I recently have to flash my Jetson Orin Nano again due to some issues. While trying to setup Stable Diffusion this round using this guide: https://www.jetson-ai-lab.com/tutorial_stable-diffusion.html
I am hit with a very weird error message below which I have never encountered previously, the last few lines of the errors are:
stderr: WARNING: Retrying (Retry(total=4, connect=None, read=None, redirect=None, status=None)) after connection broken by 'NewConnectionError('<pip._vendor.urllib3.connection.HTTPSConnection object at 0xffff908076a0>: Failed to establish a new connection: [Errno 113] No route to host')': /jp6/cu126/numpy/
WARNING: Retrying (Retry(total=3, connect=None, read=None, redirect=None, status=None)) after connection broken by 'NewConnectionError('<pip._vendor.urllib3.connection.HTTPSConnection object at 0xffff908079d0>: Failed to establish a new connection: [Errno 113] No route to host')': /jp6/cu126/numpy/
WARNING: Retrying (Retry(total=2, connect=None, read=None, redirect=None, status=None)) after connection broken by 'NewConnectionError('<pip._vendor.urllib3.connection.HTTPSConnection object at 0xffff90807b80>: Failed to establish a new connection: [Errno 113] No route to host')': /jp6/cu126/numpy/
WARNING: Retrying (Retry(total=1, connect=None, read=None, redirect=None, status=None)) after connection broken by 'NewConnectionError('<pip._vendor.urllib3.connection.HTTPSConnection object at 0xffff90807d30>: Failed to establish a new connection: [Errno 113] No route to host')': /jp6/cu126/numpy/
WARNING: Retrying (Retry(total=0, connect=None, read=None, redirect=None, status=None)) after connection broken by 'NewConnectionError('<pip._vendor.urllib3.connection.HTTPSConnection object at 0xffff90807f10>: Failed to establish a new connection: [Errno 113] No route to host')': /jp6/cu126/numpy/
ERROR: Could not find a version that satisfies the requirement numpy==1.26.2 (from versions: none)
ERROR: No matching distribution found for numpy==1.26.2
I’d be happy to help you troubleshoot the issue with your Jetson Orin Nano.
Firstly, I’d like to acknowledge that you’ve had to reflash your Jetson Orin Nano due to some issues, and now you’re encountering a weird error message while trying to set up Stable Diffusion using the guide from Jetson AI Lab.
To better understand the issue, could you please provide more details about the error message you’re seeing? Specifically, the last few lines of the error message would be helpful. Additionally, have you made any changes to your setup or configuration since the last time you successfully ran Stable Diffusion on your Jetson Orin Nano?
That being said, I can try to provide some general troubleshooting steps and potential causes for the issue.
Check the guide and dependencies: Double-check that you’ve followed the guide correctly and that all dependencies are installed and up-to-date.
Verify the Jetson Orin Nano’s configuration: Ensure that your Jetson Orin Nano is properly configured and that the power modes are set correctly. You can refer to the NVIDIA documentation for more information on configuring the Jetson Orin Nano.
Check for software updates: Make sure that your Jetson Orin Nano is running the latest software versions, including the JetPack SDK and any other relevant software packages.
Inspect the error message: Look for any clues in the error message that might indicate the cause of the issue. Check for any specific error codes, file paths, or library names that might be relevant.
In terms of potential causes, here are a few possibilities:
Software compatibility issues: It’s possible that there’s a compatibility issue between the Stable Diffusion software and the Jetson Orin Nano’s software configuration.
Power mode issues: The Jetson Orin Nano has different power modes that can affect performance and functionality. It’s possible that the power mode is not set correctly, leading to the error.
Dependency issues: Stable Diffusion may rely on specific dependencies or libraries that are not installed or configured correctly on your Jetson Orin Nano.
To further assist you, I’d like to ask a few more questions:
Have you tried running other AI models or applications on your Jetson Orin Nano since the reflash?
Are you using the same guide and software versions as before, or have you updated to newer versions?
