 120Mbps UL.
cuphycontroller_P5G_LO_GH.yaml (19.7 KB)