Have you checked the NVIDIA forums or documentation for any known issues or troubleshooting guides related to Stable Diffusion on the Jetson Orin Nano?
Please feel free to provide more information or clarify any of these points, and I’ll do my best to help you troubleshoot the issue.
Thanks for informing, had tried to run but still the same error:
stderr: WARNING: Retrying (Retry(total=4, connect=None, read=None, redirect=None, status=None)) after connection broken by ‘NewConnectionError(’<pip._vendor.urllib3.connection.HTTPSConnection object at 0xffffb5227490>: Failed to establish a new connection: [Errno 113] No route to host’)‘: /jp6/cu126/numpy/ WARNING: Retrying (Retry(total=3, connect=None, read=None, redirect=None, status=None)) after connection broken by ‘NewConnectionError(’<pip._vendor.urllib3.connection.HTTPSConnection object at 0xffffb52277c0>: Failed to establish a new connection: [Errno 113] No route to host’)‘: /jp6/cu126/numpy/ WARNING: Retrying (Retry(total=2, connect=None, read=None, redirect=None, status=None)) after connection broken by ‘NewConnectionError(’<pip._vendor.urllib3.connection.HTTPSConnection object at 0xffffb5227970>: Failed to establish a new connection: [Errno 113] No route to host’)‘: /jp6/cu126/numpy/ WARNING: Retrying (Retry(total=1, connect=None, read=None, redirect=None, status=None)) after connection broken by ‘NewConnectionError(’<pip._vendor.urllib3.connection.HTTPSConnection object at 0xffffb5227b20>: Failed to establish a new connection: [Errno 113] No route to host’)‘: /jp6/cu126/numpy/ WARNING: Retrying (Retry(total=0, connect=None, read=None, redirect=None, status=None)) after connection broken by ‘NewConnectionError(’<pip._vendor.urllib3.connection.HTTPSConnection object at 0xffffb5227cd0>: Failed to establish a new connection: [Errno 113] No route to host’)': /jp6/cu126/numpy/ ERROR: Could not find a version that satisfies the requirement numpy==1.26.2 (from versions: none) ERROR: No matching distribution found for numpy==1.26.2
I tried setting ‘INDEX_HOST=jetson-ai-lab.io’ in the session - then running “jetson-containers run $(autotag stable-diffusion-webui)” again - but I still get:
Installing requirements
File “/opt/stable-diffusion-webui/launch.py”, line 48, in
main()
File “/opt/stable-diffusion-webui/launch.py”, line 39, in main
prepare_environment()
File “/opt/stable-diffusion-webui/modules/launch_utils.py”, line 423, in prepare_environment
run_pip(f"install -r “{requirements_file}”“, “requirements”)
File “/opt/stable-diffusion-webui/modules/launch_utils.py”, line 144, in run_pip
return run(f’”{python}" -m pip {command} --prefer-binary{index_url_line}', desc=f"Installing {desc}“, errdesc=f"Couldn’t install {desc}”, live=live)
File “/opt/stable-diffusion-webui/modules/launch_utils.py”, line 116, in run
raise RuntimeError(“\n”.join(error_bits))
RuntimeError: Couldn’t install requirements.
Command: “/usr/local/bin/python3” -m pip install -r “requirements_versions.txt” --prefer-binary
Error code: 1
stdout: Using pip 25.0.1 from /usr/local/lib/python3.10/dist-packages/pip (python 3.10)
Looking in indexes: https://pypi.jetson-ai-lab.dev/jp6/cu126
How do I get it to look at jetson-ai-lab.io instead of pypi.jetson-ai-lab.dev ?
I updated the file, and ran:
bash jetson-containers/install.sh
Same error. :(
main()
Error code: 1
Requirement already satisfied: setuptools==69.5.1 in /usr/local/lib/python3.10/dist-packages (from -r requirements_versions.txt (line 1)) (69.5.1)
Requirement already satisfied: GitPython==3.1.32 in /usr/local/lib/python3.10/dist-packages (from -r requirements_versions.txt (line 2)) (3.1.32)
Requirement already satisfied: Pillow==9.5.0 in /usr/local/lib/python3.10/dist-packages (from -r requirements_versions.txt (line 3)) (9.5.0)
Requirement already satisfied: accelerate==0.21.0 in /usr/local/lib/python3.10/dist-packages (from -r requirements_versions.txt (line 4)) (0.21.0)
Requirement already satisfied: blendmodes==2022 in /usr/local/lib/python3.10/dist-packages (from -r requirements_versions.txt (line 5)) (2022)
Requirement already satisfied: clean-fid==0.1.35 in /usr/local/lib/python3.10/dist-packages (from -r requirements_versions.txt (line 6)) (0.1.35)
Requirement already satisfied: diskcache==5.6.3 in /usr/local/lib/python3.10/dist-packages (from -r requirements_versions.txt (line 7)) (5.6.3)
Requirement already satisfied: einops==0.4.1 in /usr/local/lib/python3.10/dist-packages (from -r requirements_versions.txt (line 8)) (0.4.1)
Requirement already satisfied: facexlib==0.3.0 in /usr/local/lib/python3.10/dist-packages (from -r requirements_versions.txt (line 9)) (0.3.0)
Requirement already satisfied: fastapi==0.94.0 in /usr/local/lib/python3.10/dist-packages (from -r requirements_versions.txt (line 10)) (0.94.0)
Requirement already satisfied: gradio==3.41.2 in /usr/local/lib/python3.10/dist-packages (from -r requirements_versions.txt (line 11)) (3.41.2)
Requirement already satisfied: httpcore==0.15 in /usr/local/lib/python3.10/dist-packages (from -r requirements_versions.txt (line 12)) (0.15.0)
Requirement already satisfied: inflection==0.5.1 in /usr/local/lib/python3.10/dist-packages (from -r requirements_versions.txt (line 13)) (0.5.1)
Requirement already satisfied: jsonmerge==1.8.0 in /usr/local/lib/python3.10/dist-packages (from -r requirements_versions.txt (line 14)) (1.8.0)
Requirement already satisfied: kornia==0.6.7 in /usr/local/lib/python3.10/dist-packages (from -r requirements_versions.txt (line 15)) (0.6.7)
Requirement already satisfied: lark==1.1.2 in /usr/local/lib/python3.10/dist-packages (from -r requirements_versions.txt (line 16)) (1.1.2)
stderr: WARNING: Retrying (Retry(total=4, connect=None, read=None, redirect=None, status=None)) after connection broken by ‘NewConnectionError(’<pip._vendor.urllib3.connection.HTTPSConnection object at 0xffffa16d76d0>: Failed to establish a new connection: [Errno 113] No route to host’)‘: /jp6/cu126/numpy/
WARNING: Retrying (Retry(total=3, connect=None, read=None, redirect=None, status=None)) after connection broken by ‘NewConnectionError(’<pip._vendor.urllib3.connection.HTTPSConnection object at 0xffffa16d7a00>: Failed to establish a new connection: [Errno 113] No route to host’)‘: /jp6/cu126/numpy/
WARNING: Retrying (Retry(total=2, connect=None, read=None, redirect=None, status=None)) after connection broken by ‘NewConnectionError(’<pip._vendor.urllib3.connection.HTTPSConnection object at 0xffffa16d7bb0>: Failed to establish a new connection: [Errno 113] No route to host’)‘: /jp6/cu126/numpy/
WARNING: Retrying (Retry(total=1, connect=None, read=None, redirect=None, status=None)) after connection broken by ‘NewConnectionError(’<pip._vendor.urllib3.connection.HTTPSConnection object at 0xffffa16d7d60>: Failed to establish a new connection: [Errno 113] No route to host’)‘: /jp6/cu126/numpy/
WARNING: Retrying (Retry(total=0, connect=None, read=None, redirect=None, status=None)) after connection broken by ‘NewConnectionError(’<pip._vendor.urllib3.connection.HTTPSConnection object at 0xffffa16d7f40>: Failed to establish a new connection: [Errno 113] No route to host’)': /jp6/cu126/numpy/
